E46 (1999 - 2006)
Old 01-15-2010, 06:34 PM
JJKK's Avatar
JJKK JJKK is offline
Mein Auto: 2002 325xi
How much suction should I be getting from oil fill
I have read some posts that say " a lot" of suction into the oil fill hole implies that ccv is stuck open. Just did CCV and am curious. I laid one of those thin taco bell bags on there and in my opinion, it really pulled it in, a lot of suction.
Old 01-16-2010, 06:29 AM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
I have Same exact question. Mine doesn't have muchsuction.
mujjuman
Old 01-16-2010, 07:11 AM
boogety boogety is offline
Boogety Boogety
Mein Auto: 325Ci
You are taking the oil filler cap off when you do this, right? Right?
Old 01-16-2010, 09:01 AM
tappa tappa toit
Mein Auto: hoopty
yes... how are we supposed to do it?
Engine is started, and I remove the oil filler cap. It comes off with ease, no force involved. I put my hand to the hole, and only a negligible amount of suction... so basically none. I had someone rev my car a bit, and a bunch of air came out. :/
Please help... what does thsi mean? What is normal and what is abnormally terminally ill?
mujjuman
Old 01-16-2010, 09:50 AM
Boogety Boogety
Mein Auto: 325Ci
Maybe I misunderstood your question. I thought you were changing your oil via a MitiVac or some such. In that case, you would introduce a long plastic tube, the biggest diameter that would fit, into your dipstick tube, remove the oil filler cap, pump the MitiVac, and evacuate the oil in your crankcase.
Maybe there's a Taco Bell bag in your crankcase... ???
Old 01-16-2010, 04:23 PM
tappa tappa toit
Mein Auto: hoopty
lol no we're talking about some test that is performed to see if the oil separator is working or not.
mujjuman
Old 01-16-2010, 06:16 PM
jcourcoul jcourcoul is offline
Supporter of Bimmer Lore
Mein Auto: 2006 325Ci
The crankcase vent valve and 4 associate hoses fail and cause a vacuum leak. The valve gets stuck open and the hoses crack. These last 70-120k miles and usually fail 80-90k miles. Here are a couple diagnoses.
At warm idle, place small plastic freezer storage bag on its side over the oil fill hole. If the bag sits on top or gets slightly sucked in, ~1Ē, the valve is good. If the bag gets significantly sucked in the hole the valve is stuck open and bad.
With the engine off and cold, carefully remove the hose at the valve cover front corner. Blow hard into the hole. You should hear oil bubbling in the oil pan. If you donít hear the bubbling the top or bottom hose is likely cracked. The bottom hose often breaks just below the valve connection. There can also be cracks in the other two hoses.
Hope that helps.
2006 325Ci
Old 01-16-2010, 07:05 PM
tappa tappa toit
Mein Auto: hoopty
Originally Posted by jcourcoul View Post
Hope that helps.
yeah it does. i had that exact problem. funny thing is, the hose was cracked right by the valve cover and by the oil seperator valve.... but i still had small amount of suction at the oil fill hole.
mujjuman
Old 01-17-2010, 02:47 AM
NoMercy346 NoMercy346 is offline
Mein Auto: 2004 325i, 96 Jeep GC
Yeah, mine does the foghorn sound but it doesn't suck. CCV will be replaced come spring...
