Old 02-03-2010, 05:33 AM
TimDogg's Avatar
TimDogg TimDogg is offline
Who u r, u r forever....
Send a message via Yahoo to TimDogg
Mein Auto: 2004 645ci 2008 535i
slight clicking/popping noise
Getting a slight clicking/popping noise when i turn the steering wheel from side to side. It can be heard outside the car as well, coming from behind the wheel in the area of steering components, (not coming from wheel components i don't believe).
Every couple of months i just wait for a new issue to arise---HERE WE GO AGAIN
Yes, I collect stamps....PASSPORT STAMPS!!!
Red 1998 Ferarri 355 Berlinetta F1, Black 2004 645ci, Space Gray 2008 535i
Old 02-03-2010, 08:44 AM
hainguyen281 hainguyen281 is offline
Mein Auto: BMW 645ci
I had similar issue about 2 years ago. The dealer replaced the steering column and it went away. Not sure if this is the same problem you have, but my clicking noise was pretty low and it has to be completely quiet to hear it.
I had it fixed under warranty.
Old 02-03-2010, 05:25 PM
TimDogg's Avatar
yeah, it needs to be pretty quiet to hear it, steering column sounds about right.
thanks for the info!
Old 02-03-2010, 06:01 PM
jamie645ci jamie645ci is offline
Mein Auto: BWM 645Ci
have you opened the bonnet (hood) & seen anything unusual?
Old 02-03-2010, 07:32 PM
croasdail croasdail is offline
Mein Auto: 645 Ci Convertible
I had the same problem after BMW did some from end work on the car. They had to take it back in and did something. It wasn't regular, had to take the service manager for a ride for about 20 minutes before it showed itself. When he heard it, he knew exactly what it was. Early 7 series has same issue as well. I believe it was a tie rod or something like that out of alignment - slightly installed wrong that made it happen. Nothing dangerous, but annoying to say the least. Oh, mine also acted up more when there was a passenger along with.
For what it is worth.
Old 02-03-2010, 08:56 PM
TimDogg's Avatar
nothing unusual under the hood!!!
taking it in to have it looked at, it duplicates the problem pretty well so it should'nt be too hard to diagnose....
