Oil level low.. but IDrive not saying so? - Bimmerfest - BMW Forums
Old 01-31-2010, 05:27 AM
ajp166 ajp166 is offline
Mein Auto: 330ci m sport
My 2004 645 is not sounding healthy and when I checked the oil it is just below the minimum mark on the dipstick....
Is this normal or should the sensor tell me its low? I checked my oil when the car was fully warmed up etc.
I will buy some oil today, would this be ok? castrol 0w-30 fully synthetic oil?
Old 01-31-2010, 10:13 AM
docpaulo docpaulo is offline
Mein Auto: 07 650i Convertible
you should check oil on a cold engine... so your oil level may be ok...
at least thats how it is with my other cars....
---- EDIT ----- manual says to check with the engine warm....
07 650i Cabrio CPO, Titanium Silver
Black Matte Grill
Dark Birch Wood Interior and Shifter
HUD, Cold Weather and Sports Package
Logic 7 Sound
Aluminum Racing Pedals
K&N Air Filters
Rays Master Piece REM 20" Forged wheels w/ Conti Extreme DWS
Old 01-31-2010, 10:24 AM
NWS Alpine NWS Alpine is offline
Mein Auto: 650i
I believe the manual specifically states the engine has to be at operating temp or warm. Not sure. The newer 6er models don't have a dipstick so we have to rely on the iDrive.
2006 650i - SMG - Alpine White / Chateau
Mods: OEM style 249 19" rims, H&R 10mm front spacers and 12mm rear spacers, KW v3 coilovers, Magnaflow exhaust (x-pipe, mufflers, resonator delete), RPi scoop, BMC filter (charcoal delete), LED angel eyes, 30% tint, OEM iPod interface, AC Schnitzer aluminum pedals, black kidney grill
Old 01-31-2010, 10:31 AM
Luckily i tested on hot and cold... was close to min.... now topped up sounds like a V8 again!!!
Old 01-31-2010, 10:34 AM
I'm new to the 6 so I really don't know too much about it... but with other cars you check the oil with the dipstick cold...
the dipstick checks the oil level in the pan, once you start the car, the oil leaves the pan and goes into the rest of the engine... so if you're expected to warm it up, I would leave it sitting for half an hour with a warm engine before checking to allow the oil to go back in the pan...
with an electronic dipstick I'd think it can be sophisticated enough to compensate for this, but with a manual dipstick, I doubt it's that smart... I've only checked it while running on the road and it came back normal... but I doubt engineers anticipate people to check a manual dipstick with a running car..
I'll defer to the experts on this...
do we even have an oil pan? I know some newer high performance cars don't....
Black Matte Grill
Logic 7 Sound
K&N Air Filters
Old 01-31-2010, 10:36 AM
back to your question, ideally idrive will let you know.. but not sure how the 645 differs from the 650i if your dipstick is manual... with an electronic disptick I would think it will let me know..
Glad your V8 sounds normal again...
Black Matte Grill
Logic 7 Sound
K&N Air Filters
Old 01-31-2010, 04:45 PM
I have the 645 with smg which is quite cool...
In the bmw book it does say to check the car when its at running temp....
Old 01-31-2010, 05:23 PM
TXT650i TXT650i is offline
Mein Auto: 650i
Originally Posted by ajp166 View Post
..........In the bmw book it does say to check the car when its at running temp....
But not with the engine running!
http://i45.tinypic.com/mcw7td.jpg
Old 02-03-2010, 12:48 PM
Mein Auto: 650i
Mine will not take a reading unless the car is running and at temp. I actually got a low oil warning yesterday. It even had a warning message saying that the ignition had to be on. I tried turning it on without starting it with a single press of the start button and it didn't take a reading. I purchased the BMW kit you can velcro to the side of your trunk to hold a quart of oil. Put it in and all was fine and dandy. I highly recommend this for everyone. Very cheap and protects you if you are on the road and away from any sources for the right oil. It's normal to need a quart inbetween a the 15K service.
This is the kit I am talking about (comes with paper funnels, gloves, and wipes) http://accessories.bmwusa.com/ItemVi...&productId=368
Old 02-03-2010, 06:03 PM
jamie645ci jamie645ci is offline
Mein Auto: BWM 645Ci
I think it is always best to check the oil level manually every couple of thousand miles
Old 02-03-2010, 06:20 PM
Mein Auto: 650i
I would agree but it's not possible in the 650.
