Heater does not heat up - Bimmerfest - BMW Forums
Old 01-08-2010, 06:15 AM
guntersr guntersr is offline
Mein Auto: 2003 525i BMW
Hello I have a 525i 2003 and the heat doesnt heat up until you run the temp up to about 80when I put it on 70 the air is warm but not hot....most of the time the air feel luke warm! has anyone else had this problem and what did you do to fix it....The radiator has been replaced and all hoses are good.
Old 01-08-2010, 07:18 AM
KeithS KeithS is offline
Mein Auto: '11 335d, '17 340iGT
Is the temp gauge in the middle? Have you tried adjusting the temp wheel between the center dash vent to more red dots?
Old 01-08-2010, 12:32 PM
Yes the temp gauge is in the middle and the red dots are on three red dots....Do you have any idea what the problem is?
Old 01-08-2010, 12:41 PM
Waveho Waveho is offline
Mein Auto: '07 335xi 6MT 4door
If you are not suffering from cooling system problems (clogged system limiting delivery of coolant to the heater core) then I would look to a faulty FSU (blower resistor); do a search on this forum for FSU and you might find what you are looking for.
'07 335xi 6-spd 4dr, Montego blue
'98 540i 6-spd Sport, Jet Black II(sold)
'92 325i 5-spd 4dr, burgundy(sold)
Old 01-08-2010, 01:36 PM
ashton540's Avatar
ashton540 ashton540 is offline
Mein Auto: 2007 328i
I would consider 70 to be luke warm.. Does your air conditioning work properly?
Blue 2007 BMW 328i
Green 1997 BMW 540i (Sold)
Black 1993 BMW 325i (Sold)
Gold 1993 BMW 525i (Sold)
PSALM 86:12
Old 01-08-2010, 02:15 PM
franka franka is offline
Mein Auto: E39 540i Sport
I too found that you have to crank the temp way past 70 and then it works pretty well.
I also noticed that I have heat in a short distance and short time period. Its warm air before the engine temp gage is 25% up assuming 50% is the straight up, fully warm position.
Wish I had seat heaters.
Frank
540/6
540, Dirrezas (4) @ 275/35-18 ea, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy
Old 01-08-2010, 03:58 PM
No problem with AC it works great......Let me ask you if put it on air circulating in the car or drawing air from outside car makes a difference?
Old 01-08-2010, 05:27 PM
Question:.....Would the coolant ( Not BMW) cause the heat not to be as hot as it should be?
Old 01-08-2010, 06:00 PM
occhis occhis is offline
Mein Auto: 1998 528iA
Seat heaters definitely rock.
Either you are part of the solution, or you are part of the problem.
Old 01-08-2010, 06:04 PM
What brand did you use?
Old 01-08-2010, 08:18 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
guntersr,
Has it always been this way, or just since the cooling system work. OR, since the very cold weather you've been having?
It could be perception, or air in the system, due to a les-than correct system bleed. OR, it may be a failing heater valve. Is the heat the same on both sides, or different? If different, the valve may be bad.
Old 01-09-2010, 08:19 AM
actually noticed it during this cold weather....I live in the Atlanta Ga area.....
Old 01-09-2010, 10:22 AM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Could be low coolant or a locked-open thermostat. Mine has given the open-thermostat symptom a few times...and then it goes away. (Yes, cooling system overhaul is planned, but money and the problem of no garage space get in the way).
As for seat heaters, in both my car and my grandfather's car, I find that the temperature comes up before the seats get warm. They're really nice, but the car's pumping hot air as the seats warm up.
When you put it on the defrost setting, does the air get hot? The computer that controls the heating is highly variable, and tries to make itself as unobtrusive as possible, so it seldom blows noticeably hot air, unless you ask it to.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 01-11-2010, 02:14 AM
bishoOo bishoOo is offline
Mein Auto: Bmw E39 525I
it happened to me twice:
the first time it was due ro low coolant in the car.. found a leak and made an overhaul for the engine coolant system. or you can add coolant every once and a while!
the second time it happened i changed something like a thermostat for the heater it self...
dont know whats the name of that part exactly, but its the part the opens and closes when u switch on the heater. its a heater thermostat i guess!
Old 01-12-2010, 04:36 PM
KTRAXO KTRAXO is offline
Mein Auto: 1997, BMW 318i
I'm havin the same problem , I have noticed that when the temp gauge goes up the heat works ok and when the temp gauge stays down in the blue line it only blows warm air, and I'm pretty sure is the t'stat.
Old 01-18-2010, 05:55 PM
I replaced the t'stat and water pump and problem solved, I also had the engine light on and now is off.
Old 01-18-2010, 06:08 PM
xraye39 xraye39 is offline
Mein Auto: 530i
Who refilled and bled the cooling system? Ya might have an air pocket in the heater core or your thermostat could have failed and be in the stuck open mode.
2003 530iA Sport - Titangrau Metallic/Schwarz Montana
Build Codes: ZSP/ZPP/ZCW. Born on date: 09/02, Dingolfing, Deutschland
| NAV MKIV | PP | CWP | Xenons | Style 42s | Rear Shades | OEM ULF Bluetooth | Euro Armrest | Beisan Vanos Seals |
2003 530i/5Spd Sport - Titanium Silber/Schwarz Montana
| PP | Xenons | Style 42s | OEM TCU Bluetooth | Euro Armrest | Beisan Vanos Seals |
2001 525iA - Anthracite Metalic / Grau Montana
Sold but in the "family"
