Old 01-19-2010, 08:28 AM
jeffchau jeffchau is offline
Mein Auto: 540i
Recall- strange noise from fan?
Anyone know about any recalls on a 2000 540i?
Other night i noticed a whining noise coming from under the hood. Haven't checked it out yet but my guess it may be fan as noise disappears. My indy mentioned there may have been a recall and to check into it
thoughts?
Old 01-19-2010, 08:37 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Check with the dealer on a recall.
Under what conditions does the noise stop? Could also be alternator or idler bearings.
I doubt the electric fan is running in the winter, so check the clutch on the mechanical fan with the engine stopped. The fan should move like it's in molasses. If not movable at all, get the clutch changed immediately, before the blades break off and wreak havoc under the hood.
Old 01-19-2010, 10:17 AM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
Aside from the dealer looking your VIN up in their database, you can also check here:
http://www-odi.nhtsa.dot.gov/recalls/recallsearch.cfm
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, M5 rear subframe braces, H&R 15mm wheel spacers, Bilstein B14 PSS coilovers, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 01-19-2010, 10:20 AM
Noisy engine fan operation is a pretty common complaint here. I found a Technical Service Bulletin from BMW noting that after the fan recall is performed, customers may complain of noisy operation...
http://www-odi.nhtsa.dot.gov/tsbs/
Old 01-19-2010, 11:15 AM
Mein Auto: 540i
thank you for insight everyone
