Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series
7 Series / 8 Series
The BMW 7 series and 8 Series Forum
Old 01-25-2010, 07:48 AM
michael moore michael moore is offline
Mein Auto: 1995 bmw 740il
Question Catalytic converter issues
I have a 1995 BMW 740il, american spec. I am station in south korea. I replace the converter with after market ones, plus new oxygen sensors. I assume they would be o.k. I see them on every online part store. about two month, both converters when bad. I thought maybe I had a bad brand, so I order two more of a different brand. Now they are starting to raddle and my car has lost power. This is the second time I had to replace cats less than a year. Do you have any clue on what could be causing the cats to continue to go bad? I am ordering new converter plus oxygen sensors, but not sure on where the problem really is. CAN YOU HELP?
Old 01-25-2010, 10:57 AM
TerryY's Avatar
TerryY TerryY is offline
Old Fogey
Mein Auto: BMW '95 840
Try the Magnaflow sports cats. They are supposedly durable where the standard ones are not. I seem to remember that California "certified" ones are supposed t6o be more durable also.
Terry
Aloha Oregon
'95 840Ci
'00 Range Rover Vitesse
www.wuffer.net
www.8coupe.com
www.8er.org
Old 02-07-2010, 05:20 PM
m5james's Avatar
m5james m5james is offline
Send a message via AIM to m5james Send a message via MSN to m5james Send a message via Yahoo to m5james
Mein Auto: 98 740iL - Tweaked a bit
I've got Magnaflow cats on mine w/o a single issue. There installation is critical as they can't be moved too far forwards or backwards from the original locations where the stock ones were mounted or else you'll get "cat efficiency" codes.
New here? Please visit www.e38.org, THEN you ask questions
325hp 98 740iL, black/black - Eatin 540's & $hittin 318's
PERFORMANCE:///M5 6spd conv., Iron sleeves, L/W Teflon coated pistons, 3 angle valvejob, P&P head, cams, electric fan, CF intake tube w/aluminum heatshield, Magnaflow 14816'd
INTERIOR:
Hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D, silver trim, 5% tint
EXTERIOR:19" Beyern Mesh staggered, Shadowline kidneys, Axxis pads
01 X5 4.4 - F90BT, L5
