What is this part? - Bimmerfest - BMW Forums
Old 01-24-2010, 06:13 PM
Tohsen0 Tohsen0 is offline
Mein Auto: 2006 Bmw X3
What is this part?
Hello i was wondering if you guys and tell me what this part is
Old 01-24-2010, 07:08 PM
Mein Auto: 2004 X3 2.5i
Does this have to answered in the form of a question?
What is a DISA?
That's the intake resonance valve or something, next to the celebrated Idle Control Valve.
http://forums.bimmerforums.com/forum...php?p=15286987
Old 01-24-2010, 07:26 PM
Ryan M Ryan M is offline
Mein Auto: .
Yes, that is the DISA flap. It stays closed at low rpm to make the effect of long, skinny runners in the intake manifold, which help build low end torque. It opens at high rpm to shorten the path of the intake runners, making maximum horsepower. The flap gets clogged with crud after time, and may stop working as it should. It should be cleaned when you get to higher mileage.
For Sale: M60B30 intake manifold, M50 intake manifold, 2.81 differential, new OEM upper control arm bushings, 8 M62 fuel injectors.
Old 01-24-2010, 07:53 PM
I took a audio of the engine idk if it matter but its a cold start and i know its a weird request but i was wondering if the engine sounds normal? Thanks in advance for your thoughts
