Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 01-03-2010, 12:29 PM
Marine5302 Marine5302 is offline
Heading south in 2016
Mein Auto: 2009 335d
Diesel fuel lubricity additives
Attached is the 2007 study regarding lubricity, or lack thereof, in ULSD. It's been posted in every other diesel forum so I thought we should have it here as well. It concludes with what the author found to be the best to the worst. Worst being what they found to cause worse scarring than baseline diesel fuel. As I stated in a prior thread, it's up to each owner to decide whether a lubricity/cetane improver is right for their car/SUV.
Saepius Exertus, Semper Fidelis, Frater Infinitas
Often Tested, Always Faithful, Brothers Forever
Better to live one day as a Lion than a hundred years as a Sheep
Old 01-03-2010, 01:00 PM
anE934fun anE934fun is online now
Mein Auto: 2010 335d
I had seen the study in my research, but then neglected to bookmark the url. Thanks for posting it here.
The conclusion that I came up with for my own fueling practice is that since U.S. ULSD production lubricity must conform to a maximum wear scar of 520 microns, going with Powerservice and its relatively paltry 60 micron improvement would still get me to a 460 micron target. As I have posted previously, what is compelling about Powerservice is its wide availability.
Old 01-03-2010, 01:11 PM
I also went with PS due to it's availability and, as you alluded to in another thread, it's widespread and longstanding acceptance in the diesel community. Hopefully, most of the "D" members will read and save.
Old 01-03-2010, 03:22 PM
d geek d geek is offline
diesel evangelist
Mein Auto: vw diesels + MB e300D-T
i can't post images for some reason, so i hope its OK for me to just supply a link to a thread i started on tdiclub regarding diesel lubricity. the data i was able to obtain showed that Power Service increases lubricity on pump diesel by 170 micron (as opposed to the untreated diesel that the Spicer tests were run on)
http://forums.tdiclub.com/showthread.php?t=196059
Old 01-03-2010, 05:04 PM
Grentz's Avatar
Grentz Grentz is offline
BMW d Driver
Mein Auto: e46 M3, 335d
Why is this needed if the d was designed for ULSD?
Old 01-03-2010, 05:12 PM
diesel evangelist
it comes down to the difference between the ULSD sold here in the US and that of the rest of the civilized world
All ULSD needs lubricity additives. Somehow the regulators here in the US decided that the fuel sold here did not have to be as additized as the fuel injection manufacturers mandated.
Old 01-03-2010, 05:24 PM
Glad to see the VW diesel guys have been discussing this issue as well. Seems like a lot of you guys supporting the pro-additive posture due to the Spicer paper and elsewhere were vindicated even more so after the Bosch report. I've read in a number of places that lubricity additives are added at the terminals yet there is no standard/minimum etc. d geek, have you heard/read the same?
Old 01-03-2010, 05:35 PM
diesel evangelist
please read the thread i linked to for a full discussion. the problem is that all though there is a standard in the US, but it is not as high a standard as ALL the fuel injection manufacturers have designed their systems for. US fuel allows 520 micron wear scar with the HFRR fuel test, but the maximum wear allowed by Bosch and other designers is 460 micron. this means that the internal pump components that are only protected by the fuel are allowed to wear at a much higher rate. the big unknown is what this will mean in terms of service life for the HPFP (whatever technology is used): no one knows if it will be 100K miles or 300K miles difference.
Old 01-03-2010, 05:39 PM
Thanks for the clarification.
Old 01-03-2010, 05:41 PM
DC-IT DC-IT is offline
Love my Diesel Vehicles
Mein Auto: 335D, ML350BT, Jetta TDI
Hmmm... here in Toronto, Walmart does not carry PowerService Diesel Additive products.
Only one I can find is Prestone Diesel Fuel Treatment.
Walmart Canada
Will this do the job?
DC-IT
Old 01-03-2010, 05:43 PM
diesel evangelist
here's another link that may be of interest:
http://www.bosch-kraftfahrzeugtechni...ement_2009.pdf
Old 01-03-2010, 05:45 PM
diesel evangelist
in Canada, you do not need to worry about lubricity. Canadian standards for lubricity match those of Europe.
Old 01-03-2010, 05:53 PM
Thanks d geek.
I only refuel with Shell V-Power Diesel so I guess that should keep my D happy.
DC-IT
Old 01-03-2010, 08:17 PM
Fredric Fredric is offline
Mein Auto: '07 328xiT
I have a friend who complains that his g/f doesn't lubricate as well as she used to, and they are both getting worn out. Should I recommend Powerservice to him?
Old 01-03-2010, 08:25 PM
Stugots's Avatar
Stugots Stugots is offline
Speed Demon
Mein Auto: '10 335d E90
I'd lean towards Astroglide.
Old 01-03-2010, 11:05 PM
Norm37 Norm37 is offline
Mein Auto: Chevy half ton pickup
Interesting thread. I have wondered about Lubricity of 10% aclohol gasoline and all the HPFP failures on the N54engine.
I started a thread in the general forum (HPFP failure rate in Europe vs USA)
Hopefully somebody can sumerize the link in that thread on "LUBRICITY of GASOLINE"
Not wanting to hijack this thread with answers on gasoline. Here is a link to the thread I started.
http://www.bimmerfest.com/forums/sho...d.php?t=423168
Old 01-04-2010, 05:54 AM
CALWATERBOY's Avatar
CALWATERBOY CALWATERBOY is online now
Mein Auto: 2009 E93 N54
In Europe, biodiesel @ 5% is used for lubricity. BMW designed w/same.
What's used in Canada?
Old 01-04-2010, 07:48 AM
diesel evangelist
Biodiesel is a great lubricity additive and is what i use for my VW's when i am not out of my local area. B2 (2%) biodiesel is sufficient for lubricity. As mentioned, BMW allows up to 5%. I have B20 available to me, so i put in 3 gal of that and then top off with Amoco premier diesel (min 50 cetane)
Old 01-04-2010, 08:37 AM
Jim E.'s Avatar
Jim E. Jim E. is offline
Mein Auto: 1999 M3 Coupe & 2009 335d
We did discuss this back in November but it was hidden inside a thread. Good idea to make it its own thread.
Old 01-04-2010, 09:28 AM
Jim E.'s Avatar
Here's some good reading about diesel fuel.
Happy reading,
Jim
Last edited by Jim E.; 01-04-2010 at 01:23 PM. Reason: Sorry, can't post the attachment publicly. :-(
Old 01-04-2010, 09:59 AM
diesel evangelist
nice! where did that come from, Jim?
Old 01-04-2010, 10:27 AM
magbarn magbarn is offline
Waiting for the d
Mein Auto: '10 335d
Does this mean without this additive our d's are subject to premature HPFP/injector failure?
BTW is this stuff expensive?
'10 335d Monaco blue/oyster/SP/PP/Enhanced Premium Sound/nav from phillipek SBBMW
Click Here for Pics!
Old 01-04-2010, 10:41 AM
diesel evangelist
not using an additive does not guarantee failure, but the risk does increase.
not expensive: <$1/tank.
Old 01-04-2010, 10:49 AM
Jim E.'s Avatar
This is info from BMW
Old 01-04-2010, 11:09 AM
diesel evangelist
Originally Posted by Jim E. View Post
This is BMW technical training material.
very cool. can we see the whole thing?
are you a dealer tech?
HTML code is Off
