Old 12-29-2009, 09:15 PM
Softhands Softhands is offline
Mein Auto: BMW 530i 2003
Unhappy Code P2096 Post Catalyst Fuel Trim System Too Lean Bank 1
I drive a 2003 530i BMW with almost 100k on it, this is what has been happening. The car drives great, but sometimes I do get a bit of a rough idle first thing in the morning; other than that it drives real nice.
I first got smacked with three codes P0303 Misfire Cylinder #3; P0420 CAT Efficiency Bank 1; P0133 O2 Sensor Bank 1. I apparently fix those issues because I no longer get these codes.
However after replacing the two Pre CAT O2 sensors my SES light went away by itself, then came back with a P2096.
So then I replaced the Post CAT O2 sensors and my SES light, again went away by itself, but it came back like the first time. I am not sure if it will come back, but based on previous experience with this code it likely will.
What can it possibly be that it recorrects itself and it comes back. Better yet does any body know what I actually need to fix. I will be going on a trip tomorrow so I hope it drives okay.
Old 12-29-2009, 09:22 PM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/Stick Blown
Do you still have the misfired code? If you do you should check for rubber boots cracks, vacuum leak, and coils.
Old 12-30-2009, 09:05 AM
Max_VQ Max_VQ is offline
Mein Auto: E39 with a sweet six
Interesting code... It implies that the rear O2 does more than we think.
Check for any cracks in the exhaust system. They can let unwanted air into the exhaust and cause a false lean condition. Remember Lean means too much air.
We should also look at the rear O2 sensors. Once the car is warmed up, measure the rear O2 voltage. If you have an OBD-2 scanner (I use obd-2.com $122 & laptop) with live data then it is easy. If not, then I hope you have a meter and know how to read a wiring diagram.
If no to both, I think your best bet is to take the car in and have a pro look at it.
After idling for 1-2 minutes the rear O2 should be around .6 volts. See attachment.
Do you have access to an OBD-2 scanner that supports live data? (mode $01)
Old 01-02-2010, 02:12 PM
Just got back from my 1200 mile trip and overall the car drove nicely with no apparent problems. Did have to put a quarter of a cup of antifreeze, otherwise the car took real good care of use. However I did eventually get that P2096 code back, and it stuck with me thru out the entire trip. The reason I know is that I took my scanner.
However for a short period I did get code P1346, which is a misfire during start Cylinder 3. However once I erased it it never came back so I am not sure what this means other than it appears to be a one time thing.
It is the second time in a couple of months that my scanner mentions Cylinder 3.
For those who asked or are wondering, no other codes have reappeared, and a few weeks ago did have new spark plugs (6) installed and had Cylinder 1 and 3 removed and replaced with new boots.
Will check to see if I have any exhaust leaks in hopes it removes this P2096 code. However is there something I can use to find a small exhaust leak ?
I also do not have a scanner that can be used with a laptop.
This P2096 code is a pain to get rid of.
Old 01-02-2010, 04:33 PM
300B 300B is offline
Mein Auto: 02 525i
Clean or replace your MAF.
Old 01-02-2010, 05:58 PM
My next step would be to look at:
(1) Long term and short term fuel trims
(2) Pre & Post O2 sensors (I know you changed them, but they will tell us what is going on)
The #3 misfire is a clue. The fuel trims will tell us what is going on in bank 1.
I don't think it is the MAF, since the problem is on bank1 and the MAF is connected to banks 1 & 2.
I am thinking your scanner does not support live data, so unless you buy or borrow one I don't know how else to help.
Old 01-02-2010, 06:32 PM
Okay can someone tell me what a fuel trim is and looks like. Is it the fuel rail? Also what should I look for when removing the new 02 sensors I recently replaced? I will clean the MAF, seems to be a simple thing to do. I guess there is no way of checking a exhaust leak without getting down underneath and getting lucking in finding this possible leak. I say it is small since I do not hear any difference in my exhaust before I got this P2096 code. I did get this code after replacing pre 02 sensors, bank 1.
To clean a MAF what should I use? I've been told to stay away from the sensor unless I am using rubbing alcohol. Is this correct?
Old 01-02-2010, 06:50 PM
Good question.
To see the fuel trims you need an OBD-2 scanner that supports live date (mode $01)
LongFT_1 = Long term fuel trim bank 1
ShrtFT_1 = Short term fuel trim bank1, etc
They indicate how much fuel is being added (+ fuel trim) or removed (- fuel trim) from the base fuel map/calculation. This allows for normal wear and tear.
Fuel trims should normally be in the range of -10 to +10.
See attached pic for graphic.
There is no need to remove the O2 sensors. The easiest way to see what they are doing is using live data from an obd-2 scanner.
If you plan on keeping your E39 for a while and like to repair it yourself, you will need some kind of OBD-2 scanner. (CarSoft is also good, but more $$) They will save you lots of money!!
Old 01-02-2010, 07:18 PM
Should I use rubbing alcohol to clean the MAF?
