E36 (1991 - 1999)
Old 03-19-2012, 05:31 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
wow that looks like a lot of camber!!!!
df
Old 03-19-2012, 05:37 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Mind you, the camber can be adjusted (haven't touched it yet) and the rear of the control arm is just chillin there lol.
Turbo Build Here
Old 03-19-2012, 06:06 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Have you been running those HP Plus pads before, or are they new, too?
1998 BMW 328is
1966 Pontiac GTO
Old 03-19-2012, 06:08 PM
Needs Boost
Mein Auto: Red Sled
New, haven't had the 4 piston calipers on yet, or the M3 rears.
So all the brakes will be new, pads, rotors, calipers, lines, and fluid.
Turbo Build Here
Old 03-19-2012, 06:17 PM
ZeGerman's Avatar
Warm Leatherette
Your car is going to feel totally different on so many levels.
PS: What's the status on the head gasket repair?
1998 BMW 328is
1966 Pontiac GTO
Old 03-19-2012, 06:26 PM
Needs Boost
Mein Auto: Red Sled
I know, I'm pretty excited! I've had many of these parts for YEARS.
Turbo Build Here
Old 03-21-2012, 06:24 PM
Needs Boost
Mein Auto: Red Sled
Haven't touched the HG yet, trying to find a .140 first.
Picked some things up from the blaster today:
Went to town:
Started on the Wilwood install:
Trimmed backing plate:
Installed:
Gonna press these in tomorrow and the front will be done minus bleeding the brakes and alignment.
Anyone know if the fat end of the bushing goes towards the front or rear of the car?
Turbo Build Here
Old 03-21-2012, 06:34 PM
ZeGerman's Avatar
Warm Leatherette
I think they do, but double-check that first.
1998 BMW 328is
1966 Pontiac GTO
Old 03-21-2012, 06:38 PM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
woah woah where the heck you find studded hubs?
-Dino
Needs Boost
Mein Auto: Red Sled
Huh? lol didn't answer the question:
"Anyone know if the fat end of the bushing goes towards the front or rear of the car?"
Turbo Build Here
Old 03-21-2012, 06:39 PM
Needs Boost
Mein Auto: Red Sled
I put new hubs on, and purchased studs long ago. Bimmerworld and many other sites sell them. I hate not having them.
Turbo Build Here
Old 03-21-2012, 06:45 PM
ZeGerman's Avatar
Warm Leatherette
Oh, sorry, I meant that I think the fat end goes toward the front, but double-check. They go toward the front with most poly FCABs, so I'm assuming yours are the same.
1998 BMW 328is
1966 Pontiac GTO
Old 03-21-2012, 06:49 PM
Needs Boost
Mein Auto: Red Sled
Yes I would assume, I'm pretty sure these will be easy to pull out too if something is wrong.
Turbo Build Here
Old 03-21-2012, 07:27 PM
uhh....they go this way....
-O O- in the vehicle. the 'fat end' points inwards...the bevel should be indexed to only mount 1 way and have the bushing inward.
df
Old 03-21-2012, 07:52 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Wow! Everything in that wheel well is so nice and clean!
-CJ
Old 03-22-2012, 07:09 PM
Needs Boost
Mein Auto: Red Sled
Thanks! It's all new.
Installed my AKG control arm bushings and greased them up.
Also pressed in the rear wishbone bushings.
Then I painted my buddies STI bumper and fog covers.
unfortunately I found out I need spacers to make the front wheels fit.
Sent from my ADR6400L using Bimmer App
Turbo Build Here
Old 03-23-2012, 12:41 PM
DinanM3e36's Avatar
DinanM3e36 DinanM3e36 is offline
WayTooFastWhitey
Mein Auto: Dinan BMW M3 e36
Where are you located? We have a lot to discuss boosting everything
Old 03-23-2012, 01:34 PM
ZeGerman's Avatar
Warm Leatherette
I love your updates, Matt. Do you need spacers due to the brakes, or the struts, or both?
1998 BMW 328is
1966 Pontiac GTO
Old 03-23-2012, 05:25 PM
Needs Boost
Mein Auto: Red Sled
What are we discussing Dino?
Thanks Karl. More coming in a few. The wheel touches the strut.
Turbo Build Here
Needs Boost
Mein Auto: Red Sled
Oh and I'm at 17257
Turbo Build Here
Old 03-23-2012, 06:19 PM
Needs Boost
Mein Auto: Red Sled
Progress made today:
Homebrew spacers, cut down the old rotors then lath them. Walah!
Rear setup is ready, minus camber arms (not pictured)
Rear end torn apart and ready for install:
Two of my homebrew 6mm spacers was enough to clear the wheel from the strut, so I'm going to purchase 2 12mm for the fronts. The 6mm will work perfect for the rear.
Ran into a moment, I forgot my 325 axles won't work in these hubs! Anyone have a spare set of the bigger ones? Not sure if it's just M3 or 328 as well.
Turbo Build Here
Old 03-25-2012, 01:15 AM
DinanM3e36's Avatar
WayTooFastWhitey
^+1 I'm sooooo jealous, keep up the good work I'm sure we'll cross paths one day...
Old 03-25-2012, 01:18 AM
DinanM3e36's Avatar
WayTooFastWhitey
Hey I've got slide on 1/4 spacers PM me if you want them think I got 2 maybe 4, I def don't need em I'm slammed with lots of rubber
Old 03-25-2012, 01:23 AM
DinanM3e36's Avatar
WayTooFastWhitey
Pm'ed you, you really should use the ones I have cause they are milled nice and flat
6.35mm = .25in
Old 03-25-2012, 04:44 AM
BMRfanatic's Avatar
Everything on this car is so damn new, I love it
Take my car under your wings?
-Dino
:3
