Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series
7 Series & 8 Series
The BMW 7 series and 8 Series Forum
Old 01-26-2010, 01:51 PM
bmw russ bmw russ is offline
Mein Auto: 1997 740 il
97 740iL - Burning oil, cly #6,7,& 8
hey guys whats up.
I'm screwed!! my #6, #7, and #8 cylinders are burning oil. Plugs are Wet with oil. Car was fine, them just started blowing smoke. What am I looking at? Think maybe a blown head gasket? both sides at the same time is rather ironic no. Any ideas would be great.
thanks
B R
Old 01-29-2010, 12:05 PM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
Mein Auto: 2001 740i
its quite possible the spark plug tube seals are bad and leaking. thats really the only way they will get oil fouled. most likely you will need to replaced the tube seals along with the valve cover gaskets.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
Old 01-31-2010, 11:34 AM
Thanks Cody I''ll check that next.
This is what I'm into, I took off the Intake mannifold and found it loaded with oil. It looked as if someone purd 1/2 qt in it. I changed out the oil separator valve on the back of the manifold, thinking this was the cause of this problem. I cleaned out all and any oil i could get to inside the intake. I started the car and let it run for about 1 1/2 hour and the smoke went away. Car sat for two days. Just took it out and it started smoking again. What would cause the intake mannifold fill with oil?
Thanks for your input
bmw russ
Old 02-01-2010, 03:33 AM
usually the OSV like you changed out would solve that problem. i dont know why the intake would be getting excessive oil build up besides the OSV. the spark plug tube seals would not cause it to get oil into the intake. but it could be multiple problems which it sounds like. might want to talk to M.Wong, he's quite knowledgeable with the E38. he gives great advice.
*Der E38*
manufactured: 7/01
