The X5 SAV Forum
Old 01-05-2010, 08:16 PM
delish delish is offline
Mein Auto: X5
X5 4.4i 2004 PROBLEMS
Have had the car for 2 yrs no problems reg. oil changes & main. Female & highway driven. Reached 130 km and have been fixing it monthly - rad. hoses, coolent leak, control arm, gas tank issue, now being quoted for VALLEY PAN - over a $1000 to fix. Not to mention that my hood has issues opening and my sun roof tilt is not closing. For those who own an X5 is there more to come? I love my bimmer, but am not sure if its worth it to keep it, I can't go back to anything else! Need advice :o(
Old 01-05-2010, 10:46 PM
bmmer2001 bmmer2001 is offline
Mein Auto: 2010 X5
I had a 2001 X5 for 4 years, had a lot of issues during the warranty period, as soon as the warranty expired, I realized how much it cost to own a BMW. My CAs used to always say welcome to owning a BMW. I was so disgusted that I sold the X5. I loved the car but hated the cost of owning. After almost 5 years, I just recently bought by 2nd X5. Lesson learned from the first one, always get the extended warranty or plan on selling before the warranty expires. Just my experience. Good luck!
Old 01-05-2010, 10:49 PM
Route 66's Avatar
Route 66 Route 66 is offline
Mein Auto: 2001 740i
My valley pan fix was $640.00.
Old 02-01-2010, 10:58 AM
m5james's Avatar
m5james m5james is offline
Send a message via AIM to m5james Send a message via MSN to m5james Send a message via Yahoo to m5james
Mein Auto: 98 740iL - Tweaked a bit
The cooling system is just that, a system. You should have replaced EVERYTHING in one single shot. Now you're seeing the downside of replacing bits and pieces of it since the new parts put more pressure on the older parts.
640hp 10 X5///M, Alpine White/Sakhir Orange - Gutted cats, muffler delete, Eurocharged tune
325hp 98 740iL, black/black - Eatin 540's & $hittin 318's
PERFORMANCE:///M5 6spd swap, Iron sleeves, L/W Teflon coated pistons, 3 angle valvejob, P&P head, cams, electric fan, CF intake tube w/aluminum heatshield, Magnaflow 14816'd
INTERIOR:
Hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D, silver trim, 5% tint
EXTERIOR:19" Beyern Mesh staggered, Shadowline kidneys, Axxis pads
Old 01-05-2011, 10:22 PM
Alfredo2001X5 Alfredo2001X5 is offline
Mein Auto: 2001 BMW X5
True that!!! My waterpump is leaking so I'm also replacing thermostat and the switch.
Old 01-07-2011, 07:32 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
I just did my valley-pan and valve cover gaskets, along with oil separator since I was already there. Let me tell you if there is an indy shop (dealer will be around $2-$3k for all these) like one poster says who is willing to do it under $1k, let them do it; it's a PITA job.
Oh one more thing, my valley-pan gasket was actually OK but the rear coolant manifold gaskets are the ones leaking. The 3 screws on each side were so loose no wonder the coolant was leaking since I don't like the idea of going back to fix these I used Loctite blue on all 6 screws.
Also along the way I also found a leak in one of the vacuum line on top of manifold, After all of that jobs, my car runs smoother and pull harder. I have 2002 4.4i X5 around 70k miles.
GL.
Old 01-07-2011, 11:52 AM
golferjohnm's Avatar
golferjohnm golferjohnm is offline
Mein Auto: '01 540i 6sp '01 X5 4.4
I completely empathize with your situation, but we have over 160,000 miles and the key, IMO is keeping-up with the routine maintanence.
If I had the chance to do over again, which we probably will in the next year, is do like the previous poster stated, purchase the extended warranty.
Got stuck with a new transfer case and ABS module just after the original warranty expired, dang
Over-all, it's just a great, comfortale, safe car that's hard to say goodby to
'01 540i 6-speed, blk/blk, upgraded stereo w/sub, passport, Dice Mediabridge and some cool M-stuff
Old 01-07-2011, 09:28 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
"and the key, IMO is keeping-up with the routine maintanence."
So true, 2002 X5 153,000 miles. MANY ups and downs. At times i wanted to get rid, but i'm sticking with it, my valley pan was $1200 i think i remember that much definitely over $1000, I have the know how, but didn't have the time to fix that But i cant explain why i still LOVE this truck!!! It's going to hurt, but like posted above if you get systems done at once it helps the vehicle stay on the road for longer stretches, keep searching future problems online as well. Good Luck!
Old 01-10-2011, 07:26 AM
1bad540's Avatar
1bad540 1bad540 is offline
all bmw's at 60k miles should have the entire cooling system replaced and hoses, otherwise like others stated you just draw out the process. P.s you make payments or you make repairs, try not to do both.
[SIGPIC]
e39 540i sport, acs type 2's,acs sper pdls,Euroclrs(sold)
e65 745i aw sport,21's aib's acspdls& rf splr(sold)
e46 328i Prem Aw18" 335spt whls(sold)
c5 Corvette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pana rf,nav,xenon,cldweather,20"4.6rims.(sold)
e65 750I aw, sport. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20"rennen forged,tune,exh,intake.
w221 S550 amg,dia white,5%3m tint.20"s63rims,lwrd
e70 3.5 aw.mtec, powdr blk whls.
