E36 (1991 - 1999)
Old 12-05-2013, 02:50 PM
Byrne Coatings Byrne Coatings is offline
Custom Coater
Mein Auto: 2005 BMW 325I Sedan
Originally Posted by FenderBender View Post
Thanks Ken! Engine bay still has a good bit of work to be done, wrinkle black powder coating on the piping, clean everything, move a few wires, etc.
Hey man if your interested in some powder feel free to hit me up anytime.
you can check out some of my work at www.facebook.com/byrnecoatings
Christian
Old 12-05-2013, 03:27 PM
B_Rad_M3's Avatar
B_Rad_M3 B_Rad_M3 is offline
I6 feels good
Mein Auto: POS
Hellrot Turbo Build
Christian
He does his own powder coating
Old 12-05-2013, 05:03 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
I'm glad you are going to use black wrinkle powder coating on that. I was going to make that suggestion. It'll look awesome.
1998 BMW 328is
1966 Pontiac GTO
Old 12-05-2013, 06:01 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Re: Hellrot Turbo Build
Christian
Where are you located? I can't fit one of my pipes in my oven.
Thanks guys. Got my rallyroad gauge pod. Thing is awesome. All metal construction, fits perfect. The BEST gauge pods you'll get.
ID:	411133   Click image for larger version
ID:	411135   Click image for larger version
ID:	411136   Click image for larger version
ID:	411137   Click image for larger version
Turbo Build Here
Old 12-05-2013, 06:31 PM
ZeGerman's Avatar
Warm Leatherette
Perfect gauge placement.
1998 BMW 328is
1966 Pontiac GTO
Old 12-05-2013, 06:40 PM
Needs Boost
Mein Auto: Red Sled
I honestly am super impressed with the whole setup. Zeitronix data logger and gauge setup is awesome and the rallyroad gauge pods could not be nicer. These gauges can have two parameters each, plus you can add other gauges plug and play.
I'll be getting the little square display with 4 additional parameters and fitting it to the sunglass holder area I believe.
I'm planning on boost, AFR, intake air temp, oil and water temp, and oil pressure. I may add EGT as well since the manifold has the bung. I'll also tap rpm and tps for data logging.
Turbo Build Here
Old 12-05-2013, 06:47 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Double AFR gauges? Baller. How come you need two since you have a downpipe where all of the cylinders are collected?
-CJ
Old 12-05-2013, 06:48 PM
bimmer claus's Avatar
bimmer claus bimmer claus is offline
Santa
Mein Auto: 95 M3
Hellrot Turbo Build
Great work Matt looks terrific I love the rabbit ear setups looks so clean. Wrinkle black in the engine bay is always a win looks so cool. How good are you at powder coating? ;D
Lots of junk.
Old 12-05-2013, 06:49 PM
Needs Boost
Mein Auto: Red Sled
They're not double lol. I can make the gauges read whatever I have plugged into the zeitronox box.
Each gauge can have two parameters. I'll have these set at boost and AFR for now.
Turbo Build Here
drivinfaster's Avatar
Mein Auto: rescued bmw's
yeehaw!! looks like a lotta tech there, matt. is all of this datalogging for custom tuning?? will you be able to tune as you go along with this??
never have played with tunes before, but it's similar to jetting a carb and timing the distributor and adjusting the advance mechanisms (hey, at least i didn't say set the points........i'm not *that* old....)
anyway, digging this thread, and as soon as i am able to get some cash together (which will probably be sometime in january at the earliest) i will touch base with you regarding your guages you mentioned selling. if you sell them before then, so be it. i have certain obligations that need to be addressed (happens with things like mortgages and whatnot...) so i have to budget my 'play money' wisely.
df
Old 12-05-2013, 07:01 PM
Needs Boost
Mein Auto: Red Sled
I'm OK at coating I suppose. I don't have an ideal setup but it works.
df
Yes, data logging for tuning plus it's soo much cleaner and easier to hook up gauge wise.
I can get a little black box with an SD card to record info, or plug a laptop right in and see and record live data.
I will start fiddling with tuning but I need to do a LOT of research and reading first. Miller base tune shoukd be close and safe.
