Smelling A/C when turning on - Bimmerfest - BMW Forums
Old 09-12-2015, 01:18 PM
pise81 pise81 is offline
Mein Auto: 2007 BMW 750i
Angry Smelling A/C when turning on
I got a problem, and it's not about me this time
When I turn on the A/C the first time i jump inside my car after work, it smells bad. Initially, I thought it was the upholstery, but it's not. The smell sticks around for about 30 sec, then it goes away.
Anyone experience this at all? Please help!
Old 09-12-2015, 01:53 PM
Ltmax's Avatar
Ltmax Ltmax is offline
Mein Auto: 2008 750l
Every one of the 4 750's I've owned did the same thing, I think it's the foam insulation or plastic they use in the a/c system breaking down. No matter what I've tried I can't completely eliminate the odor on start up. Tried every flush, cleaner, and deodorizer I could think of and nothing worked more than a few days. Originally thought the drains were clogged but that wasn't the problem.
If you can figure it out, let us know.
Old 09-12-2015, 02:55 PM
Rick in Yuma's Avatar
Rick in Yuma Rick in Yuma is offline
bimmerfest Supporting Member
Mein Auto: 05' 760li,94' H1,08'Smart
Both you members are in very wet humid areas. I'm wondering if we have some type of mold growing in your AC system. This has been a problem in other vehicles. There is some products out there to cure this. I would talk with one of your local shops. To see what they're using on vehicles in general.
As we only get 3 inches of rain a year. I don't know what the product name is....no great need for it here.
Old 09-12-2015, 04:06 PM
The Magus's Avatar
The Magus The Magus is offline
BMW Enthusiast
Mein Auto: BMW 760Li (2008)
Seattle has been bone dry all year, Rick.
My ac smells, but it goes away in about a minute. What about using non-chlorine bleach in a vaporiser.
http://www.marianresearch.com/images/SigPicMay2015.jpg
Old 09-12-2015, 04:11 PM
Marcelo11 Marcelo11 is offline
Mein Auto: 2006 BMW 750i
I think this problem is specific to humid areas like where I live. If you run the A/C all the way home and abruptly turn the car off, it seems that it leaves good conditions for mold to grow in the ductwork overnight and you get that awful smell the next time you start the car and run the ventilation.
There are a couple of things you can do: 1. run the heater at full power as you get home and shut off the ventilation system and leave the hot air in the ducts. The heat kills the mold for a little while and you have to repeat often. 2. As you get close to your destination, turn the A/C off and let regular air circulate in your ducts for 5 minutes and this will prevent mold from growing in your ducts.
Old 09-12-2015, 04:28 PM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
I used a long plastic tube I bought at Home
Depot to get the AC cleaning spray
deodorizer as far inside as I could . It was
the plastic tube you use when hooking up
The water & ice maker on your refrigerator
. I used almost 2 cans & it's been all good
since about June
Old 09-12-2015, 07:28 PM
No such thing as dry in Seattle.. Your humility was at 44 to 66% today.. I don't think I would put anything except approved air-conditioning solution in the system. God knows what chemical reactions might occur with something else.
Old 09-12-2015, 08:09 PM
dvanlare dvanlare is offline
Mein Auto: '95 E31, '05 E66, '15 F02
I did a temporary assignment up in Portland, OR for about a year and brought up one of my cars from AZ. Within a few months it started to smell like mold. After bringing the car back to AZ it mostly cleared up but was never quite the same. It's definitely the higher humidity there. Make sure your A/C drains are clear first and try some of the treatments other have suggested.
Old 09-12-2015, 08:52 PM
usdrake1fallen's Avatar
usdrake1fallen usdrake1fallen is offline
760 is BAE
Mein Auto: 760Li
I did the same thing paper did and it cleared the issue right up. Long tube and a bottle of ac safe ac cleaner and the issue has been gone for 3 months now. All parts bought at home depot.
http://www.homedepot.com/p/AC-Safe-A...-920/100599017
current: 2013 jeep wrangler jk / bmw 760Li - new passenger HPFP diaphram replacement with 19,158 mls on replacement from magna fuel !!!
CODED
past: 2002 ford tarus / 2005 suburban z71 / 2005 Tahoe z71 / 2004 760li / 2008 silverado.
ford sucks chevy's rule and Mercedes drools
Old 09-12-2015, 09:00 PM
PAPER's Avatar
CRISP & CLEAN
Old 09-12-2015, 09:21 PM
PAPER's Avatar
CRISP & CLEAN
This is what I used from Napa auto
http://www.napaonline.com/Catalog/Ca...523_0483033803
Old 09-13-2015, 12:46 AM
Thanks alot guys, i really do appreciate ur inputs, sounds like the a/c air cleaner might be a good option here, i'm gonna give it a shot and hope that fixes it.
Old 09-13-2015, 04:50 AM
AActive AActive is offline
Mein Auto: BMW X3 e83LCI
You need to run an ozone generator in the car.
Youve got mold .mildew in the ducting ( bacteria ) causing the smell.
You run the ozone machine for 30 min inside the car . On recycle. Replace the cabin filter with a carbon type. Make sure ac drains are not blocked. Do this every 6 months. Its the only remidy with out chemicals.
Ozone kills bacteria, ozone is used to senitize hospitals to hotel rooms and even drinking water in third world countries.
Its also harmhul to humans though so make sure its aired out properly befor driving.
Good luck.
Old 09-13-2015, 09:47 AM
I've looked at some Of the Ozone Generator online, there are some for the car too, but I'm a little skeptical about those ones, they're kinda tiny, not sure if it will do the job. However, the big one is kinda expensive, is there one that u recommend AActive?
Old 09-13-2015, 10:13 AM
I bet the use of an ozone generator will turn all the parts in your interior into dust.
Old 09-13-2015, 01:18 PM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 328GT/740LI/750LI
13 740LI W/Msport package. Executive Package
DRIVER ASSISTANCE PKG, HUD,
OYSTER; NAPPA LEATHER SEAT TRIM,
Lane departure, blind spot detection,
Collision Mitigation,
Side & Top View Cameras
Aftermarket Rear entertainment
Old 09-13-2015, 01:44 PM
This is MWS's video on his ozone treatment of his M6. It didn't do any damage to his car. The prior owner was a smoker,and used cologne to mask the smell. Seems to have worked for him.
Old 09-13-2015, 08:31 PM
We use a Cliplight The Purifier, its specifically for Automotive, it is expensive though.
It does come with a wall charger and I have used it in small rooms as well.
a/c, bad smell, odor, smelly
