E36 (1991 - 1999)
Old 10-30-2011, 08:49 AM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
Originally Posted by cj.surr View Post
How'd the knock sensor replacement go for you?
A biiaatch.
But it solved my hesitation/lag/misfire issues and car revs up MUCH MUCH quicker than before..... i can now peelout again
-Dino
Old 10-30-2011, 08:52 AM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Hmm, how did you diagnose it? You had a knock sensor code?
-CJ
Old 10-30-2011, 09:05 AM
BMRfanatic's Avatar
Well using the stomp pedlal trick i got an o2 sensor code which i thought was weird because my o2 was and still is new
So I used Launch Computer to plug in the Service port and got the faults for knock sensor 2
-Dino
Old 10-30-2011, 09:08 AM
cj.surr's Avatar
some kid
What is a launch computer?
-CJ
Old 10-30-2011, 09:15 AM
BMRfanatic's Avatar
Its an OBDI/II reader, the one i was using was named launched
Heres one but from snapon
I used this one last week to tell me that my DME isnt getting info from my o2 now
-Dino
Old 10-30-2011, 09:20 AM
cj.surr's Avatar
some kid
Ah. OBDI is such a pain to scan. All of the scanners are really expensive and the parts stores don't have them around here.
-CJ
Old 10-30-2011, 09:24 AM
BMRfanatic's Avatar
Yeah, luckily my mechanic is my bro's good friend and 5-10mins away from me
I was thinking if an old laptop with a serial port and something like carsoft would make a homemade obd1 scanner cause i did find an obd1 serial cord online
-Dino
Old 10-30-2011, 11:42 AM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
Good ol snap on scanner you got there. My boss has one like that but it doesn't have the euro package on it. However hes got a MODIS (which is the tatas by the way) that rocks euro software and I just use that with the 20 pin I bought. Like a baus
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
Old 10-30-2011, 11:50 AM
BMRfanatic's Avatar
snap on one is sooo easy a caveman can do it
even read my abs codes.....i got codes for days on that thing
also tells me when my engine is advancing and also tells you what signal and how volts from that signal the DME is getting
-Dino
Old 10-30-2011, 05:25 PM
DenKare DenKare is offline
darksilver
Mein Auto: 1995 325is
- Shock tower reinforcements!
I like the colour No Bias.
1995 325is 5spd
Old 10-31-2011, 05:14 PM
hornhospital's Avatar
D'oh, You Kids!
Since I took the OEM headlights out of Elvira and replaced them with DJ Auto lights, I got to looking at the super-clouded OEMs and decided to see how clear I could get them. Got out the Mothers Powerball4Lights kit with powerball and sanding pads and went to work. After getting them looking pretty darn nice I've decided (1) it's easier to do them off the car if you can figure out how to hold them since you can get at all parts of the clear cover (I pinned them between my old man gut and the desk...worked great), and (2) These are going on Bebe, because they are in way better condition overall that the ones that are on her.
Steps as per the Mothers package instructions. Since these were really awful I did the whole process including sanding with progressively finer pads (provided):
Buff over lenses with the foam ball and polish to remove loose stuff
For the next four steps it's important to keep the surface wet (plain water) and clean the lenses between grits
Wet sand the entire cover with the #1 grit pad going lengthwise
Repeat with the #2 pad, sanding 90 degrees from the #1 pad scratches
Repeat with the #3 pad going lengthwise again
Repeat with the #4 pad going crosswise again (by this time you can barely tell which way the scratches are going anyway)
Clean the sanding residue from the last step, then using a hand drill with the Powerball attached, apply a little polishing compound to the center of the ball. Starting at slow speed but with substantial pressure, start moving slowly over the lens surface. Reapply more polishing compound frequently. Continue buffing at progressively higher speed and renewing the polishing compound often. You can wipe the lens down with a microfiber cloth to see you progress. When you decide you've gone far enough, wash the lens with soap and water. You can dry it and then apply RainX if you want (it does help keep the lenses clear longer). Reinstall and you're done. If you were careful removing the lights you should have little or no readjustment of the beams. Now go for a drive after dark and admire how much better your lights work. When you get home, admire how much better the lights look. Go ahead, you can look back a couple times.
Name:	DS before.jpg
ID:	299296   Click image for larger version
Name:	PS before.jpg
ID:	299297   Click image for larger version
Name:	DS after_1.jpg
ID:	299298   Click image for larger version
Name:	DS after_2.jpg
ID:	299299   Click image for larger version
Name:	PS after_1.jpg
Name:	PS after_2.jpg
Quotes to live by:
Old 10-31-2011, 05:28 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Nice to bring life back into old parts. I had outstanding success with the 3M kit.
