E30 (1982 - 1993)
Old 01-21-2010, 04:43 PM
E30-325's Avatar
E30-325 E30-325 is offline
Mein Auto: BMW 325is
New rev limiter
It seems that my car has made itself a new rev limiter at about 5200rpms. Anyone know why these cars would just decide to do this? The revs will not go over 5200 but it revs up fine. the idle is alright but sometimes the car will just die if i let it sit for awhile. I just replaced the o2 sensor but that didn't seem to help. Only a few sensors left that i have yet to replace. Gimme some suggestions!
Old 01-21-2010, 08:02 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
Mine did that (booyyaaaahhh past tence ) when it was cold from time to time, talking once a fortnight. no idea of the cause but i have been told on a different forum that either the AFM or TPS is be the issue as thats what fixed it on his car
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 01-22-2010, 10:29 AM
PBC///2.7 PBC///2.7 is offline
Mr.Evil...E30
Mein Auto: 87 E30
^^plus the ECU too....
Old 01-24-2010, 05:37 PM
E30-325's Avatar
eh idk i unplugged the tps but it still does it. but while the tps was unplugged my car didnt stall and give me check engine lights on the highway
Old 01-24-2010, 06:00 PM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
It could be the road speed sensor. Did you check the fault codes?
I Timothy 2:1-2
Old 01-24-2010, 06:25 PM
E30-325's Avatar
how do i check what code it is on an 87?
Old 01-25-2010, 06:11 AM
karimMsalama karimMsalama is offline
Banned
Mein Auto: BMW M5 VW MK2
may be a sensor
Old 01-25-2010, 06:21 AM
an audience of One
There's a diagnostic port under the hood. An indy shop can pull the codes for you. Or Google "stomp test".
I Timothy 2:1-2
Old 01-25-2010, 08:13 AM
E30-325's Avatar
i thought the stomp test didnt work with pre 88 cars
Old 01-25-2010, 09:00 AM
an audience of One
I didn't know that. Go to a local shop and ask them to read the diagnostics.
I Timothy 2:1-2
Old 01-25-2010, 07:12 PM
E30-325's Avatar
well the check engine light doesnt stay on. it only goes on when the car hiccups then it goes off.
anyone know what the sensor is thats right under the TPS? it plugs into this circular thing with a little vacuum line that goes underneath the throttle body
Old 01-25-2010, 08:59 PM
JohnMadd's Avatar
JohnMadd JohnMadd is offline
obsessed
Mein Auto: 1989 325is 03 330i ZHP
round connector under the throttle body, c191 iirc. This has been disscused on here recently. I reccomend unscrewing it and checking for moisture and corrosion, if water is present then make a small slit in the bottom to let it drain.
Old 01-25-2010, 09:02 PM
E30-325's Avatar
c191? thats what its called? whats it do?
Old 01-25-2010, 11:58 PM
portal through time and space
E30 above Sold
Old 01-26-2010, 09:31 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
I thought that was the Tardis?
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 01-26-2010, 10:04 AM
E30-325's Avatar
......thanks?
Old 01-26-2010, 10:13 AM
JohnMadd's Avatar
obsessed
It is a main connector, I dont really remember exactly what it goes to but it does effect the way your car runs. Just unscrew it and see what it looks like. I had water and corrosion in mine, I used a very small screw driver to scrape the inside of the pin connectors. Dont know if this will help your problem but it is easy to try.
Old 01-26-2010, 10:18 AM
E30-325's Avatar
i dont know if we're talking about the same connector here. this connector has a vacuum line going to the charcoal canister on one end and the other end has a vacuum line going to the throttle body/.
Pictures:
Old 01-26-2010, 10:23 AM
JohnMadd's Avatar
obsessed
Good pic, we are not talking of the same part, sorry. I have unplugged that but dont really know much about what it does or what its called.
Old 01-26-2010, 10:25 AM
JohnMadd's Avatar
obsessed
Part #?
Old 01-26-2010, 10:26 AM
E30-325's Avatar
0 280 142 150 is the only number on it. it says made in germany and Bosch
Old 01-26-2010, 10:55 AM
JohnMadd's Avatar
obsessed
0 280 142 150 Canister Purge Valve
This is what I came up with. I guess you could try to clean it out since it is a valve.
I dont know for sure but you could probably bypass it but I bet you would smell gas fumes in the car.
Old 01-26-2010, 11:21 AM
E30-325's Avatar
well i was fiddling with that and the tps while my car was running. i got it to rev up to the real limiter but now its back to 5k and wont go any higher. idk if i have a bad vacuum leak or if that purge valve is blocked or something
Old 01-26-2010, 02:34 PM
JohnMadd's Avatar
obsessed
Here is some info on motronic and 2 or 3 down it explains that valve. http://www.hiperformancestore.com/Motronic.htm
I think that it may be the tps though, do some resistance tests on it. There is tons of info and tests in that link I gave above.
Old 01-26-2010, 09:04 PM
E30-325's Avatar
i'll see how the tps checks out with my volt meter as soon as its light outside!