Old 01-02-2010, 11:14 PM
I don't think cleaning the MAF will make any difference, but if you want to clean it you must only use a proper MAF cleaner. Anything else can leave a residue and cause the MAF to under/over read the air flow.
Google MAF cleaner for options...
Old 04-04-2013, 10:57 AM
onevicious onevicious is offline
Mein Auto: 750il
I have had this code P2096 on my 2003 e39 525i for almost a year. Frist showed up with P0313 which is a misfire code. did a lot of reserch, exhust leak, short in O2 heater circuit. I then cleared the codes. the P0313 went away, but the P2096 was a real pest. Hooked up ODBII reader with real time info. Code PO2096 starts to read when the O2 heater circuit becomes ready. All O2 sensors read within tolerences. Turn out that the Problem was the freakin' "Master Air Flow Sensor" Changed it and all codes are gone and car is running great. I was feeling some slight hesitation in acceleration when getting on highway, that is gone also. I know it is an expensive sensor, don't try cleaning it change it as it may be to far gone for just a cleaning.
Old 03-13-2015, 02:49 PM
p2096 2003 BMW 530i
I have been getting the same code for a while and replaced the MAF and the same code is still coming back on. Any suggestions? BTW I also changed out the O2 sensors and checked with a carb cleaner for any vacuum leaks.
Thanks.
Old 03-13-2015, 03:41 PM
Mein Auto: 750il
Found.out that there is a service bulliten for this code, P2096,P2098. Lucky my code went away, but stealershiphave to service the code if vehicle is under 100k that is the lengh of the emissions warranty
Old 12-16-2015, 11:41 AM
Mein Auto: 750il
P2096/2098Final Solution
Code eventually came back September 2015, had to take car to dealership, and they reprogramed the DME as described in the service technical bulletin. Save yourself hundreds by not trying to replace parts to clear this code. cost of reprogramming 230.00 cost of wasted money and time on replacing parts well over two grand. what a waste.
Sad part is I had to inform dealership about the bulletin!!
Old 12-16-2015, 12:00 PM
MKJS MKJS is offline
Mein Auto: '99 540iA
Can anyone recommend a book on fuel trim, maf's, O2 sensor voltage interpretation, etc? "Diagnostics for Dummies?" I'm from a carburated world and understand the basics but the new language and data is unknown to me.
Old 12-16-2015, 02:32 PM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
there is a series of diagnosis videos with good explanations in this group of them
also en ex carburetorista so im going thru the same transition as you
99 528i 5sp sport
Old 12-16-2015, 02:33 PM
Thank you. Thank you. Thank you!!
Old 02-02-2016, 08:26 PM
cirishmn cirishmn is offline
Mein Auto: 2002 BMW 325i
K&N sh*t
Just spent 2 months chasing down this problem, hesitation on acceleration, along with p2096, p0171, p0313, and a few other misc codes...fuel pump fixed all but the p2096, a wix air filter and a MAF cleaning solved that....Goood luck....
Old 08-29-2016, 12:53 PM
ramp ramp is offline
Mein Auto: 635csi, MGA, e39
It looks like my turn at this mysterious code. 4 new o2 sensors, Checked for vacuum leaks, replaced fuel filter was original, cleaned MAF. Car runs fine. I clear the code and can drive for hours. Once I restart in about 5 minutes the code comes back. I don't want to just replace the MAF. Car has 142000, 2002 525i.
Old 08-29-2016, 02:46 PM
MAF, 02 sensors, these are parts with a limited life. Seems like around 150-180K or so, they should be replaced anyway to keep the car running optionally.
Jim
Old 08-29-2016, 06:19 PM
Burning2nd's Avatar
Under the lift arms
I dont buy in to that, Ive got 2 with 200k on them... and never a maf related code Also o2's ive never replaced them... never had a code that reflected anything to do with them... If i had.. they would be changed... efficiency codes are not out or range code
15486372<-----
Old 08-29-2016, 06:26 PM
HolyToledo HolyToledo is offline
Mein Auto: '02 530i Toledo blue
Just because they don't throw a code doesn't mean they're up to snuff tho. My o2 sensors and maf were in bad shape without throwing any codes. Night and day difference after I replaced maf and pre cat sensors. Long term fuel trims were barely acceptable and the car ran like crap. Maf reporting wrong values caused some funny shifting too.
Old 09-05-2016, 10:08 AM
Well I hate to just replace the MAF without evidence of it being the culprit. But I am at the end of the line.
1. Vacuum lines replaced. Smoke test without evidence of leak.
2. New Fuel filter
3. Front and Back oxygen sensors.
4. New spark plugs.
5. Ran some Seaform in the gas.
6. Checked exhaust for leaks. Nothing apparent.
The car runs great. Clear the code and drive without it coming on. Next time I go to drive the car with in 5 miles the code comes back but still drives fine.
Suggestions on what is the best MAF to buy? They seem all over the place from real cheap knock offs to the $300 BMW version.
Old 09-05-2016, 02:38 PM
Siemens/vdo one is a bit cheaper, but oe quality.
Old 09-05-2016, 06:54 PM
Thanks, just ordered!
p02096; rough idle;
