Where exactly do we look on the E39 radiator for telltale cracks? - Page 3 - Bimmerfest - BMW Forums
Old 02-10-2010, 10:22 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Originally Posted by chiefwej View Post
The third picture is a 540 bleeder (there is only one).
Oh, I see. There is only one bleeder and it's on the expansion tank for the V8 but on the inlet hose of the thermostat housing for the I6.
Is that right?
Old 02-18-2010, 09:52 PM
bluebee's Avatar
I was wrong!
After reading the attached documents, I now realize that the thermostat in my E39 operates totally differently than a "conventional" thermostat.
Specifically, it keeps the engine hotter at lower loads than it otherwise would be and it keeps the engine artificially cooler at high loads (for smog reasons).
To to that, they put in a thermostat that is directly controlled by 0 to 12 volts instead of coolant temperature (directly anyway).
The formula they use to control the thermostat is non-intuitive (to me anyway) as they actually have a WIDE RANGE of temperature from 80C to 103C in which the thermostat is artificially manipulating the flow (hence the temperature).
ID:	219010   Click image for larger version
Old 02-19-2010, 03:33 AM
aca84's Avatar
aca84 aca84 is offline
Mein Auto: E39 530i
As I've been having coolant problems recently, every time I drive, I've had the digital readout of the coolant temperature showing on my OBC. This has indeed shown the unusual operation of the thermostat.
Basically, when stationary in heavy traffic, I've had the coolant temperature down at 84 C at times. On the open road doing 60, I've had it consistently around 96 C (where theoretically, it should probably be cooler since more air is being taken through the radiator than when stationary) probably indicating that the thermostat is actually not always fully open at higher loads (depending on other variables too ofcourse).
Old 02-24-2010, 08:06 AM
bluebee's Avatar
Just for the record, here's a thread where the bleeder valve (near the thermostat) turned to mush.
Old 02-24-2010, 09:22 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Hello Blue.
As Mack said, and I know from other sources as well:
Usually the first thing to go is the thermostat. Mine went 2 years ago at around 60k miles.
I am still with the original cooling system at around 80k miles (128,000 Km).
Also, that bleeder screw you pointed out - that one turned to mush on my car last summer, when I did the Vanos seals. So I think the entire cooling system is not far behind.
Change that plastic bleeder screw withan aftermarked brass screw. I know I changed mine. They come with the rubber O-ring, but make sure it's on it.
Looking for a DIY? Parts? Check this out, it might be your ticket
Stable: e92is, e46, , e83, f25, e53 - sold, e39 RIP
Old 04-01-2010, 07:44 AM
etc etc is offline
Mein Auto: 528i
The design is garbage. The parts seem to be made from recycled plastic milk jugs. It's just astounding that the QC team let something this big slip through, or is it the engineering team, or both. There is no way a non-moving part like this should wear out or be damaged by heat. If they can put a man on the moon, for sure they can build a radiator that doesn't blow up at 80K miles.
However in BMW's defense, many modern cars have weak cooling systems that need to be overhauled at 100K miles. I had another make vehicle, that nearly stranded me at night on I-95. The radiator exploded right at the same point as shown above. I was able to slip the radiator hose a bit further on it and made it home but thought for sure it's towing truck time.
1999 BMW 528iT. Station wagons are back.
Old 05-17-2010, 01:14 AM
bluebee's Avatar
Originally Posted by etc View Post
The parts seem to be made from recycled plastic milk jugs. The radiator exploded right at the same point as shown above.
Here's another exploded radiator upper milk-jug plastic hose that happened in this thread today.
Old 05-17-2010, 01:27 AM
bluebee's Avatar
It looks like there are two main failure modes:
1. The upper plastic connection to the engine
2. The upper plastic neck of the radiator
Old 05-17-2010, 01:29 AM
bluebee's Avatar
And here's another BMW E39 radiator explosion from today.
This one was more classic at the upper neck instead of the last one which was nearer the engine on the upper connection to the thermostat.
The funky stuff is JB Weld.
Old 05-29-2010, 07:51 PM
bluebee's Avatar
In keeping with the pictorial nature of this thread, here's a picture of an expansion tank with white deposits along the side ...
Old 05-29-2010, 08:51 PM
namys1 namys1 is offline
Mein Auto: 2002 525i
My two cents to the discussion. My car has 115K miles (184000km). I`ve replaced the rad today. Car was loosing about 100 grams (3 ounces) of coolant every three-four days of city driving. A hair-wide crack was on the upper plastic corner on the driver`s side. Crack was almost invisible, there was no leak when the car was parked, although you could smell coolant and see white spots all over. When my mechanic applied air pressure on the rad, the crack erupted with a small fountaint. Four hoses were replaced as well. But now I found that the expansion tank has its on crack - one of the necks linked to a hose is cracked. That is my next project.
I ordered BEHR rad via Bimmerspecialists at c$213 (with import taxes)- compared to c$650 asked by local BMW dealership, that was a good deal. Parts were delivered very fast, air S&H was very reasonable).
Old 05-29-2010, 09:14 PM
@Bluebee:
I`ve got exactly the same looking residue on the expansion tank, not much, but alarming. In my case, the upper neck of the expansion tank, which is beneath the shroud next to the bleeder screw, has a crack. You can`t see it unless the plastic cover around bleeder screw is removed. I was wondering what consequences that crack may have - besides the need to add coolant. My mechanic told that the tank has to be replaced.
