Old 01-18-2010, 09:19 PM
trublulgc trublulgc is offline
Mein Auto: 300 E
2005 X3 - Any big issues to look out for?
Hi all,
New to BMW, my wife and I will soon be done with grad school and moving to Chicago. We've been looking for a 2005 X3, 50-60K miles, but still pretty new to the car - any big issues I should be looking out for? I've gone through several threads, and a red flag is the stiff ride, especially on Chicago's poorly maintained roads.
Any other tips/advice is appreciated! TIA
Old 01-19-2010, 05:54 AM
codog2 codog2 is offline
Mein Auto: 5
check under the floor mats for water leaks. I had rubber mats so it took me a while to find out. I think mine was aleaky vapor barrier for the door.
My 05 also had a problem with the keyless entry not working in Boston - too much interference. This is a common problem on early 05 models (since you are in Chicago, problem have the same issue) - there is a service bulletin to fix the issue - which was done for me under warranty
Old 01-19-2010, 06:05 AM
Evlengr's Avatar
Evlengr Evlengr is offline
Ukemi - that's how I roll
Mein Auto: 2013 Audi S4 2010 MT MCS
Have a dealer run the VIN number for past service history.
The other thing I see is what codog mentioned which can be from roof or door leaks.
Car wash or high pressure wash may help show that.
2013 S4 Loaded (and NO RFT's) Awesome is an understatement
2008 MT X3 RIP you were a faithful sidekick and will be missed.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
1997 Twin Turbo RX-7
1984 GTI Wolfsburg Edition Neuspeed and more
Old 01-19-2010, 10:22 AM
enamoured enamoured is offline
Mein Auto: 2005 BMW X3 3.0i
I drive a 2005 X3. The issues so far, sunroof shade got stuck once, replaced under warranty, passenger seat recall due to problems with passenger detection and airbag module, driver seat leatherette deformation which is found to be common in extreme cold weather locations and was replaced under warranty. Other than that if you drive the car coming down to flat road from an incline and it tends to hold the lower gear for a tad longer, there is a s/w patch for that which does work. Overall 2005/2006 are the best years for an X3. Good luck with your purchase.
(OO \ (|||) (|||) / OO)
Old 01-19-2010, 03:50 PM
dharmadoggie dharmadoggie is offline
Mein Auto: 2005 X3
Cool. I need that fix. Keyless wouldn't work for me in Portland, OR, near some radio towers.
2005 X3 3.0i, CPO, white, auto, adaptive xenon lights, stock suspension, premium pkg, cold weather pkg, heated steering wheel. Self installed: factory hitch, paint protection film, mud flaps
Old 01-19-2010, 06:48 PM
Mtnbiker Mtnbiker is offline
Mein Auto: 2005 x3 3.0 Highland Grn
Sit in the driver seat with the heater on high for 10 minutes and then check for hot spots in the seat. Signs of future failure in the heating pad. Very expensive to fix - unless you can live without heated seats. I have heater steering, and will always have it.
Have the suspension springs checked for broken ends. Frequent problem. It cost me $360 to have a rear spring replaced. It had a 2" piece broken off from one end, and I didn't have any indication that it had occurred. Dealer said it was a stablity issue if not fixed.
When were the brakes done? It's about $500 an axle to have it done. Consider this in your potential future cost expectations. Also, at 60K mileage, it's time for the super duper service requirement. I hear its close to $750.
I have an 05 X3, with 44K on it. Fun to drive. Stiffness in suspension could be tires. My replacement tires were Bridgestone Turenza Serenity and I like the ride better then the OEM tires.
Old 01-19-2010, 07:32 PM
PPXYZ PPXYZ is offline
Mein Auto: BMW X3 2009 AT
Originally Posted by trublulgc View Post
Hi all,
Since sunroof and door leaks seem to be on people's minds, I would get a big flashlight and check the bolts under the seats. With extreme leaking, people say they rust.
I would find a decently maintained road and drive it a few times in your own car, try the X3 and then try (if you are at a dealer) a 328 which is what it is based on. I would then go to a Lexus dealership and try an RX which probably has the most marshmallow ride of the bunch. If you can't tell the difference when driving the same road in a number of different cars then maybe it doesn't matter to you or maybe you even prefer a harsh ride....some do...you never know.
I do think that more passengers in the car makes the car less bouncy so I would drive it alone if possible.
Good luck. CPO?
Old 01-22-2010, 09:41 AM
kps88 kps88 is offline
Mein Auto: BMW X3 3.0
I just got one with very low miles and full warranty until 9/2012. Just curious why the 05/06 is the better years for the X3. Thanks in advance.
Old 01-22-2010, 10:05 AM
Should have said 05/06 are best years for X3 with AT. Read the sticky and you will understand why.
Old 01-22-2010, 10:22 AM
AT as in automatic transmission? that is what I have.
Old 01-22-2010, 10:24 AM
Indeed. What year model did you buy? When you say "full warranty" is it bumper-to-bumper or CPO?
Old 01-22-2010, 10:26 AM
2006. "bumper2bumper" till 9/2010 and the CPO until 9/2012 or 100K miles (I have less than 30K now).
Old 01-22-2010, 10:28 AM
Sounds good. Congratulations on your purchase. Now post some pics already