1998 BMW 328is
1966 Pontiac GTO
Old 10-31-2011, 05:40 PM
D'oh, You Kids!
The local auto parts places had the 3M polish. I bought it and used it, but it would take forever to get all the stone chips and scratches out with nothing but the polish working by hand. I asked them to get the kit, but they never did, so I bought the Mothers kit. I do like that powerball! The sanding took probably ten minutes per light, but the polishing only too about 4 minutes each. I can't wait to put them on Bebe.
BTW, my adjusters came from Pelican today. Now I just need my replacement ballast....
Quotes to live by:
Old 10-31-2011, 06:01 PM
ZeGerman's Avatar
Warm Leatherette
Yeah, the full kit is necessary on most headlights. I was surprised (and pleased) at how aggressive the sanding discs were. Definitely made things a lot easier to get all the pitting and other imperfections out.
1998 BMW 328is
1966 Pontiac GTO
Old 10-31-2011, 07:56 PM
darksilver
cleaned up rear end
WTF GEARING fuel goes from 45 - 30 in 80 kms (highway)
1995 325is 5spd
Old 11-01-2011, 07:44 PM
D'oh, You Kids!
Unhappy DDM strikes again
The M3 molding for Elvira came today................minus the Motorsports inserts! Amber said "their prices draw you in, but you pay in aggrivation". So true.
Quotes to live by:
Old 11-02-2011, 07:34 AM
thudsonjr's Avatar
thudsonjr thudsonjr is offline
Troy "Thud" Hudson Jr
Mein Auto: 1996 BMW 328is
new Home Depot front lip
Photobucket
Photobucket
Photobucket
let me know what you think
1996 328is 5speed
-Montreal Blue Metallic
-17" ASA JH3
-VIS Racing Carbon Fiber hood
-DJ Auto Projector Housings with Predator Chromium AE and
55w 10k HIDs, Clear M3 corners
-M3 replica side mirrors
-Summit race buckets
-Raceland Headers
-Raceland Ultimo Coilovers
Old 11-02-2011, 08:39 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Yea DDM is terrible and I will never buy anything from them again...the thing is ECS tuning has pretty much same prices and there customer service is amazing...I think im going to pick up my m3 mirrors from them vs buying oem and having to replace the glass at 60-90 bucks a piece, plust can paint them easier bc come primered.
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 11-02-2011, 11:55 AM
Joe__Sterling's Avatar
Joe__Sterling Joe__Sterling is offline
Fast Cars Suck!
Send a message via AIM to Joe__Sterling
Mein Auto: '13 FIAT 500 '68 BMW 1602
i dont think you could fit the lighter on its side under lola when she had her lip.
looks good now needs moar lowz
edit: just realized that kens BMW 1600 is to lola's left, and his dads 40' international rat rod project to her right.
wow that was awhile ago that poor 1600 hasnt seen daylight in quite some time
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
@Joe__Sterling on twitter & instagram (two underscores)
Old 11-02-2011, 09:10 PM
thudsonjr's Avatar
Well there is a lot of speed bumps here in iowa...and winter makes some hellish potholes. So I font want to sit too much lower.....a half inch lower would be perfect
Sent from my HTC Aria using Bimmer
1996 328is 5speed
-17" ASA JH3
-Raceland Headers
Old 11-02-2011, 09:23 PM
D'oh, You Kids!
I wish it was this Ken's 1600. If he doesn't appreciate it, tell him I would. One Ken to another
Quotes to live by:
Old 11-03-2011, 01:06 PM
thudsonjr's Avatar
Damn I forgot to add that Lola looks sexy
Sent from my HTC Aria using BimmerApp
1996 328is 5speed
-17" ASA JH3
-Raceland Headers
Old 11-03-2011, 01:11 PM
thudsonjr's Avatar
I also got the brake dust off my wheels.....man I need better pads.
And I don't know what to do about my eyelids they come in abs plastic black......so the same color as my lip......I was thinking either paint them car color ir just leave them unpainted.......but the car color paint is gonna cost quite a bit.....the BMW dealer in my town is outrageously expensive
1996 328is 5speed
-17" ASA JH3
-Raceland Headers
Old 11-03-2011, 01:13 PM
ZeGerman's Avatar
Warm Leatherette
Just don't put them on your car and sell them.
1998 BMW 328is
1966 Pontiac GTO
Old 11-03-2011, 08:19 PM
thudsonjr's Avatar
imma try em out...if i dont like em ill sell em...if i do then i guess i keep em
.....they only cost 12.99 and shipping was free
1996 328is 5speed
-17" ASA JH3
-Raceland Headers
:3
