Old 01-01-2010, 10:04 PM
Alexbenz Alexbenz is offline
Mein Auto: E30, Es300, benz-sold
--How to remove trunk tool kit?
i need to remove it completely.. i took off the front black piece and the rest of the clips off but how is it held in from the bottom of the tray? i tugged on it a little bit but nothing...
Old 01-02-2010, 09:10 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Dunno. But, this reference to an E39 trunk lid replacement DIY implies that only two screws hold down the tool kit.
"Letís begin. First remove the trunk liner. You can use a flat head screw driver to lift the pushpins. Then simply pull them out with your fingertips. This is a two piece push pin, so the center top piece needs to come all the way out fist then the base comes out. Also remove the toolkit which is held down by 2 screws on each end imbedded into the carpet."
