Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series
7 Series / 8 Series
The BMW 7 series and 8 Series Forum
Old 01-24-2010, 01:20 PM
CruiserClass CruiserClass is offline
Mein Auto: 735iL
Question Continuous chiming from 735iL when off
Hi,
A few weeks back I found that my car (I believe it's an '89 E32 735iL) started to chime in an annoying fasion when I shut it off. It's fine when driving around, but turn it off and after 5 or 10 seconds the chiming starts. You can get out, lock it, and come back in the morning - STILL chiming. Has anyone encountered this before? It was intermittant for a week or two but now it seems it's here to stay.
If you turn the lights on with the engine off you get the standard chime and "Lights On?" on the dash. This kills the chiming problem (but then of course your lights are on!). So I guess the "Lights On" state overrides whatever sensor / fault is causing the permanent chiming issue.
Any pointers would be appreciated. I can't think what sensor could be to blame because I've never seen the car do this under any "legitimate" circumstances either.
Old 01-24-2010, 04:28 PM
rrtec's Avatar
rrtec rrtec is offline
Bored Worker
Mein Auto: 1997 740i
OUt of the blue I would blame the ignition, it probably thinks the key is still in it. I dont have your particular model but my 97 740i will chime if you leave the key in the ignition after it has been turned off..
1997 740i- Daily Driver- 18" M-Pars, Depo Lighting, HIDs
1991 Mazda Miata CSP Autocross Beast. too much to list..
1999 540i M-Sport 6 SPEED- Waiting for upgrades.
2010 Mini Cooper S- Bone stock TURBO Wife's Daily..
Old 01-24-2010, 04:35 PM
Mein Auto: 735iL
I like the theory and did consider it, but I never noticed it doing that when I ACTUALLY left the key in before. This said, I'm in the habit of always removing the key and in fact locking the car even for short periods, so it's possible. I'll crack the cowel off of the column and unplug anything that looks like a sensor on the locking barrel. Cheers.
Old 01-25-2010, 08:56 AM
TxGr8White TxGr8White is offline
Sick Puppy Motorwerks
Mein Auto: BMW 850Ci
Check the CCM module. They are known to get bad solder joints.
White 1993 850Ci - 251,187 miles
Black 1993 850Ci - 125,508 miles
Old 01-25-2010, 01:06 PM
Mein Auto: 735iL
Ok, cheers. My manual should help me locate that. Do you know if it's more the connectors or the module's PCBs that get the problems?
Old 01-25-2010, 01:32 PM
Pcb
735il, beep, chime, e32, warning
