Old 11-30-2012, 12:55 AM
emergency_bg emergency_bg is offline
Mein Auto: BMW X3 2.0 2004
Hi, sorry to get back to that pretty old topic.
I have a small red navigation screen on my e83, would like to update to the big colorful screen 16:9. I have the DVD installed in the trunk.
Which parts exactly do I need?
Old 11-30-2012, 01:27 AM
darkrider darkrider is offline
Mein Auto: x3 2005
Hello
you will need the retrofit kit that contains
- 1 cable retrofit to install from the trunk to the dash board and fuse box
- 1 color screen
- 1 CID to replace the Business Radio/GPS in the dash board (optional - I personnaly use the Radio GPS business with the orange screen + color screen on board)
once you install all this,
you will need to update the firmware of the GPS /DVD player in the back of the car, to switch to professional GPS (with deported screen)
for this you will need a dongle + a software "Navcoder" or you can ask your dealer for updating your firmware, once all is installed.
good luck!
Dark
Old 11-30-2012, 01:50 AM
Thank you for your prompt reply.
Can you please post a link to such retrofit cable so that I know what I should be searching for.
So, am I right that I can leave the small screen and then I only need the large screen + cable + firmware update?
Old 11-30-2012, 02:03 AM
Mein Auto: x3 2005
man, I am in Europe too,
so try Google and Ebay
you have all key words in my reply
thx
Dark
Old 10-12-2013, 08:25 PM
peter_cd.cn peter_cd.cn is offline
I care my ride
Mein Auto: BMW X3
Question Broken Display. Solutions?
This is a great retrofit instruction. I am sure it has helped many people. I have a different need. My car's display just broke the other day. I think the led starts to leak and I get this big circle on my screen. This should only get worse by day, so I am thinking to get it fixed.
Since I am fixing this, I want to add some features to the whole system. I am thinking to add
-HD radio
-Bluetooth phone
-iPod via Intravee II
-Reverse Camera (nice to have)
-Sirius radio (nice to have)
My car's stereo control unit has a 'phone' button on it, but it doesn't have the bluetooth option to setup. I also don't have HD radio on this, but sna77 has it after his retrofit. I think I am missing some hardware.
Anyone knows what I need to buy to get this project going?
-Central Information Display (CID)
Thanks for the help.
ID:	401837   Click image for larger version
ID:	401838   Click image for larger version
Old 10-13-2013, 09:56 PM
Mein Auto: x3 2005
Hello,
hard to reply from scratch, there are multiple possible options.
first, need to understand the archit. of the car to understand what you want to do:
for instance: reverse camera
or you go retrofit, or you add a specific devise between the GPS MK4 and the screen CID
if you go retrofit,
you will need a TV module (specific for your car, you need to find the serial number of the corresponding part on the site realOEM.com)
or eventually put a modern one, hybrid digital and analog.
for the ipod, same issue, multiple modules exists, that will show (or not) the title of the songs, and the playlists on the screen, (or not - depending on car version/year and price)
and so on ... so on....
I would advise for each feature to be installed, to check solution on google.
you may find comon parts, that should be your start point
good luck
Old 10-13-2013, 10:14 PM
I care my ride
Mein Auto: BMW X3
Thanks for your reply 'darkrider'. Back up camera and sirius radio are optional for me right now. The most important thing for me is to get the CID fixed.
Apparently people don't make them anymore, and realOEM.com are selling one unit for over 1000 dollars.
Do you know why my car doesn't have the HD radio and the phone function? What hardware am I missing. The stereo control has a 'phone' button, but that does nothing...
