E36 (1991 - 1999)
Old 07-11-2012, 12:04 PM
hornhospital's Avatar
D'oh, You Kids!
They are BMW Style 127, known commonly as CSLs.
Quotes to live by:
Old 07-11-2012, 12:10 PM
FenderBender's Avatar
FenderBender FenderBender is online now
Needs Boost
Mein Auto: Red Sled
Yup, they are CSL reps.
Sent from my ADR6400L using Bimmer App
Turbo Build Here
Old 07-30-2012, 12:43 PM
short-circuit short-circuit is offline
Mein Auto: 97'328is
i don't know whether to boost my car or not i keep changing my mind although i really want to.The car was expensive like all cars here so dont have enough money left ANOTHER DOWNFALL IS THAT IT HAS 228232 KM ON IT but it spent most of its life in Germany and cant find a place to check the compression in the cylinders.plus want to change the rims but toooo many choices i know i want 17" though.
Need advice on whether to go with it or not plus what kind of turbo maybe even twins since i might do it anyways.
Oh and everything is still original even the cooling system.
Old 07-31-2012, 11:52 AM
Mein Auto: 97'328is
Would i have to change the suspension or just keep it stock would be fine???
Old 07-31-2012, 02:46 PM
Needs Boost
Mein Auto: Red Sled
If you are really serious, you need to have some serious cash saved up, are you doing the work or someone else? I would say 6k minimum.
Don't use twin turbos.
What kind of power do you want to make? That's the question that needs to be addressed first.
The whole car should be updated at least maintenance wise, suspension, brakes, engine, cooling, etc.
Turbo Build Here
Old 08-01-2012, 12:57 PM
Mein Auto: 97'328is
Hey im doing the work and i want to make about 350-380whp. i updated the cooling system yesterday.
since here in lebanon everything is soo expensive 6k in the us will probably be about 10k here if i do the work.but i might get the things from there.
what i want to know is would i have to change the clutch and if h&r suspension would be good.
what kind of turbo should i get and should i put it in the end since with little money i would upgrade the car periodically and if i put the turbo in first i might crack something or burn the engine.
why no twin turbo.
sorry for asking sooo many questions and thanks.
Old 08-01-2012, 03:25 PM
Needs Boost
Mein Auto: Red Sled
Twin turbo is too complicated and hard to fit on these cars, really no benefits.
I'd go with a turbo like a GT30r, GT35r, Precision 6262, or a good old fashion cheap 60-1. Those will all do your power goal.
The clutch will need to be changed for sure, go with the F1 stage 3 package on ebay. Your engine will be just fine as long as it is in decent shape now and you get a good tune.
Turbo Build Here
Old 08-01-2012, 03:30 PM
Needs Boost
Mein Auto: Red Sled
In other news, have a big order coming in, trying to get a lot done before bimmerfest.
Add a third gauge to A pillar, and have it professionally molded together and wrapped in suede. I'll do the headliner and other pillars to match, as well as the shift boot, e brake boot, and armrest.
5mm spacers for the front.
Smaller tires for the front (rubbing issues)
New Styrofoam piece that goes under the rear bumper (to align it better)
New windshield cowl.
New used window trim and door seals.
New window seals for the coupe glass on the bottom.
Splitters.
Center carrier and guibo.
I also need to aim my driver's side headlight, change oil and filter, change coolant, clean/detail, powder coat my valve cover, and some other things I'm forgetting.
Turbo Build Here
Old 08-01-2012, 06:05 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Cool beans. Sounds like you've got your work cut out for yourself.
-CJ
Old 08-01-2012, 07:22 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
cool beans?? cool beans??!!! omg, dude....like, 1988 just called. they want their expression back...
df
Old 08-01-2012, 08:40 PM
cj.surr's Avatar
some kid
:d
-CJ
Old 08-23-2012, 08:21 PM
Needs Boost
Mein Auto: Red Sled
Doing last minute work in CJ fashion.
"New" guibo (from one of my auto trannies) (Yes I spelled it guibo, no giubo and will continue to do so)
New center carrier bearing
Front looks good right? I didn't think it was too bad.
Then saw the rear, man, I'm glad I fixed it now. Probably would have imploded at the Fest.
Discovered my driver's side parking brake decided to implode, blah!
All is well now though.
Plan for tomorrow:
New windshield cowl
New lower window seals
Newish door seals
Newish window trim
New rear bumper styrofoam support
Major detailing
Turbo Build Here
Old 08-24-2012, 05:58 PM
Needs Boost
Mein Auto: Red Sled
Bimmerfest prep:
New quarter window seals, along with new used door seals, and window moldings.
Also put a new windshield cowl on.
Set tire pressure
Packed detailing supplies, oil, coolant, microfibers, car charger.
What am I missing for the show? Pretty stoked!
Turbo Build Here
Old 08-24-2012, 06:17 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Such an awesome car....
1998 BMW 328is
1966 Pontiac GTO
Old 08-24-2012, 06:28 PM
Needs Boost
Mein Auto: Red Sled
Shoot, thanks Karl!
Turbo Build Here
Old 08-24-2012, 06:50 PM
ZeGerman's Avatar
Warm Leatherette
It's well deserved. You've put a ton of work into that car, made smart decisions about your mods, and the net result is excellent.
1998 BMW 328is
1966 Pontiac GTO
Old 08-24-2012, 06:53 PM
Needs Boost
Mein Auto: Red Sled
Except I did them all in the wrong order...lol.
Boost
Interior
Suspension
Brakes
Throw in maintenance between boost and the rest haha.
Turbo Build Here
Old 08-24-2012, 07:07 PM
yeah, umm....i'm just gunna park in teh back....
that looks soooo super dooper!!
unfortunately i have not really had time to do much to cadence. i washed her (maybe the 3rd time this year...) for bfe, but really, have been too busy with stuff and junk to pour into much of a detail for her. i mean, i drive her. hard. reeeel hard. whenever i can. she's got a lot of dings in her, scratches, and whatnot.
but all 3 shades of her arktisgrau are clean (ish) now, so y'all will be able to see her in pretty much her finest.
we'll see what the trip down has in store for her...
df
Old 08-24-2012, 07:09 PM
Needs Boost
Mein Auto: Red Sled
Wait until you see what the PO did to my hood, yuck.
Turbo Build Here
Old 08-26-2012, 09:26 AM
DEATH2000's Avatar
DEATH2000 DEATH2000 is offline
Mein Auto: 1998 BMW E36 328i,
I dont see anything wrong with it in the pictures. Is it paint related?
ProjectTechnik.com - Alberta based BMW Community
See My car on Project Technik HERE!
| OE M3 Bumper | M3 Mirrors | Jim Conforti CF CAI | UUC Motorwerks Underdrive Pulleys | 18x8 ASA AR1's | Koni Sport Springs & Shocks |
Founding Member of the Canyonrot Club! #343!
Old 08-26-2012, 12:32 PM
cj.surr's Avatar
some kid
I saw the car in person and I don't know what he's talking about.
-CJ
Old 08-26-2012, 07:49 PM
this...
df
Old 08-26-2012, 08:05 PM
Needs Boost
Mein Auto: Red Sled
Haha, it's hard to see outside, inside you can see some really bad bodywork by the PO.
Turbo Build Here
Old 08-26-2012, 10:14 PM
Hellawut??
Mein Auto: who knows?
this car is so ugly and slow. idk why people like it do much
Trooolllololololllll
-Franklyn
Old 08-27-2012, 04:52 AM
Needs Boost
Mein Auto: Red Sled
Lol
Turbo Build Here
:3
