7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
Instrument cluster menu
I have found 2 menus on the instrument cluster by pressing the trip button and holding for 15sec with the ignition on pressed once (1 menu) and then with the ingition button pressed again (a second series of menus)
The first menu goes through sensor data language, voltage etc.. items 1 to 20 The second menu (with the ignition on or in the 2nd position) goes into brake life, rotor life brake fluids etc.. Does anyone have a pdf manual on this topic. I have attached two pictures, 1 from the first menu and 1 from the second menu Thank you |
Steps to get into the second menu --> here.
White 2007 Alpina B7 Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts Black 2002 BMW E66 / 745Li (sold) KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights... |
The IDrive has a hidden Service Menu too :
Enter Service Mode of Control Display by: 1. In Basic Menu display (N,S,E,W), press down the iDrive Controller for 6 seconds. Hint: The help text flashes briefly when it is ready. 2. Turn Controller 3 increments clockwise. (Increment means click) 3. Turn Controller 3 increments counter clockwise. 4. Turn Controller 1 increment clockwise. 5. Turn Controller 1 increment counter clockwise. 6. Turn Controller 1 increment clockwise. 7. Press Controller to confirm. 8. Enter "MOST Devices" menu. 9. Browse
My BMW ACS7 ![]() |
Thank you I am going to try this now on the 750i 2006.
I could not get the Idrive version to work for me, I will now try the cluster
Thank you |
For Step 1. - try holding the IDrive controller down for 8 or 9 seconds.....
My BMW ACS7 ![]() |
Thank you for your help. Is it possible that they changed the access on the idrive controller for the 2006 model year 750. I did hold it down for at least 20 sec with the ignition on and off but I am going to recheck it.
ty again |
Guys...I tried this and my ABS light comes on for a little while then goes off...The hidden menu comes up..Is this normal?
for the life of me I cannot get the idrive hidden menu to come up on my 2006 750i. I have a build date of July 2006, and an inservice date of Dec2006. Any further assistance is appreciated.
thank you |
Back from the dead - just dropped in new cabin microfilters and noticed this same issue when doing the service reset. I did not have this come up when I did the service reset for the brakes and brake fluid a year ago. Anyone have an answer on this one? If not I will ask the tech when I take it back to the dealer in 2 weeks for their 4th try at fixing my possessed idrive controller.
Yup, it's normal.
Same thing happened to me as well. But it (Yellow ABS light ) only pops up and then disappeared.
THE ONLY STUPID QUESTION, IS THE QUESTION NEVER ASKED Beautiful car is hard find Beautiful girls are just around the corner.
Where did you get your fog light LED Halo rings from ? http://www.bimmerfest.com/forums/sho...051&highlight= Were they an easy mod to do ? Cheers !
My BMW ACS7 ![]() Last edited by TechFreak; 06-19-2010 at 03:21 AM. |
Can i reset my service light this way?
Yes, you can. First menu, you will see it.
Good luck.
![]() Yes, very very easy to do. Tapped right into the fog lights. From ebay, get the 80mm. Fitment...couldn't have fit any better.
Sorry i made a mistake with the timing for Step 1 .....here's the official sequence from BMW :
Service functions The controller can be used to activate Service mode. Service mode provides access to details of the hardware/software versions for the control display and the control units in the MOST network, for example. Service mode provides a simple means of quickly accessing diagnostic data without the need for a diagnosis tester. Activating Service mode: 1. With the basic menu active, press and hold down the Controller for at least 10 seconds. 2. Turn Controller three increments clockwise 3. Turn controller three increments anti-clockwise 4. Turn Controller one increment clockwise 5. Turn Controller one increment anti-clockwise 6. Turn Controller one increment clockwise 7. Press Controller down. If the function "MOST Devices" is selected, a list of all MOST network nodes is displayed. When a control unit is selected, a scrollable list detailing the following information appears: Item number, hardware number, coding index, diagnosis index, variant index, date of manufacture, manufacturer, message catalogue version, software version and operating system version. The function "Settings" provides access to the following service settings: Activate/deactivate audio system RDS (Radio Data System) function Log on cordless handset. To exit Service mode you select the arrow symbol in the bottom left corner of the screen.
My BMW ACS7 ![]() Last edited by TechFreak; 06-20-2010 at 03:49 AM. |
Any danger you could PM the mod info too ![]() Cheers |
What danger ? Nothing to it. Just tap wires to the fog lights.
But now you're hijacking the thread... Let's get back to instrument thing...
I think what you have to do is add up the last 5 numbers of your VIN
And hold the button down and move down to unlock and pit the added number in. That shod allow you access to what you need. |
anything I am doing wrong?
#25
Go down to "19 - Unlocking", hold the trip meter until it prompts you on the other gauge for the code, add up the last 5 digits of your VIN (mine: DR06717 = 0+6+7+1+7 = 21) ...tap the trip meter button until you get to that number, then push and hold it again until it brings you back to the main menu. You should now be able to get to the other items in the menu.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
