Old 12-27-2009, 11:05 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Strangest thing: My automatic door locks stopped locking automatically! :)
I never thought I'd be asking this question!
What "thing", if broken, makes the automatic door locks NOT lock automatically (when they are actually set to lock automatically)?
I know that sounds confusing so let me explain:
- Since I bought my 2002 BMW 525i, all 4 doors always locked automatically at about 5mph
- I know Carsoft will unlock "something" in a computer somewhere but that hasn't been done on my BMW
- Suddenly, as of about last week, the 4 doors no longer automatically lock!
Note: Yippee!!!! But, huh? How did that happen?????
- Everything else related to the locking seems to work fine (i.e., I can unlock all four with one click of the center-console button or two clicks on the diamond key fob).
A while ago, I did test the manual unlocking of the trunk and side doors based on a recent trunk unlocking thread; and my trunk loom wires are a shambles ... but neither is known to have any effect on the autolocking of the doors!!!! ????
I'm actually happy the auto lock is 'broken' ... but now my curiosity is rising.
Obviously something is actually "broken" ... but what physical "unit" or "thing" actually controls all four door locks auto locking?
Old 12-27-2009, 11:14 PM
peekaytoo peekaytoo is offline
Account Under Review
Mein Auto: 1er
Did you suddenly, as of about last week, begin using the spare key, instead of your usual key? The key memory is specific to each key, and each can have different settings with regards to auto door locks (among other things).
Old 12-29-2009, 02:37 AM
bluebee's Avatar
I have only two keys and I didn't switch them. But, just as a test, I did switch them today and nothing changed. The automatic door locks now (thankfully) don't lock when I start moving.
I always was (and still am) skeptical when people tell me the automatic door-lock memory is in the key because Carsoft reputedly can change it yet Carsoft has nothing to do with the key.
Is there any "proof" that the automatic door lock is stored in the key?
Old 12-29-2009, 04:26 AM
franka franka is offline
Mein Auto: E39 540i Sport
Be glad that your locks have not yet locked you into the car.
Frank
540/6
540, Dirrezas (4) @ 275/35-18 ea, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy
Old 12-30-2009, 07:54 AM
bluebee's Avatar
I see what you mean. More lock-related electrical gremlins are popping up.
Yesterday & today the trunk wouldn't open with the key or with the underside lid outside handle.
I had to manually use the key to unlock the trunk (turning left in the key slot).
I think it's time to fix the wires in the trunk loom during my vacation!
Old 01-08-2010, 12:08 PM
bluebee's Avatar
Unfortunately, the trunk loom wires must've shifted ... that blasted autolocking ... it's back!
Old 01-08-2010, 12:13 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
Replace the loom ASAP before things get worse, and you have more serious issues. It is my understanding BMW sells a replacement loom. I have been shooting a bit of silicone spray into the rubber sheath every 6 months or so, on the presumption a little lube we help prevent the wires from binding up, twisting and breaking.
I don't believe you can fix this by simply repairing the breaks in the wires...there are probably multiple wear points and strands already broken under the sheath...so you fix one place, and it will eventually break in another.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, M5 rear subframe braces, H&R 15mm wheel spacers, ST X (KW) coilovers, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 01-08-2010, 01:47 PM
bluebee's Avatar
I tried that route. Maybe I gave up too soon, but, the part number wasn't obvious to me. Sure I can find the diagram in realoem but when I called two different BMW dealerships, they had no idea what I was talking about.
They said nobody buys the loom. I concluded (perhaps erroneously) that people must be successfully soldering them. Bear in mind that nobody on the wiring loom thread has replaced the loom and LOTS of people have this problem ...
But, cost being not too high, I'd vastly prefer to replace the whole loom.
Seems like a good plan. It's almost like the ABS control module where prophylactic care (by rebuilding it even when it's still good) is what is needed more than any use model.
I don't believe you can fix this by simply repairing the breaks in the wires...it will eventually break in another.
I don't disagree ... but see point #1 above which precludes that option ...
Old 01-31-2010, 08:51 PM
bluebee's Avatar
I just belatedly realized, based on information in this post, that the real reason my automatic door locks (thankfully) stopped locking (albeit temporarily), was because the ABS was off the car at the time.
I didn't put it together until now, but, when I sent my ABS out for rebuild, it was just about then that the automatic door locks stopped locking (I loved it!).
Now automatic door locking is back (ugh!) and I think it's because my ABS module is back in the E39.
Mystery solved!
