7 Series / 8 Series
The BMW 7 series and 8 Series Forum |
Heat/air issue, and door won't close in cold
Hi guys I have 2 major issues going on with my 1998 740IL
1. Even though the temp Knob in dash is on cold ( Blue) when ever feet/upper button is pressed I still get hot air coming out, sometimes I get hot air coming underneath the seat. So After playing around I have either user auto or straight button ( air would come straight to your face) in order to over the heat issue. Since its winter I don't mind it is big problem in winter. Also sometimes I get only cold air if straight to your face button is pressed so I have either use feet or upper button to get heat. 2. Driver side door is not shutting down when it is really cold , I have googled it but not found a satisfactory solution. Some say use UD-40 or silcion base solution which I have but it didn't work. Any suggestions or do I have change my latch. Thanks |
for the cold air in the face make sure the adjuster on the dash is rotated towards the red more than the blue.
i have also had a problem with driver side door not latching. i used a dry lubricant called poxylube and it worked great. sprays like wd-40 will give you problems later as it tends to collect dust and dirt. hope this helps. |
| Bookmarks |
| Tags |
| door lock, heat |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