Old 05-29-2010, 09:19 PM
5er2er8er 5er2er8er is offline
Mein Auto: 98 528ia premium
all hose connections
Old 06-22-2010, 04:27 PM
bluebee's Avatar
Here's an autopsy of a failed BMW E39 expansion tank and another DIY.
The failure-mode sequence of events was:
- Sensor stick fell off sensor float (may have already been deteriorated or the cap put on wrongly)
- Float mechanism puts even more stress on the bottom of the expansion tank
- Expansion tank leaks at connect to level sensor at the bottom of the float mechanism
Lots of good pictures of the INSIDE of the expansion tank here ...
Old 06-22-2010, 08:58 PM
dms540i's Avatar
dms540i dms540i is offline
Mein Auto: 1999 BMW 540iA
You don't fix the problem by putting another OEM Behr radiator in. That just ensures you will go through the problem again. The plastic is the problem. Whether it cracks at one hose fitting or another, or across the expansion tank, or somewhere else is not the point. If you keep the car it will continue to eat radiators. After you put the third one in the Zionsville math starts to look different.
BMWCCA#401441
Old 06-22-2010, 09:12 PM
chiefwej's Avatar
chiefwej chiefwej is offline
Freude am Fahren
Mein Auto: 2003 540i/6 //m-tech
That's why I went to a zero pressure system w/ NPG+.
http://www.bimmerfest.com/forums/sho...877&highlight=
chiefwej 2003 540i ///m-tech 6-speed
Black Sapphire Metallic w/gray
Old 06-22-2010, 09:14 PM
Mack's Avatar
Mack Mack is offline
Thebizzy.com
Send a message via AIM to Mack
Mein Auto: '02 525i
Behr (OES) rad - $138 to the door from Autohausaz
Zionsville alloy rad - $690 + shipping.
I was ALL about to go Zionsville but at that price it will take approximately 5 rad failures to make your $$ back if my math is correct. It just doesn't make sense in the end. And my car made it to 120k before I replaced the rad just for general maintenance.
Mods: Shark Injected | Magnaflow Exhaust + Resonator | H&R Springs | Bilstein SP Shocks + Struts | TMS Power Pulleys
Eibach F+R Sways | BeastPower Brackets | M-Tech bumpers | Predator ICE V3 + HID Fogs | Eurodyne CF Hood | BSW Sub + Dice + spec dock
[---Quote (Originally by Tex330i)---
You can warranty a turd, that way when you have a problem you can exchange it for a new turd.---End Quote---
Old 06-26-2010, 11:52 PM
repcapale repcapale is offline
Mein Auto: 2014 535 XDrive
In this case, where exactly is the coolant leaking from?
Old 06-27-2010, 12:14 AM
chiefwej's Avatar
Freude am Fahren
If that is a 540 I would first look at the bleeder screw, next see if it could be coming from the cap.
Old 06-27-2010, 10:57 AM
I have some of that coolant residue in the exact spot. Should I be worried? It dosent look like its coming from the cap, so it must be from the bleeder screw. I replaced the water pump and thermostat a couple of months ago, will replace the rest soon. Is this residue common? Or does it mean the expansion tank is going to blow.
Old 06-27-2010, 04:54 PM
chiefwej's Avatar
Freude am Fahren
It could be just left from the last time you opened the bleeder. Rinse it away, then see if it comes back. If it does something is leaking somewhere.
Old 07-03-2010, 11:15 PM
bluebee's Avatar
In this canonical fan-clutch fan blade failure thread are some pretty gruesome pictures of what happens when the cooling system fan blades spin around in the engine compartment!
"in general the fan blades ... fail when being overtaxed by a bad fan clutch causing the fan to spin too fast and fail to disengage at high speeds"
"most often ... a fan clutch will go bad by NOT spinning fast enough ... and thus not cooling sufficiently at low speed or idle. One give-away sign of this is that the aux fan will kick in at high speed when at idle"
"Fan Clutch fails in two ways:
1. Does not operate as it should (the design is COLD: spin slowly, HOT spins faster close to engine speed to dissipate heat).
2. Becoming loose "wobble".
In the case #2, recall that the fan blade is attached to the Fan Clutch, which in turn is attached to the WP shaft.
So a bad WP bearing or a wobble fan clutch can cause the fan blade to wobble, HITTING the Fan Shroud."
ID:	236831   Click image for larger version
ID:	236832   Click image for larger version
ID:	236833   Click image for larger version
ID:	236834   Click image for larger version
ID:	236836   Click image for larger version
ID:	236837   Click image for larger version
Old 07-05-2010, 06:33 PM
bluebee's Avatar
In keeping with the picture nature of this thread showing BMW E39 radiator failures, here's one I found today looking for a solution for someone else...
The crack is right in the bend of the neck as it comes backwards from the radiator.
ID:	237021   Click image for larger version
Old 07-05-2010, 06:42 PM
chiefwej's Avatar
Freude am Fahren
That is a CLASSIC radiator failure. Exactly where mine cracked.
Old 07-05-2010, 06:58 PM
bluebee's Avatar
Here is a pic of a radiator that leaked from the cap and was replaced with a Zionsville.
ID:	237027   Click image for larger version
ID:	237029   Click image for larger version
