Old 08-20-2010, 10:51 AM
irokdastar383 irokdastar383 is offline
Account Under Review
Mein Auto: 745li
do a test on ure cd loader and dvd loader also. if all fails its propably the radio tuner
Old 08-20-2010, 11:44 AM
TechFreak TechFreak is offline
Mein Auto: AC Schnitzer 745i Sport
Originally Posted by Has8223 View Post
will do... so the process is take the FOC out from the L7 unit and plug the MOST FOC that i buy into this? Is this correct?
Yep...correct !
My BMW ACS7
Old 08-21-2010, 11:03 PM
Yancboy1 Yancboy1 is offline
Send a message via Yahoo to Yancboy1
Mein Auto: 2002 BMW 745i
@ Has8223
The tint ppl let the fluid run down to your Voice control unit...same thing happened to me and a number of other ppl. Bypass it wit a most bus jumper and it will work fine
Old 08-22-2010, 01:06 AM
Has8223 Has8223 is offline
Mein Auto: 745i
Thanks... that sounds vey logical... which unit is the voice control unit? is it the L7 or is it the one above this?
Old 08-24-2010, 11:15 AM
Mein Auto: 745i
took the car to BMW today... in south african rands it cost R500 ($70) to fix... it was the voice control unit.... they tried to sc%$# me over but i told the technician to try what techfreak said i should and it worked like a charm... thanks to all you international BMW freaks!
Old 08-24-2010, 11:18 AM
Mein Auto: 745i
btw..heres a picture...
Old 09-01-2010, 02:56 PM
Ryan@PiTech Ryan@PiTech is offline
Mein Auto: 04 745i
Radio
New member, having the exact same problem as Has8223. I have replaced the Voice Control unit, L7 amp, tried restetting FOC ring from under the dash, jumping every module, and resetting the battery master.....With no luck. All of my speakers are popping at random times too.......
2004 745i..its killing me. I would rather not take it to the dealer and get scr3wed.
Old 09-02-2010, 07:19 AM
Mein Auto: 04 745i
Nobody? I have read just about every post on the 745i radio issues...i think i have tried about everything..anyone have any ideas?
Old 09-02-2010, 11:07 AM
Mein Auto: 745i
Had a similar problem... it is the speakers... change them....
Old 09-02-2010, 09:33 PM
Mein Auto: 04 745i
If it is the speaker, why do none of the presets show up on the am/fm, the nav screen blank and the hands-free not working? Like I said, I am having almost the EXACT same problem you had, but I have done everything you have done with no positive results. Do you think maybe i need to get the software/firmware updated or something?? I am new to the BMW world, but work on imports/domestics all day long.
Old 09-03-2010, 10:38 AM
Mein Auto: 745i
bypass the L7... if you still get sound then problem lies there. If not, do what i did, take it to the nearest bmw and let them diagnose... i was surprised because in ZAR terms it costed me R500 to fix ($70).... my speakers also pop at times, if you find a cure, let me know.
Old 09-03-2010, 11:56 AM
Mein Auto: 04 745i
I did bypass the L7 but still no presets....I am going to bite the bullet and take it to BMW.....
Old 09-03-2010, 11:58 AM
Mein Auto: 745i
That is your best bet... remember to take some KY Jelly along because thay can scr%$ you at times... Good luck....
Old 09-07-2010, 10:33 AM
Mein Auto: 04 745i
Yea, i figured they would. I co-own a shop but we work primarly on imports, domestics and bikes...Not to many vw/audi/bmw and exotics. I have also worked for dealers and i know they charge a ton of money Well, im gonna go drop it off and see what they have to say. Poor wallet
Old 09-09-2010, 08:48 AM
Mein Auto: 745i
Hi,
Did they manage to fix issue?
Old 09-12-2010, 02:12 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: Ford Pinto
Ok yesterday my nav screen froze up . After letting the car sit
for about 20 minutes I started it up & the only thing on the
screen is am , fm with no stations & the cd & cd changer are grey .
Now I have a jumper so I used it on the Voice control unit & on the NAV UNIT
& it did not change . what other unit should I try using the jumper on ???
Does any 1 in my area ( L.A. ) happen to have the software
or unit that can plug into OBD to see what's wrong ? I would
rather try that before going to the stealer & be ripped off !!!
sorry I forgot to mention that right before this happen .
I stopped at a store & I noticed that my steering wheel
stopped auto moving out of the way when turning off
the car . It was working right before that as it did move
into place when I started the car & parked earlier yesterday .
Old 09-12-2010, 10:19 PM
Mein Auto: 745i
Get a diagnosis from BMW before putting your fingers where they don't belong.... Diag is not expensive... once you know what is wrong, the rest is easy...
Old 09-15-2010, 12:48 AM
PAPER's Avatar
CRISP & CLEAN
unfortunately they can't see my car til next week
but here is a pic of the nav screen . I also discovered
that there is no red light on the most bus loop in the
glove box , nor is there a red light on the voice control
module plug in the trunk . Pic is of the tuner radio screen
& the nav screen .
ID:	246219   Click image for larger version
Old 09-15-2010, 01:27 AM
Mein Auto: 745i
My screen looked the same! Check the MOST BUs Loop in the glove box... Unplug this for a few minutes and replug... the problem seems similar to mine...one of your units is dead... if all else fails, get hold of TECHFREAK, he is the guru on the moving computers we drive! You have a break somewehere in your fibreoptics if you do not have the red light...
Old 09-15-2010, 03:17 PM
PAPER's Avatar
CRISP & CLEAN
thank you , I sent him a message .
Old 09-16-2010, 11:59 PM
Have you got the Logic 7 Amp fitted in the trunk ?
It's the most common module to fail.....try using the MOST Bus jumper that too.
You'll need to remove the trunk liner to get to it.
My BMW ACS7
Old 09-17-2010, 12:16 AM
PAPER's Avatar
CRISP & CLEAN
yes I do have the l7 in the trunk, but would that cause the screen problems
& wouldn't the front speakers still play if it was the l7 .
I will try the jumper on the L7 tomorrow .
Old 09-17-2010, 05:24 PM
PAPER's Avatar
CRISP & CLEAN
ok I looped the L7 & then the voice control module & the nav
had a red light , but there was no change to the screen & there
is still no red light in the glove box . the cd player is still the
same with only the light around the knob but does not eject the cd ,
& the changer is still the same it makes noise & if I hit eject it
still ejects the cartridge .
ANY OTHER SUGGESTIONS ???
Old 09-20-2010, 08:53 AM
Mein Auto: 745i
your cd changer is stuffed... have it checked.... what did bmw advise?
Old 09-20-2010, 02:54 PM
PAPER's Avatar
CRISP & CLEAN
BMW made me an appointment for friday .
What do you mean the cd changer is stuffed ?