Turbo Build Here
Old 12-05-2013, 07:33 PM
well, if you ever need to do 'research' and need a driver....
df
Old 12-05-2013, 09:38 PM
cj.surr's Avatar
some kid
Oh that's sweet! So the actual background changens? It's a completely digital display?
-CJ
Old 12-06-2013, 08:07 AM
Custom Coater
FenderBender,
I am located in Bergenfield NJ. If you want You can ship your stuff to me if its too far for you. I get a great discount with UPS through my other company so I pass those savings on to my powder customers. What I usually do is email a shipping label to the customer and add the discounted shipping to the final invoice.
My oven is 6'6" x 4'6"
Let me know if your stuff will fit.
Christian
Byrne Coatings
27 McDermott Pl.
Bergenfield, NJ 07621
201-477-0079
cjbyrne@byrnelogic.com
Old 12-06-2013, 08:31 PM
Needs Boost
Mein Auto: Red Sled
Kinda. The center display is digital and can show anything. The other numbers are permanent but can show boost, AFR, etc.
FenderBender,
Christian
That should fit. I'll keep you in mind.
Turbo Build Here
Old 12-13-2013, 04:01 PM
Needs Boost
Mein Auto: Red Sled
Drove her around a little, I think it's making about 11psi on a 9psi spring, which is GREAT! especially since I have only a downpipe, no other exhaust. Feels fast, but I didn't get into it a whole lot, spun 3rd gear. I did finally get to clean it up.
Untitled by fender13bender, on Flickr
Turbo Build Here
Old 12-13-2013, 05:48 PM
cj.surr's Avatar
some kid
I'm stoked for you dude! Looking great! Glad you aren't getting any boost creep. What manifold were you using again?
You're gonna want get a hose on that CCV before you give your intake an oil shower, though
-CJ
Old 12-13-2013, 07:52 PM
hornhospital's Avatar
D'oh, You Kids!
That car gives me high blood pressure, if you get my meaning (nudge, nudge, wink, wink).
Sent from my MB860 using BimmerApp mobile app
Quotes to live by:
Old 12-13-2013, 07:55 PM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: A redhead E90
i can't even imagine how insanely powerful this car is going to be.
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '06 325xi 6MT
Old 12-13-2013, 08:33 PM
Needs Boost
Mein Auto: Red Sled
Thanks gents!
CJ, it's a custom twin scroll tubular T4 I got used off bfc.
Turbo Build Here
Old 12-15-2013, 05:10 AM
Santa
Mein Auto: 95 M3
Hellrot Turbo Build
So sexy man. Love it.
Lots of junk.
Old 12-15-2013, 08:23 AM
dwonda's Avatar
dwonda dwonda is offline
Insane in the membrane!
Mein Auto: 1996 328iS
Looks really really really good! You should replace that centre arm rest though, looks gross. I've never really understood those colored hooks I see everyone putting on their cars, and I noticed you put a hole through your removable bumper trim flap. I see a lot of honda civics driving around with them mounted somewhere under their rear bumper. Whats the purpose of this? Why not just use the included hook in the tool kit whenever you need to use it instead of having a fancy one mounted at all times? Other than that I can't wait for you to dyno this car, you are going to dyno it right? Also have you decided to just not use an air filter, or is that still coming? Looks great man!
Old 12-15-2013, 11:49 AM
Santa
Mein Auto: 95 M3
Hellrot Turbo Build
He has a screen filter on the turbo because of clearance issues. He's had that two hook on there for as long as I remember. I don't mind it. Because racecar.
Lots of junk.
Old 12-15-2013, 01:33 PM
D'oh, You Kids!
I believe that armrest is covered in Alcantara, a fabric that is supposed to give all Bimmerphiles instant wood. I don't care for Alcantara myself. It's grossly overpriced CLOTH, but in this case it doesn't look bad. It certainly doesn't look "gross".
Quotes to live by:
Old 12-15-2013, 02:22 PM
Needs Boost
Mein Auto: Red Sled
Gross? Interesting. I do want a new armrest and boot covers though. It will be dynoed eventually. Hooks are there for when I track the car.
Yes
I may get leather again, I dunno.
Turbo Build Here
:3
