E36 (1991 - 1999)
Old 12-05-2012, 05:13 AM
B_Rad_M3's Avatar
B_Rad_M3 B_Rad_M3 is offline
I6 feels good
Mein Auto: POS
Mthrfkr!!!! You know the deal pics or GTFO!!!!!!!
Por Favor Due EfŤ...
Sent from my Nexus 4G using Bimmer App
Old 12-05-2012, 06:39 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
had taken pics of 'before'...but for some reason the card isn't loading, and appears to be blank??
so, i went to go get another sd card, and found a cool flash drive as well, so i got that, too.
so now i should have no difficulties with teh pics.
i will commence with teh remainder of teh destroying this weekend.
df
Old 12-07-2012, 05:51 PM
dc_wright's Avatar
dc_wright dc_wright is online now
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Replaced the cam position sensor today. Not too bad except for the connector under the intake manifold. Didn't realize the release was a push instead of a pull and managed to pull it off, drop it, and lose it. Fortunately the clip from the throttle valve switch is the same so I transplanted that one and used a tie wrap as a temp holder until the replacement clip arrives.
Interestingly, it took 5 engine start/stop cycles before the CEL cleared....
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 12-07-2012, 06:34 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
Yeah, I think the CEL takes a little while in general to turn off for certain things. Did you have to pull the intake manifold to reach the connector?
1998 BMW 328is
1966 Pontiac GTO
Old 12-07-2012, 06:37 PM
dc_wright's Avatar
No, by pulling the cover off the oil filter and taking out the air box and alternator cooling duct I had enough room to get my hand in. If I'd realized the connector release was a push and not a pull it would have been even easier.
Old 12-08-2012, 02:21 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Removed the headliner and pillars from my red car to install it in the 328.
Then I needed to wrap the one A pillar because the one from the red car had my gauge pod on it.
And finally installed. Looks much better, old one was falling apart and tan.
Now I need to wrap the tan one in suede for the black car. Where can I find some? I want it to match my armrest from rallyroad.net.
Sent from my SCH-I605 using Bimmer App
ID:	352382   Click image for larger version
ID:	352383   Click image for larger version
ID:	352384   Click image for larger version
Turbo Build Here
Old 12-08-2012, 03:33 PM
Needs Boost
Mein Auto: Red Sled
Also for you climate control gurus, the fan ac heat etc. do not work. I swapped the digital unit itself from the working one from my red car and it made no difference.
Im guessing fsu?
Turbo Build Here
Old 12-08-2012, 04:16 PM
is there power to the control unit??
if you jumper out the fsu, does the fan operate @ full speed??
df
Old 12-08-2012, 04:23 PM
BMdude816 BMdude816 is offline
Mein Auto: 2004 BMW 118
Today i drove my kids to places wherever their minds leads them to. Had fun with kids.
Old 12-08-2012, 04:29 PM
Needs Boost
Mein Auto: Red Sled
df
The unit turns on and functions exaxtly as it should. Just there is no air movement or what have you.
Turbo Build Here
Old 12-08-2012, 04:46 PM
you mean the climate control head?? i thought that you meant that you got no fan operation, which would be the fsu or the fan.
or a fuse, but you checked that already, riiiiiight??
since the fan is pretty burried, the fsu would (should??) be between the control head and the blower motor. when the fsu is bypassed, it should operate the fan @ full speed since it is allowing full current to go through to the fan.
this is all a swag (sophisticated wild abstract guessing) protocol since i do not have a schematic in front of me to verify this information. if you could reach the fan, though, that would be ideal to check with a test light to see if the fan is bad.
df
Old 12-08-2012, 05:14 PM
Needs Boost
Mein Auto: Red Sled
The climate control head that controls everything looks turns on and acts exactly as it should, but neither the fan, ac, heat, defroster etc turn on.
Turbo Build Here
Old 12-08-2012, 05:17 PM
do you hear the blend doors moving when requesting vent vs. footwell vs. defrost??
does the compressor kick on when requesting ac or defrost?? if so, then i would say it sounds like a blower motor to me, unless the fsu died. but then, i thought they would fail 1 or 2 speeds first, before giving up the ghost totally...
df
Old 12-08-2012, 05:20 PM
Needs Boost
Mein Auto: Red Sled
No I don't think anything works or moves.
Turbo Build Here
Old 12-08-2012, 05:21 PM
hmmmm....time to break out the schematics...
df
Old 12-09-2012, 07:56 PM
hornhospital's Avatar
D'oh, You Kids!
It wasn't today but yesterday....new belt tensioner cylinder arrived. Installed it...the rattle is finally GONE! Bebe is so quiet now! I didn't realize just how noisy that tensioner was. Rattlerattlerattlerattle even when at speed. I also put a new thermostat in her. Last cold snap it was taking forever to warm up, apparently stuck open. Yesterday she stuck shut and started to run toward the red, so out came the old 'stat and in went the new. Took my time bleeding the system. Temp now goes to center within a mile and stays there.
Quotes to live by:
Old 12-09-2012, 08:01 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Nice!
I've had a very loud squeaking since I put the new alternator in. I figured it would go away, but a few hundred miles later, it's still there
-CJ
Old 12-09-2012, 08:21 PM
D'oh, You Kids!
If it started out squealing I think I'd have taken it back.
Quotes to live by:
Old 12-09-2012, 08:41 PM
cj.surr's Avatar
some kid
Didn't have much of a choice at the time... Had to get home. Do you think I should stop there on the way back? It's a little bit out of the way, and I doubt they have another in stock.
-CJ
Old 12-09-2012, 08:47 PM
Hellawut??
Mein Auto: who knows?
hmmm..... tricky could just be your belt?
-Franklyn
Old 12-09-2012, 08:53 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
Does the whine get louder when you ask for more juice? Lights, stereo or air.
You canít spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 12-09-2012, 08:55 PM
D'oh, You Kids!
Yeah, I forgot it was breakdown drama. Do you have their phone number? Explain the situation and maybe they can help....like get one on hand before you get there.
Quotes to live by:
Old 12-09-2012, 09:02 PM
cj.surr's Avatar
some kid
Yeah, that might be it. I'm gonna check it out tomorrow morning.
Nope, just gets louder with increased RPM.
Heading back tomorrow morning, so I don't think they can get one in time. I'll give them a call anyway, though. Maybe on my way back for Christmas, I'll stop there.
-CJ
Old 12-09-2012, 09:06 PM
TRaV MaNN's Avatar
Mein Auto: EW/// 86
I would guess belt tensioner then. Or like Franklyn said just the belt.
Old 12-09-2012, 09:08 PM
cj.surr's Avatar
some kid
It started right when I put the alternator in, though.
-CJ
:3
