Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 02-05-2010, 12:20 AM
philp123 philp123 is offline
Mein Auto: 1988 BMW 528e
528E rear defroster
I have a 1988 528e, whose rear widow defroster is currently not working. When I push the defrost button, it's light actually turns off. Any ideas on how to diagnose this?
Old 02-05-2010, 12:34 PM
catso's Avatar
catso catso is offline
catso
Start with the fuse, then go through the wiring. Use a voltage tester. Your accessory battery connections might be corroded.
Old 02-17-2010, 02:19 PM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
Check the switch also. Just find a used one and replace it. Mine had an aftermarket switch that was on ALL the time. I got a used one and it has been good since then.
Jimmy Moreno
1995 530i
1986 535i
HTML code is Off
