Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series
3 Series & 4 Series
The BMW 3 Series and 4 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 10-10-2003, 08:27 AM
jk330i jk330i is offline
Ripening slushbox drifter
Send a message via AIM to jk330i
Mein Auto: 2002 330i OB
Engine clicking noise all of a sudden--HELP!
I noticed this morning as soon as I started the car I heard Engine ticking noises. I thought it might have been due to the factor it was cold, however, even after 5 minutes of warming up the noise didn't go away.
When I stepped on the gas, the noise seems to diminish and come back again during idle. When I popped open the hood the noise seemed to grow even more apparent. I drove it to my destination which is 2 miles away, and about 10 minutes later I got out of the car and checked again for noises. Same thing...."click click click". I had an oil service done 2 weeks ago and haven't noticed any noises until now.
Pls advise. thanks.
Old 10-10-2003, 08:33 AM
JonW's Avatar
JonW JonW is online now
blubb blubb blubb
Mein Auto: '01 325xi & '93 325is
Check you oil level. I think low oil can make the valves click like that. But it could be other things as well.
Old 10-10-2003, 08:54 AM
But I just had an oil service done 2 weeks ago... any other thoughts? anyone?
Old 10-10-2003, 09:00 AM
JonW's Avatar
blubb blubb blubb
Just because someone changed your oil does not mean it was done properly. I'd say have a look at the dipstick.
Old 10-10-2003, 09:11 AM
operknockity's Avatar
operknockity operknockity is offline
My TARDIS is a BMW
Mein Auto: '02 325i
The likelyhood is that the oil change was done correctly, but it only takes a minute to check it and eliminate a possible source of the problem. Besides, once you are under the hood, you might notice something else amiss which might be the real problem. I can't tell you the number of times I've popped the hood to find bolts that weren't fully tightened or air filter cover latches that weren't latched.
How many posts could a repost post if a repost could post posts?
Old 10-10-2003, 09:32 AM
Artslinger's Avatar
Artslinger Artslinger is offline
BMW + twisty road = fun
Mein Auto: Car
Check the oil cap. Sometimes they forget to put it back on. Its happened to me twice (never with the BMW), now I make it a point to check after every oil change.
Old 10-10-2003, 09:39 AM
okay I'll do that and all the other things mentioned above. The funny thing is the biggest peeve of mine is service negligence on their part. I forgot to mention that on my oil service 2 weeks ago they forgot to re-cap my tire valve stems after checking air pressure. I had to go back and get some worn out old ones that were laying around.
And this was at Crevier BMW... surprise!
Old 10-12-2003, 04:51 AM
blackhawk77 blackhawk77 is offline
Mein Auto: 330Ci
Suspicious that it happened soon after an oil change.
Maybe they serviced it with the wrong oil......
2003 330CiA. Japan Rot, Sand Leather, Premium Pkg, Htd Seats
__________________________________________________ ________
The power of accurate observation is commonly called cynicism by those who have not got it.
George Bernard Shaw (1856-1950)
Old 10-12-2003, 05:53 AM
xspeedy's Avatar
xspeedy xspeedy is offline
mmm... carbs!
Mein Auto: 2007 E90 335i
Someone stole your engine and replaced it with an obsolete diesel
Old 10-12-2003, 07:11 AM
My TARDIS is a BMW
Mein Auto: '02 325i
After one service on my old car, the oil dipstick was not put back. I didn't notice it was gone but when I took the car in for a smog test a couple of weeks later, they wouldn't pass it because of the missing dip stick. Argh!
Old 10-12-2003, 09:52 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
i've heard that ticking noise on my 330i before, and it was the oil level. was about 3/4 of a quart low.
and the reason it was 3/4 of a quart low was because i just brought it in for service a few weeks prior.
i have a feeling they just put in however many whole bottles of oil (6 or 7, i cant recall at the moment) and leave out whatever fraction. it would be a pain for them to deal with half empty bottles of oil.
now that prior statement is totally negated if they use bulk oil to fill. I've never seen them actually changing the oil so i have no clue if it comes from bottles or a bulk dispenser...
Old 10-12-2003, 10:38 AM
The HACK's Avatar
The HACK The HACK is offline
Rest in peace, Coach
Mein Auto: '06 MZ4C, '09 WRX Wagon
Service department don't carry "bottles" of oil. They have these giant 50 gallon drums of oil that they pump into the engine compartment.
"Bench racing" about track times driven by professionals are like a bunch of nerds arguing which Princess Leia is hotter, the slave Leia or the no-bra jail-bait Leia. No matter how compelling your argument is, the plain and simple fact is, none of you will EVER get to hit that.
Old 10-12-2003, 01:26 PM
that makes sense. how do they measure out the oil though? i've had two oil services and both times i was short about 1/2 to 3/4 of a quart when i checked.
