The X5 SAV Forum
Old 06-15-2006, 02:45 PM
toddbright toddbright is offline
Mein Auto: X5
electrical issues help needed
OK I have searched through this site and have not seen anything like the problem I have. My 2002 X5 3.0i is having major electrical issues. Most of the time when I start the car all of the displays freeze (the radio and the electronic cluster). None of the controls on the steering wheel work and the radio will eventually shut it self down and the display will go out. However, if I continue to mess with the seat memory and change it between two different memories it will work itself out and all the warnings will come back on line and the radio will come back on, then it will freeze up within a minute or so again. Anybody had this before or know of any suggestions to fix this??
Old 06-15-2006, 02:55 PM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 535i M Sport; Twin X1's
How old is the battery? Amazing how many electrical problems can stem from lo voltage and a bad battery.....
Current BMW's:
2014 535i MSport Space / Black, ZCW, ZDA, ZLP, ZLS, ZPP, H-K and 704
2015 X1 28i xDrive Alpine / Black, xLine, ZCW and Ultimate
2015 X1 35i xDrive Black / Black, ZCW, Ultimate and Xenons
Prior BMW's
2014 328i SportWagon
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Technic
Old 06-15-2006, 03:01 PM
chuck92103's Avatar
chuck92103 chuck92103 is offline
Banned
Mein Auto: 2005 BMW 645Ci
I have learned just to replace the battery at inspection II/4 year mark. I stopped waiting for them to go bad at the most inconvenient time.
Old 06-18-2006, 09:52 AM
Mein Auto: X5
I just put a new battery in in January and it's been doing this for the last couple of months
Old 12-16-2009, 11:34 AM
breilers breilers is offline
Mein Auto: x5
I have a 01 x5 with similar electrical problems. I also just installed new OEM battery. Todd, Did you ever solve your electrical problem. My car is at dealer now. They are having hard time with problem. Serv. tech mentioned something about the cluster..and ordering a new one. Please help!
Old 12-16-2009, 12:36 PM
albie albie is offline
Mein Auto: x5 3.0 i sport/328i mtec
hi,you might want to check the main earth point on the car,iv seen 3 cars in the last year with similar probs to yours and the earth has been the problem,good luck
Old 12-16-2009, 01:14 PM
Mein Auto: X5
Actually all I did to solve the problem was move the steering wheel up. I was sitting with the steering wheel at the lowest possible point when I was having all those problems. Now I just don't put the steering wheel down that low and I have not had any problems with it in more than 3 years! I'm sure there's still some issues there as I bet that when the wheel was so low there was some sort of connection issue. Good luck!
Old 12-29-2009, 11:37 AM
careykirk careykirk is offline
Mein Auto: 330i, X5
What is the earth point?
Old 12-29-2009, 12:33 PM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
Earth = GROUND
Old 12-29-2009, 05:12 PM
Mein Auto: x5
Thanks for the responses. The problem was fixed after the dealer replaced the slip ring in the steering column. for anyone have similar problems the part # is: 61-31-8-379-091. Cost for part @$155.00
Similar Threads
electrical nightmare!!! kal530 E39 (1997 - 2003) 7 03-05-2006 06:22 PM
E46 issues eston E46 (1999 - 2006) 14 02-25-2006 10:25 PM
Electrical woes!!!!!! dbaril E34 (1989 - 1995) 1 09-28-2005 04:31 AM
Electrical Help! BC530i E60 / E61 (2004 - 2010) 5 07-20-2005 04:35 PM
325xi - E46 Body - Manual shift issues JSKSug E46 (1999 - 2006) 1 04-28-2005 12:29 PM