Old 10-13-2013, 11:31 PM
Mein Auto: x3 2005
Hello there
RealOEM (as the name says) will point you to the original BMW part. they don't sell.
the site gives you the precise part you need, from the BMW catalogue, and they are not cheap!
but the site will give you the most important info - the corresponding serial number.
with this sezam, you shall go on eb... (eb... .de for german parts)
and look for the parts
a CID costs around 150 - 200 euros (second hand) (instead of 1000 euros new)
for the phone button, all cars with advanced strearing weel, and CID prof. will have the button available.
same for phone, you need the retrofit module, same goes for bluetooth etc....
same process:
1) identify the part you need from realoem
2) search for the exact part on ebay
3) buy,
4) install
nothing else, to be done, the on board computer (Dis +) will recognize the modules, the corresponding menu will then show up on the screen
Old 01-08-2014, 05:23 PM
crompie crompie is offline
Mein Auto: X3 E83 2010
Red face
I know this is a very late reply, but maybe this info will help others as well...
I have done the exact upgrade mentioned above on my 2010 E83 (replace small red screen in radio with colour LCD display on dash) - thanks to sna77 for all the very useful info originally posted at the top of this thread.
In this case, since the nav DVD and wiring is already installed, it's only necessary to fit the additional wiring required for the LCD display (CID). It's not absolutely necessary to buy the complete nav wiring harness (loom), it's possible to just add the missing wires to the existing wiring - you'll need some thin screened cable for the video signals, and some multi-strand hook-up wire for power and other signals. However, I decided to buy the complete harness, just to make the job easier, and because all the required connectors are provided with the new harness. (I bought the wiring harness from an Ebay supplier in Europe).
I did not replace the old harness, I simply removed the additional wires that are required from the new harness, and added them to the existing wiring. It's possible to remove the individual wires from the connector in the new harness, and then insert them into the existing connector at the rear of the nav DVD. This means you don't have to install any wiring to the fuse box, or behind the instrument cluster, in this case they are already connected.
If anyone needs the exact details of which wires are required, I can post the info here.
I bought a second-hand CID, and replacement radio (from Ebay), which work just fine, and so much cheaper than new units, and of course you gain a CD/MP3 player as well.
Once the hardware was installed, all I had to do was code the navigation system so that it directs the video signals to the LCD display, using the excellent NavCoder software and an interface to the car's K-bus, which you can either buy or build one yourself using just a handful of simple components. Note that in order to recode the nav system, you'll also need to reload the nav computer's OS - which is not difficult.
Well worth the effort!
Old 04-26-2014, 02:34 PM
Archroptor Archroptor is offline
Mein Auto: X3 2007 3.0 Si
hello i love your instruction but all the image are gone..what can i do ? can you email me all of the text with images ? thank you very much
m.ghorashinezhad@yahoo.com
Old 06-12-2014, 11:34 AM
leal72 leal72 is offline
Mein Auto: 2005 X3
In reference to this picture, do all X3's with navigation have access to this menu with the wheel sensors? I have an 05, wonder if this may help me trouble shoot if I have issues with my wheel sensors.
BTW - great work on this project!
Old 06-12-2014, 12:07 PM
joylove joylove is offline
Mein Auto: 08 e83 LCI
Yes.
http://www.bimmernav.com/Advanced_Pr...n_Display.html
Old 06-12-2014, 12:59 PM
Mein Auto: 2005 X3
thanks! I'll check this out.
Old 06-30-2014, 09:21 AM
Mein Auto: 2005 X3
http://www.bigpatsfans.com/x3oemnav/29.JPG
http://www.bigpatsfans.com/x3oemnav/22.JPG
Referring to these two pictures. How do I get the presets and station info to display like this? Is it something that needs to be coded or something I can set in a setting somewhere?
I have an 05 X3 with the factory navigation setup
Old 07-03-2014, 09:32 AM
ILBMW ILBMW is offline
Mein Auto: x3
Awesome !!
This is exactly I wanted to get too for my 08 X3, can your friend (or someone nearby where I live you would know) help me too ? I live in NJ
Old 01-06-2015, 04:56 AM
dainioske dainioske is offline
Mein Auto: E83
i'm interesting in this too... do i need to code, or just push some secret buttons...
