Old 01-19-2010, 08:52 AM
Jim Rolando Jim Rolando is offline
Mein Auto: 1999 528i
Valve Cover Gasket and VANOS
Although the leak in my 528i's valve cover gasket isn't very bad, it isn't going to repair itself and will only get worse. So I've pretty much decided to tackle it soon. From what I've read in the Forum doing the valve cover gasket gets you about 90% of the way to doing the VANOS seals. Is that correct? How much more work is it coming from some of you guys who've done it?
Old 01-19-2010, 09:01 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Have you visited this site?
http://www.beisansystems.com/index.html
I believe you have the single-VANOS system. That requires special tools to align the camshaft.
Old 01-19-2010, 09:14 AM
No, I think it is the double set up. I have looked at that site though and it appears that once everything for the vavle cover gasket is removed there is't a lot left to getting the VANOS off.
