Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series
7 Series / 8 Series
The BMW 7 series and 8 Series Forum
Old 01-31-2010, 07:36 PM
rrtec's Avatar
rrtec rrtec is offline
Bored Worker
Mein Auto: 1997 740i
Exclamation Aftermarket HID install
I have been searching all over the internet and have found some serious conflicting information.
I bought an aftermarket HID kit a while ago (H1) and am thinking of installing it in the 740i (1997).
All the links I see for this install are of retrofitting OEM lighting. Even with the OEM retrofit I have seen some people end up with errors on the display (bulb failure) ect..
Has anyone done an aftermarket HID install? If so what have the results been. My headlamps have the projector for the low beam..
I will post up the install when I do it, unless I find a reason not to install these..
1997 740i- Daily Driver- 18" M-Pars, Depo Lighting, HIDs
1991 Mazda Miata CSP Autocross Beast. too much to list..
1999 540i M-Sport 6 SPEED- Waiting for upgrades.
2010 Mini Cooper S- Bone stock TURBO Wife's Daily..
Old 02-04-2010, 06:45 PM
rrtec's Avatar
Bored Worker
Did the conversion. Went great, no error codes ect... Im really happy.
ID:	217254   Click image for larger version
ID:	217255   Click image for larger version
Old 02-04-2010, 07:37 PM
TxGr8White TxGr8White is offline
Sick Puppy Motorwerks
Mein Auto: BMW 850Ci
I used a pair of HID Slim ballasts with the resistor pack to prevent the error messages. works very well
Check here:
http://cgi.ebay.com/ebaymotors/BMW-H...item4ce9098e57
http://cgi.ebay.com/ebaymotors/Repla...item35a161a8fe
White 1993 850Ci - 251,187 miles
Black 1993 850Ci - 125,508 miles
Old 02-07-2010, 02:46 PM
rrtec's Avatar
Bored Worker
Well the error codes started today. I guess I will have to buy the resitors... huh.
Old 02-07-2010, 02:49 PM
Before I installed the resistor packs, I was going through bulbs like there was no tomorrow - since the packs were put in, I have had absolutely no problems whatsoever, and have not had to replace any of the 4 bulbs.
Old 02-07-2010, 05:07 PM
m5james's Avatar
m5james m5james is offline
Send a message via AIM to m5james Send a message via MSN to m5james Send a message via Yahoo to m5james
Mein Auto: 98 740iL - Tweaked a bit
BMW needs resistors to stop the messages. I ordered my conversion kit from www.hidextra.com for $60 shipped using coupon code "besthid-m" and they'll give you free resistors if you ask for them. Maybe you can buy another set for your foglights and ask them to send you two pairs of resistors.
New here? Please visit www.e38.org, THEN you ask questions
325hp 98 740iL, black/black - Eatin 540's & $hittin 318's
PERFORMANCE:///M5 6spd conv., Iron sleeves, L/W Teflon coated pistons, 3 angle valvejob, P&P head, cams, electric fan, CF intake tube w/aluminum heatshield, Magnaflow 14816'd
INTERIOR:
Hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D, silver trim, 5% tint
EXTERIOR:19" Beyern Mesh staggered, Shadowline kidneys, Axxis pads
01 X5 4.4 - F90BT, L5
