Old 01-17-2010, 03:12 AM
5ukit 5ukit is offline
Mein Auto: 2002 540i msport
Question 2002 540i 6speed
just picked up my first bmw (finally , been wanting one for 3 years now ) its a 2002 540i 6speed with 66.5k on it the car is pure p@$$% just im planning on servicing the car this week and wanted to know your opinions and what should i pay attention 2
Old 01-17-2010, 04:26 AM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
very nice, congratulations!
i suggest coolant flush, brake fluid flush, transmission oil change, differential oil change, oil change + filter, check air filters and replace if necessary, check brakes and replace if low, tires?, check spark plugs to see if they need replacing and replace if necessary, blinker fluid.
Do you have the M Package?
mujjuman
Old 01-17-2010, 12:46 PM
hahaha blinker fluid deff gonna check that out first
thanx man thats what im doing plus a lil more
Old 01-17-2010, 01:30 PM
tappa tappa toit
Mein Auto: hoopty
Nice, what else are you doing?
mujjuman
Old 01-17-2010, 01:55 PM
well to add to that ima do a full mechanical inpection at my friends dads shop who is a certified dinan dealer and if everything is in good shape ima prob wrip out my resinators im also going to take pics of the car today because its a rainy day and the car looks so sexxy rite now
Old 01-17-2010, 02:02 PM
tappa tappa toit
Mein Auto: hoopty
word post em up here
mujjuman
Old 01-17-2010, 02:41 PM
chiefwej's Avatar
chiefwej chiefwej is offline
Freude am Fahren
Mein Auto: 2003 540i/6 //m-tech
The first mods to do on any manual trans e39 should be:
1. CDV delete. Go here to read about it. You don't have to buy the modified one, just remove it and reconnect the line. Make sure to clamp the rubber part of the line so you won't have to bleed the system.
2. SSK Some kind of Short Shift Kit. You can spend hundreds of dollars, or you can simply buy a BMW OEM shifter for an E60 545 from a dealer for about $60. It will reduce the throw distance by about 45%. Feels like a BIG change.
3. Drain the trans fluid and refill with Royal Purple Synchromax. Many auto parts stores will have it. ( If not look on the Internet) It cost about $10 per quart. You will only need two. The shortened throw will make the shift stiff and RP Synchromax will cure that.
All three can be done in one afternoon of DIY for less than $100 total, and it will transform shifting from feeling like a bus to that "snick-snick" sports car feel.
Take care of that cooling system and if the radiator hasn't been replaced: Cooling System Overhaul.
Search the forum for detailed instructions.
Oh and congratulations on the car, and welcome to the addiction.
chiefwej 2003 540i ///m-tech 6-speed
Black Sapphire Metallic w/gray
Old 01-17-2010, 02:47 PM
chiefwej's Avatar
Freude am Fahren
If you mean the M-tech Sport, that was only avail on the 03 model year (in the US). If you are asking is a sport package car, every 6-speed was a sport edition.
Old 01-17-2010, 02:51 PM
juanchi93's Avatar
juanchi93 juanchi93 is offline
Mein Auto: 2002 540i sport
This thread is worthless without pics.
Old 01-17-2010, 10:14 PM
tappa tappa toit
Mein Auto: hoopty
Oh I see.
Btw I drove the E60 545 6spd and the throws are really long... It was a 2004 model.
mujjuman
