E90/E91/E92/E93 (2006 - 2013)
Old 01-29-2010, 02:25 PM
plo335ICPE plo335ICPE is offline
Mein Auto: 2010 335i Coupe
e92 Weak heater
Ok, so last night did my 70mile trip home from the Indy airport where my car hit the 2k mile mark. I ordered this car back in September, waited a grueling two months and picked her up on Nov 2. I've got to say that so far I am having a blast. The car looks and sounds great and performs better than I had even anticipated. I came from a 2003 325i so while familiar with BMW the performance on this is leaps and bounds above.
It is not all roses though!
Not sure if this is a general 2010 e92 issue or issue with my car. Granted when I got the airport last night and started it up it was about 10F outside and by the time I got home it was ~7F but the car never really warmed up. Oil was up to temp but inside heating temp was the problem. In the e46 you could cook a turkey in the cabin if you wanted to. This one is weak when it comes to temperature and had it not been for heated seats and wheel I would have been downright cold. I did everything I could think of with the settings but nothing seemed to help. This is the second time under really cold conditions that I notice this. Anyone else in a northern climate have this problem or should I take it in to be checked?
I hate winter!
Old 01-29-2010, 02:35 PM
johnc_22's Avatar
johnc_22 johnc_22 is offline
Squeal like a BMW
Mein Auto: 2007 E90 335i
You put the red/blue dial on red, right?
Then again 7F is pretty cold.
ED 03/30/2007 - e90 335i - Titanium Silver, Black Leather, Burl Walnut, 6MT, Premium, Sport, Cold Weather, Nav/iDrive, Comfort, Sirius, PDC
VPC 5/1/2007, Redelivered 5/15/2007.
HPFP Replacements: 1 (2010-04-22 - 943)
Old 01-29-2010, 03:35 PM
DSXMachina's Avatar
Automaticallyparsinglinks
Hi plo. There has been negligible mention of HVAC cabin heating problems with the E9x. I have an E92 and get more than adequate heating within 10 minutes at temperatures similar to what you report.
When you call your SA you should have factual info available, otherwise they might think you are on blood thinners or don't know what you are talking about. Here's what to do; set your temp dial to the maximum temp, set your system to 'vent', be sure the dial is set to the red zone on the upper dash, set the fan speed to the second speed from low. Drive the car and measure the exact vent output temperature.
That is the method specified by all mfrs. for checking heater output, Your thermometer should read at least 140 and ideal would be 160F. Don't let them tell you that it isn't working to spec because "it's too cold out". That's BS, the thermostat guarantees a minimum engine temperature and that's where all the hot coolant for the heater core comes from.
Try the test I described and let us know what you get.
Old 01-29-2010, 03:39 PM
DJEcLeCTiK's Avatar
DJEcLeCTiK DJEcLeCTiK is offline
Gentleman Extraordinaire
Mein Auto: 2009 E92 335i
2009 E92 335i xDrive (Ordered 3/21/09 / Completed 5/4/09 / Delivery 6/6/09)
Space Gray Metallic / Black Dakota Leather / Gray Poplar Wood Trim / ZPP / ZCW / ZSP with 18" wheels / StepTronic / Navi+HD Radio / Logic 7 / iPod+USB / PDC / Anti-Theft
Old 01-29-2010, 07:04 PM
AzNMpower32's Avatar
Tar Heel Faithful
Send a message via AIM to AzNMpower32
Mein Auto: X3
Did you have the climate control on automatic? Additionally, it helps if the centre vent dial (underneath lock button) should be at middle or to the right/red.
Old 02-01-2010, 06:51 AM
Thanks DSX. I noticed over the weekend that when I hit the MAX button no light comes on. I am pretty sure we have a problem. I am calling the SA to make an appointment and will run your test beforehand to make sure i go in with some solid ammo. I appreciate your advice.
Old 02-01-2010, 07:38 AM
DSXMachina's Avatar
My guess is that they are going to be replacing the Control Head. That's the box directly behind the control panel, which is part of the control panel. It contains the HVAC computer and drivers.
It's relatively easy diagnostics, and a fast job. The part cost would choke a horse but you won't be paying...
The dealer is very unlikely to have the part in stock so be prepared to have a loaner for a few days.
Let us know what happens.
Old 02-04-2010, 12:47 PM
I stopped by and talked with my SA on Tuesday while cold outside but the car up to temperature. SA gets in and gives me a resounding, yes, we have a heating problem and we set up an appointment to drop the car off today and put me in a loaner. By noon he's calling me telling me that they checked it on the computer and no faults or issues are showing up and the tech looked at it and it was heating correctly. Wants me to pick it up and tech will go through proper operation of the heating system (WTF!) Loaner he puts me in is a 2010 328 vert. Heating system is identical to mine. I set it at max temp and after 2 minutes I am cooking. Hit the MAX button and lights up, and makes adjustments to the settings. Works as you would expect. I don't have a PhD in HVAC but I know how to work a car heater!
So he calls me a while later and tells me to disregard the previous conversation. He took it out of the bay and fiddled around with it and agrees it isn't working right. He will call me back with a report later today.
Annoys me that we can sit in it one day and we are in complete agreement that we have a problem but because they hook it up to a computer that reads no problems, they dismiss it.
Old 02-04-2010, 01:06 PM
DSXMachina's Avatar
That's exactly why I suggested you have temperature data to whack the SA over the head with. I have heard this story so many times, "the computer says there is nothing wrong with it." Then how come you're freezing your *ss off?
I knew you were going to hear the "let us show you how to work it" BS!
PS I bet they don't give you a vert if you bring your car in in July!
Old 02-04-2010, 01:28 PM
You were absolutely correct. But when I stopped by earlier this week and he was in such wild agreement I though that would be enough. For crying out loud, it is obvious! Chalk it up to lesson learned.
and your right, he was probably LHAO when he handed me the keys to the vert while the snowflake symbol is on in the dash!
Old 02-04-2010, 04:13 PM
DSXMachina's Avatar
The b*st*rd!
Old 10-03-2012, 11:08 AM
kuleinc kuleinc is offline
Mein Auto: 94 325i, 95 332ti
Curious what they did to resolve this issue...
Boston Green 1994 325i Saloon (wife's)
1987 Vanagon
Old 10-03-2012, 01:28 PM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 09 335Cabrio zsp/11 335d
I've never had an issue, then again 30 degrees is really cold for me to be out driving in. N4S
cwp, e92 6mt sapphire/black, ipod, pp, sp
