E36 (1991 - 1999)
Old 12-01-2013, 09:06 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
Two of my Style 30s were slightly bent by the previous owner. I couldn't even tell from a visual standpoint, because they looked perfect, but they wouldn't balance out. Kinda odd, too, since I'd think they would be fairly robust.
1998 BMW 328is
1966 Pontiac GTO
Old 12-01-2013, 10:19 PM
3star 3star is offline
Mein Auto: 89 E30 Cabrio
what no turbo istall slacker!
wow thats a list
!! lolol
Originally Posted by 97328i View Post
Finally got it back together after 3 months on jack stands.
Rear subframe reinforcement mounts welded in
Poly subframe bushings
Poly RTABS
LSD rebuilt with new seals & bearings
New diff bushings
New driveshaft carrier bearing
New Giubo
H&R lowering springs
KYB shocks
New pads/rotors
Flushed brake fluid
New Clutch, PP
New Pilot bearing & seals
New Slave cylinder (The old one worked fine, and I may reinstall it because it felt better than this non oem unit)
New Throwout bearing
$60 used M3 muffler with slightly bent tail pipes
Heater hoses done while the trans was out.
New motor mounts & engine support bracket
Ground-down and painted a few areas on the under body that were starting to rust.
Fresh Diff gear oil, trans fluid, coolant, engine oil.
Old 12-08-2013, 08:55 PM
97328i 97328i is offline
Mein Auto: 1992 325i, Porsche 944 s2
wow thats a list
!! lolol
I don't feel I'm qualified to drive anything over 200hp.
Went out in the snow today, LSD seems to be working pretty good.
Anyone else in this storm? It was just the right amount of snow to have a little fun in and not get stuck.
RzxfEuXYmhY
1992 325i w/ factory LSD, Porsche 944 s2.
Fun fact, I've never owned a '97 328i.
Old 12-09-2013, 10:17 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
Replaced the VANOS, cam gear chain, guide rail, and tensioner... Good lord, now I see why people hate doing the chain. Ugh...
Harry // 1995 Avus Blue M3 - 2003 Titansilber 530i M Sport - 2010 Black Sapphire Metallic 128i M - Sport // BMW CCA #453346 - North Capitol Chapter // 2000 Silver Audi B5 S4
My Previous Work:
My 325is M-Tech Restoration Thread
My 98 M3 and 03 530i Restoration Thread
Old 12-19-2013, 07:56 PM
Melted speed/impulse sensor.
Name that failure mode... Because I sure can't..
Diff got very hot on break-in. Changed gear oil, changed sensor. Drove it about 15-20 miles and it seems fine, no strange noises.
A new problem arose in that 15-20 mile drive.. Only the middle brake light is working. probably not related.
Name:	melted impulse sender.jpg
Old 01-19-2014, 06:34 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
fixed my door panel. now my brake light malfunction warning popped on....
got my list together for the stuff i will need to the ti swap.
and promptly misplaced it....
i'm too young to be old!!!
(that's ken's job....)
df
Old 01-19-2014, 11:27 PM
hornhospital's Avatar
D'oh, You Kids!
df
My God, you have no idea how true that is.
Quotes to live by:
Old 01-20-2014, 12:01 AM
kieefersM3 kieefersM3 is offline
97M3 Sedan
Mein Auto: 97M3 Sedan
Today I got my mirror mount bracket for my radar detector and installed that. Picked up a hot wire off the sunroof and now it comes on with the key, looks nice and neat.
Old 01-20-2014, 12:05 AM
southpark11235's Avatar
southpark11235 southpark11235 is online now
bimmerfest Supporting Member
Mein Auto: 1999 BMW 323is
Pictures? How stealthily is it?
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 01-20-2014, 12:23 AM
97M3 Sedan
Pics later when I can.
Stealthy enough for me
Here's the link for the mount. http://www.countryjoycrafts.com/escortmount.html
I did have to make a few mods to make it work.
You use the Escort suction mount and remove the cups, those holes line up with their mount, at least it's suppose to. I had to file them out for the bolts to fit and line up.
The next mod is on the mirror, theres a raised plastic lip on the back side going around the swivel hole, this need to be ground flush unless you sit taller than I and like to lean to the right. Their bracket prevents the mirror from being adjusted to where I like it.
As with a lot of aftermarket stuff some exact fitting is needed.
Beside those two things it installed simply.
Old 01-20-2014, 07:51 AM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
I've found that it you lower the mirror about 1", you can fit a radar detector above it using standard suction cups. Even more out of the line of sight for someone looking into the car. But still easy to read when it goes off.
-CJ
Old 01-21-2014, 02:20 PM
97M3 Sedan
This sounds more stealthier than what I've done but I don't like seeing the suction cups from the outside. That's one reason I relocated with this bracket. If the cups where higher and not noticeable or behind some window tint I'd do this.
Matter or fact I wouldn't consider my setup steathier at all, more like bananas hanging off a tree. Also after studying it this bracket could have been made so that it could be closer to the windshield and higher.
You said that you lowered the mirror? I'd like to know how this is done.
Meanwhile I've got a growing list of things to do once time and weather permits, ABS, ASC, SRS light delete, various bushings, PS leak, cold start idle issue....
Old 01-21-2014, 02:54 PM
cj.surr's Avatar
some kid
To lower the mirror:
Remove the mirror and arm from the nut. Do this by grabbing the mirror arm where it attaches to the windshield, and twist.
Only the nut should be left on the windshield.
Remove the nut. I used a chisel and hammer VERY carefully. Use common sense here. Heat may help.
Use two-part epoxy to glue the nut back on, about an inch lower on the windshield, making sure to keep it at the same orientation rotationally.
-CJ
Old 01-21-2014, 03:41 PM
mbeezy mbeezy is offline
Mein Auto: 93 318i manual
once this weather warms up i have a parasite draining my battery to nothing. also updating front suspension with heavy dooty control arms. maybe this weekend will be good for it. Unitl then my car is in park freezing away. itll be MTA until saturday. yeah even if i jump the car as soon as the cables are off, boom dead she goes again. ..gahhhh of all times
you drive an automatic why
BMW CCA # 481777
Old 01-21-2014, 06:15 PM
Mr. Crimson's Avatar
Mr. Crimson Mr. Crimson is offline
Kid in Queen City
Mein Auto: 1993 325is Coupe
Today, I...
-freed up and lubed the throttle linkage because my pedal was sticking
-lubed my steering bearing and u-joint thingy with PB blaster to fix the squeek. made my wheel a lot smoother too!
-replugged my deleted-but-leaking throttle body coolant line using a larger screw with anti-sieze
-attempted but failed to find the chain tensioner under the car
Adam ///My E36 Adventure /// Xbox Live gamertag - aerodigy
Old 01-21-2014, 06:58 PM
cj.surr's Avatar
some kid
Did you try looking behind the timing cover? They like to hide there...
-CJ
Old 01-22-2014, 01:43 AM
Jammin325's Avatar
Jammin325 Jammin325 is offline
Mein Auto: 325I birthday mods soon
Well I afew days ago installed my bday gift which was coilovers. And Friday I should be installing 15 mm spacers on all 4 corners so I can actually lower the car abit and not have tire running issues
Sent from my SCH-I200 using BimmerApp mobile app
Old 01-23-2014, 05:34 PM
D'oh, You Kids!
Switched wheels on Sylvia today.
Sent from my MB860 using BimmerApp mobile app
Quotes to live by:
Old 01-23-2014, 08:14 PM
dc_wright's Avatar
dc_wright dc_wright is offline
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Lookin' good Ken! Any progress on the Style 42's?
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 01-23-2014, 11:04 PM
D'oh, You Kids!
Just painted the centers is all. The cans I bought of the same paint you had were a little different shade (common problem, undoubtedly a different lot), so I had to lightly spray the one you'd painted, too. Worked a little on the barrels. I'm not going to worry about getting the inner part (behind the centers) perfectly smooth. Just get it to bare metal and epoxy-coat them, then concentrate on polishing the lips.
Picture of the two different shades of the same paint shown below.
Name:	center paint.JPG
Quotes to live by:
Old 01-24-2014, 02:21 AM
Hellawut??
Mein Auto: who knows?
Look just like the ones cj has now.
nice
-Franklyn
Old 01-24-2014, 08:03 AM
bimmer claus's Avatar
bimmer claus bimmer claus is offline
Santa
Mein Auto: 95 M3
Do several coats of clear Ken the gold really shines I did one coat primer two coats gold metallic and three coats clear .
Lots of junk.
Old 01-24-2014, 08:16 AM
hnaz's Avatar
BMW CCA Member
Which stiffer arms are you going with? Loemforder or MEYLE HD? I don't know what's wrong with the MEYLE HD's but a lot of the guys I've spoken with in the New Jersey BMW CCA group hate them, same with the California BMW CCA group, saying that they bend and break too easily for being so expensive. They swear by Loemforder as the best bang for buck you can get for the front suspension arms.
As far as any work I did on the M-Tech, headliner was done with new headliner material and got it installed... solo. I don't ever want to do another solo headliner install in these cars, even though my front seats were removed for more movement, including the center console.
But the good news is, the M-Tech is now 20 years old... so Haggerty Insurance, here I come!! WOOOT!! Next year, the M3 becomes 20 years old!! So excite.
My Previous Work:
Old 01-24-2014, 11:10 AM
Santa
Mein Auto: 95 M3
For the last time don't buy meyles. Unless you want to almost die when a the ball joints rip out of the arm going into a Corner, get lemforders period.
Lots of junk.
Old 01-24-2014, 11:17 AM
You should just put your Meyle control arm story in your sig. It will save you some typing.
:3
