Old 10-22-2015, 03:16 PM
99528icali 99528icali is offline
Mein Auto: 99 528i
Idler pulley
Should it spin freely and quietly or does it make noise aswell?
Old 10-22-2015, 03:25 PM
JKRIT JKRIT is online now
Mein Auto: '03 525i
With belt off, it should turn quietly by hand, but not continue spinning. If it keeps spinning, the bearings are dry. Some will DIY and re-pack the bearings with new grease. Others (like me) will just buy new ones. Good idea to replace all three if one is about to go.
'03 525i Sapphire Blu/Grey, SP, Nav
'03 530i Sterling Gray/Blk, SP
'02 525it Titanium Silver/Grey, SP
'02 325it Orient Blu/Grey, SP, Nav
Old 10-22-2015, 03:30 PM
Mein Auto: 99 528i
Sounds good, also should the tensioners spin freely aswell?
Old 10-22-2015, 03:38 PM
Mein Auto: '03 525i
Same deal. NOT continue spinning.
Old 10-22-2015, 03:43 PM
Mein Auto: 99 528i
so my tensioner (next to the alt) not spinning at all by hand is no good then right.
Old 10-22-2015, 03:54 PM
Mein Auto: 99 528i
new question would be, is that tensioner not spinning at all, whats making my alternator not run to its potential :o
Old 10-22-2015, 04:32 PM
Mein Auto: '03 525i
That would be called "frozen or locked up," and usually leads to belt failure. If you mean you can turn it easily by hand, but it stops spinning as soon as you let go, then that sounds normal.
If main belt is running (even if there are some noisy idlers) and the alternator is not putting out the correct voltage, then the problem is in the alternator.
Old 10-22-2015, 04:34 PM
Mein Auto: 99 528i
even if the tensioner is completely frozen?
