Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series
7 Series / 8 Series
The BMW 7 series and 8 Series Forum
Old 01-15-2010, 10:26 AM
bema735i bema735i is offline
Mein Auto: 735i
Unhappy Heater fan not working
I really need your help if you know the answer.. Ive got a E38 735i on a 98 plate and the heater fan is not working. Now i dont know but is there 2 fans (Driver/Passenger) or just the one ? I think ive checked the right fuses but not 100%.. Is this a common problem or just me ? Where are the fans located or the relays ? I would be very happy if i can get this fixed as the winscreen and all the windows keep misting up :o(
Many thanks Jason.....
Old 01-15-2010, 12:36 PM
Mein Auto: 735i
Bump!
Old 01-15-2010, 02:16 PM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
If you post in the correct forum you might have better luck.
******** DIY Board - POST DIY WRITE-UPS HERE, **NOT** TECHNICAL/OTHER QUESTIONS.
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
Old 01-19-2010, 11:34 AM
mariusvanrooyen mariusvanrooyen is offline
Mein Auto: 728
Smile 728 1998 heater fan
got the same problem
Old 01-20-2010, 03:26 PM
Payback's Avatar
Payback Payback is offline
Mein Auto: 97' 740iL
If I am understanding correctly... you are not getting any air/heat blown into the cabin of the car with the system turned on. If this is the case...It could be a bed blower motor or resistor that attached to the blower motor. Located underneath the dash board (upper half)
See the link below for info. visit partsgeek.comfor the part. Its where I got mine from
http://www.bimmerboard.com/forums/posts/45351
Old 01-23-2010, 09:57 AM
Daytona_BMW Daytona_BMW is offline
Mein Auto: Bimmers are sold :(
I am sorry to hear that, but I would bet that your poor blower motor is worn out. I had the same problem on my car.. Try to give the dashboard a beating with your hand while having the air on full, to see if it starts turning. If it does, the motor is busted.
It is a pretty hard job to replace the fan, but i assure you, it looks alot worse than it really is.. You need to remove the entire top portion of your dashboard to access the fan. I did it in five hours just to give you an estimate on it. There are some good diy online about it. So check e38.org.
Nothing else to do than to just start the job.. I am 100% sure that is the problem.
Go to www.bavauto.com and order up the fan, and start working ASAP..
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=141224&dateline=1253113821
Old 01-23-2010, 10:05 AM
Here is the link to the DIY by the way.. Link!
Old 01-23-2010, 05:06 PM
Payback's Avatar
I did the same job (replacing the blower motor). It took me about 2.5 hours. I also work on jets so that speaks on behalf of my mechanical skill. But regardless, you can do it and save yourself some money. No serious tools required!!!
