Old 01-05-2010, 09:24 AM
rayman1086 rayman1086 is offline
Mein Auto: BMW 520i
That really grinds my gears!!
I have a 2000 e39 520i manual 5 speed, It popped out of gear during gear change and when I tried to get it back in it grinded, it eventually went back in but drives fine it hasnt popped out since but in first and reverse gears there is a low whining noise, Have i destroyed the pressure plate or the teeth/splines on the gears? Any help would be great guys!
Old 01-05-2010, 09:45 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
When did you last change the lube in the trans? If never, try a fill of RedLine MTL or Royal Purple Manual Trans Lube, or another synthetic lube for manual transmissions. Do not use ATF.
Whilst the car is up in the air, replace the diff lube, too, with 75W90.
The factory fill is labeled "lifetime"; don't you believe it.
A few grinds will not hurt the trans.
Old 01-05-2010, 11:52 AM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Send a message via MSN to bmw_n00b13
Mein Auto: 99 528iA
Sounds like a synchronizer got upset. Change the oil, and if there's further problems, you should have the synchronizers looked at.
'99 528i ('98/12 build). 174,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals
'99 540i (grandfather's)
Old 01-05-2010, 12:58 PM
Mein Auto: BMW 520i
thanks so much dude, happy new year!
Old 01-05-2010, 06:42 PM
haolibird haolibird is offline
Habitual User
Mein Auto: E39 540i, E39 M5, E34 535
Whooaa!!
"Talk to me about the "synchronizers"!
My car has been difficult at times to get into gear, typically after a extended amount of time in high gear.
I have a short throw lever, and was blaming that, telling myself "It's not the trans, it's not the trans!!"
I have the MTL product in the box, and it being changed in a timley fashion.
Any light on that subject would be great.
I, in turn, will dazzle you with my oil expertise.
Thanks,
Tom
Old 01-05-2010, 07:10 PM
I installed the E60 545 shift lever, and it feels like I'm arm-wrestling with the trans every time I shift. I may be changing back, since I don't see a real value in this setup.
You may wish to put the original lever back in.
Old 01-05-2010, 09:35 PM
QuoteWarz Insurance QuoteWarz Insurance is offline
Past Sponsor
Mein Auto: BMW
Yes, would definitely get the tranny oil changed out for some fresh stuff, but most likely you have some issue with your synchro.
Old 01-06-2010, 04:15 AM
franka franka is offline
Mein Auto: E39 540i Sport
Looked at?
You can't just ''look at'' the synchros w/o taking the tranny out and apart.
To the OP, a few grinds will not hurt if the tranny still pulls smooth thru all the gears.
Frank
540/6
Dirrezas (4) @ 275/35-18, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy
