Old 01-11-2010, 01:09 PM
Josh P.'s Avatar
Josh P. Josh P. is offline
Bimmerholic
Mein Auto: 2001 530 SP/PP/CWP/Slush
Thinking about a new water pump?
If so (and if not, you should be) I notice that Autohausaz has an improved version of the pos OEM one, with a metal impeller, made by Graf. And not only that, it's cheaper: $56 vs $82 for the OEM replacement (which I'm quite sure is what was put in my car).
Just a heads up for those with cooling system issues (this means YOU)
E39 Water pumps.
There's also an EMP one for $170 if money's burning a hole in your pocket
2001 530 Steel Blue Metallic, purchased Dec 03
SP/PP/CWP/Slushbox (I know I know)
OEM M5 bumper, 40% Huper Optik ceramic tint, Dice Silverline Pro iPod adapter, 540SP radial spokes, Zimmerman Z-Coat rotors w/ Hawk HPS pads
"Mods": driveshaft, cooling system, Vanos, CCV, PSR, VCG, FSU, spark plugs, buncha belts-n-hoses, & other things I'd just as soon forget
BMW CCA member for 15 years
Old 01-11-2010, 01:15 PM
cn90 cn90 is offline
This is rare but in the V8, there is one incidence where the OUTER section of the impeller falls off, making alot of noise:
http://forums.bimmerforums.com/forum...php?p=18361700
For the I6 engine, I have had the "Hepu" Water Pump now for 4 years, rock solid.
Do a cooling overhaul.
Old 01-11-2010, 01:29 PM
filon102 filon102 is offline
Be american, get a bimmer
Mein Auto: 00' 540i, 87' benz 300DT
i dont see a point of getting "high performance" wp... ur not running turbo or s/c... just 100 bucks down the drain
Old 01-24-2010, 06:12 PM
R2dmax R2dmax is offline
Not addicted... OBSESSED!
Send a message via Yahoo to R2dmax
Mein Auto: 99 528it/5 S; 88 735il
Thanx for the heads up! I actually just developed a leaky pump in my 99 528it. What else should I replace while I'm in that area?
e32 735iL - H&R/Bistein Sport; Smoked Corners; Brembo x-drilled front and ATE slotted rear rotors; PGR Ceramic Pads
e39 528iT/5 M-Sport - 17x8 and 17x9 M-Sport staggered; 20% tint. Soon to come: I.C.E; Haaman front lip; Carbon fiber grills, etc...
psst... Into Euros? Live in the Carolinas? check out CarolinaEuros
Old 01-24-2010, 07:00 PM
mhughett mhughett is offline
Mein Auto: 2003 530i/2007 Z4 Coupe
I've used nothing but Graf water pumps for over 10 years in all of my BMW's and never had one fail yet.
2003 530i 5-speed, SP, PP, CWP, Xenon
Bilstein Sports
UUC short shifter with DSSR and ZHP shift knob
Michelin Pilot Sport A/S
BSW IQ speakers, Sirius
CDV delete
Huper Optik tint
2007 X3 3.0si
6-speed manual, CWP, Xenon, Cft. Seats, Premium Pkg, Sirius, Privacy glass
Old 01-24-2010, 07:59 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
I believe Stewart makes a water pump that has a steel impeller. FWIW.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 01-25-2010, 05:56 AM
Originally Posted by R2dmax View Post
.....What else should I replace while I'm in that area?
Do a COOLING OVERHAUL!
http://www.bimmerboard.com/forums/posts/199986
NOTE: Do NOT use MTC Fan Blade (mine broke after 15K, use BMW Dealer Fan Blade it is better).
Use realoem to find PN for your car: 1999 is slightly diff from 1998 model.
RE: Brand Name: BMW is fine, I am happy with HEPU brand (3.5 years and rock solid), Graf is fine too.
Geba is a bit unpredictable.
Old 01-25-2010, 07:42 AM
Mack's Avatar
Mack Mack is offline
Thebizzy.com
Send a message via AIM to Mack
Mein Auto: '02 525i
That's the one I just put on recently when I did my cooling overhaul. I think we can all agree if you can get parts that will perform better than stock in your cooling system it is a good thing.
Part# 888010330 - $170.95 (AutohausAZ.com)
EMP Stewart
Water Pump; High Performance
This pump offers 20 percent flow increase, carbon graphite seal, larger bearing, and stainless steel impeller for improved cooling efficiency.
Mods: Shark Injected | Magnaflow Exhaust + Resonator | H&R Springs | Bilstein SP Shocks + Struts | TMS Power Pulleys
Eibach F+R Sways | BeastPower Brackets | M-Tech bumpers | Predator ICE V3 + HID Fogs | Eurodyne CF Hood | BSW Sub + Dice + spec dock
[---Quote (Originally by Tex330i)---
You can warranty a turd, that way when you have a problem you can exchange it for a new turd.---End Quote---
Old 01-25-2010, 07:44 AM
Solidjake's Avatar
Solidjake Solidjake is online now
Zero. Leaks.
Mein Auto: 02 330i 6MT
Welcome to the past.
Old 01-25-2010, 04:19 PM
zoevans zoevans is offline
Mein Auto: 2000 528i and 2001 4.4 X5
Pelican Parts has Graf water pumps for $60, with metal propellers.
http://www.pelicanparts.com/bmw/cata..._pg1.htm#item1
Old 01-25-2010, 08:08 PM
occhis occhis is offline
Mein Auto: 1998 528iA
Don't know about Graf, but stay away from Bosch. New pump w/o-ring leaked right out of the box. Had to re-install original. Original is tight and running well. Will replace with Hepu at 200k.
Either you are part of the solution, or you are part of the problem.
