E36 (1991 - 1999)
Old 01-29-2010, 06:30 PM
ilovemybimmer95 ilovemybimmer95 is offline
Mein Auto: 1995 BMW 325i Convertible
1995 325i convertible top problem...
The people I bought it from apparently took the motors out or disabled them in some way. Now the top has to be put up and down manually. When I'm driving and I hit a bump the windows roll down about 2 inches like it's going to put the top down. Any way to fix this? They told me to find the "sensor" that makes the windows go down for the automatic top.. idk if they were completely sure of what the were talking about though.
Old 01-30-2010, 02:27 AM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Lots of help available here:
http://forums.bimmerforums.com/forum...play.php?f=207
http://forums.bimmerforums.com/forum...d.php?t=692443
http://forums.bimmerforums.com/forum...d.php?t=684992
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 01-30-2010, 03:11 PM
didn't really find anything about my problem in any of those... My windows drop a couple inches when I hit a bump.. I hear some kind of motor sound and they drop 2 inches like the top is going to go down.. anyone know how to fix this?
Old 01-30-2010, 06:03 PM
dc_wright's Avatar
Could be a number of possible causes. Need to know if you have the semi-auto or fully auto top. If you have the semi-auto top, you have to release the handle at the front of the top and push the front of the top up to start the top retracting. If you have the fully auto top you just hold the button down.
Old 01-30-2010, 07:35 PM
Hellawut??
Mein Auto: who knows?
yes.... Dc is correct....
Search about re Syncing your top....
how do you manually put your top down and up? explain this a little
-Franklyn
Old 01-30-2010, 08:02 PM
I'm not sure on the top being fully or semi auto... to put it down I just relaese the lever above the rear view and push it back. then lift up the back window part, then the stow away compartment and push it all in. the close the stow away.
Old 01-30-2010, 08:17 PM
Hellawut??
okay you have a fully manual top.
i think
when you want to put your top down.... do you roll down your windows.. then do the lever then put it down?
or are the windows automatic?
-Franklyn
Old 01-30-2010, 08:30 PM
i just bought this car 2 days ago.. there is a button to make the top go down. it used to be automatic but they disabled it or something... idk... when the button DID work.. when you pressed it the windows went down about 4 inches.. so it used to be automatic.. but now it isnt... make sense? lol
Old 01-30-2010, 08:34 PM
Hellawut??
yes.... research the resync for the convertible top... should help...
do it and report back
-Franklyn
Old 01-30-2010, 08:52 PM
will do. I'll have to wait til I don't have 4 inches of snow covering my car though. haha
Old 01-30-2010, 08:54 PM
Hellawut??
okay cool dude... why were you trying to put the top down in 4 inches of snow!! lol
any pics of the car??
color?
any mods?
-Franklyn
Old 01-31-2010, 08:11 AM
dc_wright's Avatar
You've got the semi-automatic top.
The windows going down the 2 inches could be either related to the convertible top or you could have a problem with the master window switch that controls all 4 windows simultaneously.
For the top controller to command the windows down, the handle above the rearview has to be released and the front of the top pushed up enough to switch micro switch S4 (see attached PDF file) while the top switch is sumultaneously held. Seems like too many things would have to have gone wrong all at once for this to be causing your window issue.
I think it's more likely you've got a problem with the master window switch or the wiring to it.
Old 01-31-2010, 08:23 AM
ViNNIE_G ViNNIE_G is offline
Send a message via AIM to ViNNIE_G
Mein Auto: 94 325ic 2007 bmw 335i
i have a video on how to resynic let me get it
Old 01-31-2010, 08:26 AM
this helped me hope it helps you
Old 02-11-2010, 07:11 PM
bighappy bighappy is offline
Mein Auto: E36 325I CABRIOLET
convertible top
i ran into the same problem which i caused.. you seem to have the motors set to manual which is done by a lever under your rear seat driver side, wen pulled. to reset u have to do it manually, heres a link that i found helpfull its a bmw pdf manual hope it helps....
http://www.freeautorepairmanualz.com...e-top-bmw-e36/
Old 06-06-2010, 04:30 PM
Hellawut??
Convertible top problem
-Franklyn
Old 06-21-2010, 11:01 PM
Irrgang Irrgang is offline
Mein Auto: BMW 318i convertible
same thing happens to me when i hit a bump
not sure how to fix it let me know if you figure it out
Old 06-21-2010, 11:06 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
The fix for the windows dropping at random and when going over bumps is to replace the door microswitch. A quick search for that will turn up a ton of threads.
Good luck.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 05-29-2011, 04:31 AM
TonkaGA TonkaGA is offline
Mein Auto: 94 E36
If this was a door microswitch problem, wouldn't the action be isolated to one window? I had the same thing happen to me last night, twice. All four windows rolled down about 2" and stopped. I looked for a microswitch on the top and top edged of windshield, but didn't see one. I have a manual top from the factory btw. No top motors.
Old 05-29-2011, 01:16 PM
dc_wright's Avatar
If it was the door microswitch the window wouldn't drop more than about 1/2" and it would only be one door. Seems like there's an issue with the switch in the console that controls all 4 windows, or the wiring going to/from that switch.
Old 05-29-2011, 02:40 PM
Mein Auto: 94 E36
That's what I was thinking. Was doing some poking around different places and was wondering if the microswitch for the top cover may be a problem. I know it's only supposed to operate when the driver's door is open, but have to start somewhere When the key is on, driver's door open and convertible top cover opens, the windows all drop a couple of inches.
Was also wondering if it could be the relay that this micro switch sends a signal to.
I found this post and one on another site which both had the same problem. Hoping maybe they had found answers that might lead to solving my problem. I can replace the switch, which is easy enough, but would like to make sure that it fixes my problem.
94 318iC
Old 02-27-2013, 11:39 AM
RTMiller RTMiller is offline
Mein Auto: 1995 325i
New to this forum and want to thank Vinnie G.for that awesome video about resynching,,very informative,So I did that and found that something got seriously jammed when owner was trying to make top go back up,I believe it is the rod that controls the tunnel latch cover where it slips on the post. before I got the motors synched I noticed the arm off the T.Latch cover mechanism so disengaged it and slipped it back on not very easy to do and noticed the post did not have the same amount sticking out all around but went with it anyway then went through the Vinnie G. video process and bamm it worked then went to go through the open and close process again and it jammed up so much that I had to take off the tunnel latch cover to get in trunk ,once in trunk just disengaged latch cover mechanism and closed top and left it alone,,,Any ideas, thoughts or help is greatly appreciated.
Old 02-27-2013, 02:31 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Tonneau*
Please use sentences and punctuation marks. It also helps to space out your thoughts so they are easier to read.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
