E36 (1991 - 1999)
Old 02-11-2013, 09:26 AM
Hellawut??
Mein Auto: who knows?
i dont have a welder or a grand to fix it...
-Franklyn
Old 02-11-2013, 10:04 AM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Well then you're definitely not gonna have a welder and 2 grand to totally rebuild that shiit in the summer. Don't wanna be a downer, but it's only gonna get a lot worse.
-CJ
Old 02-11-2013, 10:25 AM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
CJ you know how to fix the subframe?
-Dino
Old 02-11-2013, 10:29 AM
drivinfaster's Avatar
Mein Auto: rescued bmw's
if i were closer i haz welder(s) to help out...but i are in teh stix...
btw, dino, your part is in teh mail. you need to clean your inbox out....couldn't pm you!!
df
Old 02-11-2013, 10:32 AM
BMRfanatic's Avatar
df
oops lol no more purple for me
i just nuked my inbox. (got spoiled with the increased limit)
Thanks df!
-Dino
Old 02-11-2013, 10:33 AM
gotta gets teh purples back!!
df
Old 02-11-2013, 10:37 AM
cj.surr's Avatar
some kid
I can do basic welding. So if there was a small tear, I could probably fix it by welding on reinforcement plates. But if it's completely torn out (like Franklyn's might be), then that would require an experienced welder and a lot of time. The extent of the damage on Franklyn's might be just the subframe itself. That's why I think he should pull the subframe and inspect the damage before driving it much further and possibly doing more damage. But ain't nobody wanna pull a subframe in Rochester winter, so I don't really blame him.
-CJ
Old 02-11-2013, 10:39 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Is franklyn having issues that make you suspect the subframe messed up or you talking preventative b/c the rust?
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 02-11-2013, 10:44 AM
cj.surr's Avatar
some kid
No he's had pretty bad knocking and we're pretty sure it's the subframe.
-CJ
Old 02-11-2013, 10:45 AM
B1MM3R's Avatar
Jesse Moon Bayne
Knocking when turning or all the time? Mine makes a knock/rub sound when turning reallllly slow in parking lot sharply...think mine is bushings tho.
Jesse
2001 330i DD
Old 02-11-2013, 10:48 AM
cj.surr's Avatar
some kid
The knocking is when the weight is switched on the driveline. (on/off the gas)
-CJ
Old 02-11-2013, 10:54 AM
B1MM3R's Avatar
Jesse Moon Bayne
O i see. Makes since..like rocking back and forth.
Jesse
2001 330i DD
Old 02-11-2013, 11:45 AM
EnserioJose's Avatar
EnserioJose EnserioJose is offline
Back in the game
Mein Auto: 1997 m3
I've got both symptoms ^^^.
I'm pretty sure my my subframe bushings are all shot. That's why I bought a new subframe in Chicago this past weekend.
The shot heard 'round the world.
Originally Posted by E36 Phantom View Post
That presenter is getting waaay too worked up over a tarted up VW Golf.
C:\>Sent from my 386 using MS-DOS__
Old 02-11-2013, 11:50 AM
hornhospital's Avatar
D'oh, You Kids!
It's the subframe bushings most likely. You should have heard the racket the subframe made on Elvira before I replaced the bushings. Same thing on the 633...sounded like someone slamming the frame with a 4 lb sledge every time you'd shift.
Quotes to live by:
Old 02-11-2013, 01:01 PM
B1MM3R's Avatar
Jesse Moon Bayne
Mine don't do it when shifting...only when going under 5 mph and turning really sharp. Think its bushings but not sure which ones.
Jesse
2001 330i DD
Old 02-11-2013, 03:21 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Jesse, my RTAB's sounded like that. Also on the highway I experienced a lot of bump steer.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 02-11-2013, 04:16 PM
B1MM3R's Avatar
Jesse Moon Bayne
Now that you mentioned it, mine does have a bit of bump steer. Will be doing those in spring I suppose...thanks ED. Should I just go oem or poly? Would I have to reinforce the subframe to use the poly rtabs?
Jesse
2001 330i DD
Old 02-11-2013, 04:22 PM
Back in the game
Mein Auto: 1997 m3
Ehhh...
Jesse mine had that sound coming from the rear before I did my rtabs.
I still have that sound. Ymmv (hopefully).
Old 02-11-2013, 04:29 PM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: A redhead E90
RTABs really aren't that hard. mien were pretty bad so i was able to take a sawzall to them without having to dril the rubber away to get the blade in there, once i cut through the metal cup of the bushing i was able to get it out with a hammer and chisel. the hardest part of the whole thing that took more time than replacing the bushing was getting the damn cassette to line back up to the subframe. the bolts wouldn't line up for the life of me, lots of swear words and other unpleasantries took place getting that fcuker back up there.
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '06 325xi 6MT
Old 02-11-2013, 05:01 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
I'd go with a soft poly, and no, you don't need to reinforce the sub-frame. If anything, you may want to eventually reinforce the pockets themselves if you plan to do some track work. Even so, I think RTAB pocket failure is mostly an issue with rust belt cars. I totally love my Rogue Engineering black RTABs. Super easy to install (unlike OEM RTABs, which require a special tool to install), and I didn't have any problems getting the trailing arms aligned like Ken did. You just gotta be creative with a floor jack and screwdriver to aid alignment of the bolt holes.
1998 BMW 328is
1966 Pontiac GTO
Old 02-11-2013, 05:05 PM
Kdoherty's Avatar
I used powerflex's black RTABs and they went in with very little drama. No idea why I couldn't get the console to line back up but i pretty much had to jam a punch into each hole and do one bolt at a time to get them in, and straight. what a PITA. it still only took me about an hour a side.
  • '06 325xi 6MT
Old 02-11-2013, 05:44 PM
B_Rad_M3's Avatar
B_Rad_M3 B_Rad_M3 is offline
I6 feels good
Mein Auto: POS
Originally Posted by Kdoherty View Post
does the buttdyno feel anything?
Car feels better has a bit more torque at lower RPMs, love the new rev limiter, and also it's peppier on the highway...
But can't say I gained hp though...
Mpg went up too
Old 02-11-2013, 05:48 PM
Hellawut??
Im good now cj..
-Franklyn
Old 02-11-2013, 06:10 PM
B1MM3R's Avatar
Jesse Moon Bayne
Thanks for the info guys...need alignment after?
Sent from my XT901 using Bimmer App
Jesse
2001 330i DD
Old 02-11-2013, 06:12 PM
ZeGerman's Avatar
Warm Leatherette
Yes, especially if the RTABs you are removing are shot. Putting brand new RTABs in place will align the trailing arms differently, even if you get the bolt holes lined up exactly as they were before.
1998 BMW 328is
1966 Pontiac GTO
:3