Old 02-13-2015, 12:29 AM
esco289 esco289 is offline
Mein Auto: x3
Originally Posted by sna77 View Post
Thanks--but I can't take all the credit. My friend Andy is just about the best BMW tech I've ever met... I couldn't have done it without him.
Putting in DVD headrests for the kiddies soon... Actually not going to use the BMW ones.. BMW just OEMs them from Vizualogic, and they are constantly discontinuing parts etc. I ran into all sorts of issues grabbing replacement parts on my old e46... Figured I'd go straight to the horses mouth on the X3 install...
Hi. great job on making it all work out..i have a 2006 x3 with the whole navi setup like you have done here and i would like to have my ipod connected. can you tell me what i need to get? Help please. Thanks
Old 07-15-2015, 04:54 PM
quinns quinns is offline
Mein Auto: X3, E46, E90LCI
Explanation of in-dash navigation head unit removal?
Hi, first really good work - I've done this in an e46 or two and know what it takes. What I am really interested in is how Andy removed the navigation head unit from the dash. I've not done this on an X3 and need to do so to replace the screen in my one (2004). I've got the vents, air con fascia, air con unit and radio out and front two retaining screws of the nav head unit off, but it feels like its also bolted at the back. Problem with that is that without taking out all the framework and the internal section of the vents, there's no way to be sure. I've not wanted to put too much pressure on the upward pull for fear of breaking the thing (it does bend quite alarmingly when I put some shoulder into it). Any guidance would be much appreciated.
May have found the answer I'm after in this reply: http://www.bimmerfest.com/forums/sho...3&postcount=62
Pay to read in more depth, right
Old 08-06-2015, 11:27 PM
sewe sewe is offline
Mein Auto: BMW X3 2004 model
If I may ask, my x3 2004, has the navigation computer at the rear,it has the central information display . Do you think it has GPS Aerial somewhere .?
Old 08-07-2015, 12:43 AM
I have noticed my x3 has navigation system where can I get the CD to insert . I'm in Kenya.
Old 08-07-2015, 05:04 PM
jdeday's Avatar
jdeday jdeday is online now
Send a message via AIM to jdeday
Mein Auto: 2005 BMW X3 3.0
Rotate the display into the vertical/open position and you will see the two phillips head screws. Remove them and the unit will lift out.
Jeff
2005 X3 3.0, Mystic Blue Metallic, Sand Beige Leather Interior, Birch Grain Light Wood Trim, Steptronic Transmission, Premium Package, Heated Seats, Privacy Glass, Satellite Radio Prep, Xenon Adaptive Headlights, Heated Steering Wheel, Premium Sound, Power Folding Mirrors and NAVIGATION RETROFIT
Old 05-09-2016, 10:16 PM
Hi guys I have a similar problem with my 2004 BMW X 3 ,the navigation system is old so I need to replace it with one that can connect even Bluetooth .Does these guys selling in th link provided ship to kenya.
Old 05-12-2016, 02:31 PM
Earlybird Earlybird is offline
Mein Auto:
I'm guessing the Alice in chains and dmb warehouse was no accident
Old 06-19-2016, 01:38 AM
Gandalf Gandalf is offline
Mein Auto: X1 48
Hi everybody, i know this is maybe not the correct place because i'm looking to retrofit an NBT on a X1 F48, but maybe some of you experts could solve a little doubt i have
I've found on realOEM parts what i need to start retrofitting , but i don't understand what two parts are
SATZ NAVIGATIONSEINHEIT NA and
Satz Halter Controller
Can someone help me?
Thanks in advance
Old 12-23-2016, 08:13 PM
osedov osedov is offline
Mein Auto: X3, 328xi
Wondering if anyone has oem retrofit manual/instruction x3_oem_nav_retrofit.pdf
Couldn't find it on the net.
or at least wiring diagram... how/where to tap at the fuse box
