E46 (1999 - 2006)
Old 01-21-2010, 04:50 PM
Johnst-H Johnst-H is offline
Mein Auto: 320 TURBO DIESEL
Wink Alternator overheating
LOOKING FOR INFORMATION IN THE TECHNICAL FORUM
can anyone feed me some information on why a perfectly good Alternator should develop
overheating symptoms directly after the reconnection of the battery.
I removed the battery to boost its performance after a recent spell of bad weather.
after returning the battery to the car I am experiencing extremely overheating within
the workings of the alternator.Can any members who have experienced similar problems
enlighten me of any knowledge they have experienced.
The car in question is a BMW 3 SERIES TURBO DIESEL manufactured in 2001
model 320 d
Old 01-21-2010, 05:23 PM
fcpeuro's Avatar
fcpeuro fcpeuro is offline
Sponsor
Mein Auto: All BMW Everything
When you removed the battery, did you charge it? If so, it is possible that the battery has been over charged and is causing an issue with the alternator. A brand new alternator should not be overheating unless it is faulty.
Quality & Service, Guaranteed for Life
FCP Euro - European Auto Parts Online
sales@fcpeuro.com
Old 01-21-2010, 06:25 PM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
In the E39 section, I read that leaves, etc blocking the alternator duct can cause it to heat up as well.
Old 01-22-2010, 08:10 AM
checked out vents in alternator casings all vents are free from obstuctions
thanks for your input all these things are relevent to finding the reason for overheating
The alternator was obviously operating alright prior to disconnecting the battery whatever is causing this fault has been caused directly by the disconnection or reconnection of the
battery.prior to this the alternator and all items related with same were working smoothly
and noise free most faults involved with the alternator are usually mechanical
ie; brushes failing on the slip rings or bearing failure on the stator.Both of these failures are made aware by a high pitched whine.In this case no signals are present that the alternator is suffering from a mechanical failure.
Is there someone within the forum who has suffered a similar problem and found a resolution that could help //All such assistance would be gratefully appreciated
Best Regards
To all Respondants
Johnst-H
Old 01-22-2010, 01:35 PM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Mein Auto: 2004 325 Convertible
If you did not charge the battery while it was disconnected it may be discharged to the point that the alternator is overheating trying to get it back to a proper charge. The purpose of the alternator is to recharge a battery that has MILDLY been discharged due to starting the car, not to recharge it from way past it's normal discharge point. That's why we always recommend a battery tender or c-tec to people that store their cars for a while.
Old 01-22-2010, 03:31 PM
the battery was given a slow recharge until it reached a yellow light scenario in the battery condition window
this yellow light I am describing indicates that the battery has attained its full charge and is ready to be refitted to the vehicle
After removing the battery from the charger the terminals were cleaned to give the battery a positive clean contact with its terminals
The battery was then refitted to the vehicle. I was greatly surprised to discover that on driving the car a short distance I realised there was a problem
when there was an overheating smell invading the passenger space.Istopped immediatly to find that the temperature coming from the alternator was the cause of the smell. I towed the vehicle home and it will remain out of service until I can discover WHY!
Old 01-22-2010, 04:27 PM
SJBimmer's Avatar
Here in the States the battery eye has to be green to indicate a full charge. Your battery may have an internal short. Have the battery load tested (not just voltage), to be sure it is actually good. Good luck!
Old 01-24-2010, 07:53 AM
your right a yellow light indicates a flat or damaged battery getting it checked out for damage.
Will replace THE battery if repairs are impossible
Old 01-31-2010, 05:12 AM
Arrow
the
Old 01-31-2010, 05:15 AM
the battery was replaced 29th January to eliminate same but still getting high temperature from the Alternater
has any member found a solution to my predicament ?
Old 01-31-2010, 07:18 AM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
I thought it was normal for an alternator to get hot?
mujjuman
Old 02-10-2010, 02:36 AM
I mean hot! Not warm
Old 02-10-2010, 03:33 AM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
mujju might be right - how do you know it's too hot? Maybe the opinion of a local mechanic would be warranted? Or find someone that will let you compare the temp of theirs to yours?
Old 02-10-2010, 04:13 AM
GoingNuts GoingNuts is offline
Banned
Mein Auto: 04 330Ci M-Sport
Did you see smoke ? That would be hot.
