7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners |
Reference - Common error code list
Here is a list of common error codes that could pop up on your BMW. This is reference only and not all inclusive. BMW outputs codes in Hex format. The tool then reads the code and it may translate it to its own format. So check your code reader manufacturer. If you have a code that is not on here then it may be from another module that isn't defined here, or it could be that is being displayed differently by your code reader. You may need to cross reference and check other sources.
Bavarian Tool 2711 DMTL pump final stage 2712 DMTL magnetic valve control 2713 Oxygen sensors switched 2714 Oxygen sensor heater after cat. (bank2) 2715 Oxygen sensor heater before cat. (bank2) 2716 Controller heater sensor after cat 2717 Controller heater sensor after cat (Bank2) 2718 Speed (rpm) sensor for missing tooth 2719 Speed (rpm) sensor for periode timing 271A Oxygen sensor before cat. 271B Oxygen sensor before cat. 271C Oxygen sensor after cat. 271D Oxygen sensor heater before cat. 271E Oxygen sensor heater after cat. 271F Lambda sensor periode duration ageing 2720 Lambda sensor ageing TV 2721 Lambda sensor ageing after cat 2722 Oxygen sensor2 before cat. 2723 output heater O2-sensor before catalyst bank2 2724 Oxygen sensor2 after cat. 2725 Lambda sensor periode duration ageing bank2 2726 Lambda sensor ageing TV bank2 2727 Lambda sensor ageing after cat bank2 2728 Adaption multipl. area2 2729 Adaption multipl. area2 (bank2) 272A Adaption multipl. area1 272B Adaption multipl. area1 (bank1) 272C Adaption add. per time 272D Adaption add. per time (Bank2) 272E Adaption add. per ignition 272F Adaption add. per ignition bank2 2730 failure within the idle-speed control 2731 Camshaft control inlet - VANOS 2732 NW-Control of inlet B2 (8cyl)/outlet (4cyl) 2733 NW-KW synchronfailure 2734 TPS/MAF plausibility 2735 TPS/MAF plausibility bank2 24 2736 Throttle controller PWM short test 2737 EWS-manipulation control 2738 Catalytic-converter conversion 2739 Catalytic-converter conversion LSU 273A Catalytic-converter conversion LSU bank2 273B Throttle controller PWM long test 273C Throttle controller diff. 273D Catalytic-converter conversion (bank2) 273E Signal temper.sensor exhaust1 273F Signal temper.sensor exhaust2 2740 Pedal-travel1 permanently 2741 Pedal-travel2 permanently 2742 Misfire detection cyl.1 2743 Misfire detection cyl.3 2744 Misfire detection cyl.4 2745 Misfire detection cyl.2 2746 Misfire detection cyl. 2747 Misfire detection cyl. 2748 Misfire detection cyl 2749 Misfire detection cyl 274A Misfire detection cyl 274B Misfire detection cyl 274C Misfire detection cyl 274D Misfire detection cyl 274E Misfire detection, Checksum failure 274F Misfire, Checksum failure, service rel. 2752 Pedal-travel half plausibility 2753 Monitoring ign. coil 1 2754 Monitoring ign. coil 3 2755 Monitoring ign. coil 4 2756 Monitoring ign. coil 2 2757 Monitoring ign. coil 2758 Monitoring ign. coil 2759 Monitoring ign. coil 275A Monitoring ign. coil 275B Monitoring ign. coil 275C Monitoring ign. coil 275D Monitoring ign. coil 275E Monitoring ign. coil 275F Pedal-travel defect 2760 Secondary air system 2761 Secondary air system bank2 2762 Secondary air valve 2763 Secondary air valve bank2 2764 Controll sek.air pump relay 2765 Controll sek.air valve 2766 Phase generator1 time duration 2767 Phase generator2 time duration 2768 Phase generator positioning failure 2769 Spring test DK-controller open spring 276A Control-unit recognition 276B Secondary air valve output stage bank2 276C Phase generator2 positioning failure 276D Tank-ventilation functional check 276E Tank-ventilation functional check bank2 276F failure within secondary air system 2770 failure within secondary air system 2771 Secondary air system locked 2772 Controll gas ventilation valve 2773 Tank-ventilation valve output stage bank2 2774 Monitoring cyc. failurestoring 2775 engine moment monitoring level 2 2776 Interface multifunction stearing wheel 2777 Monitoring controller function 2778 Switch clutch 2779 SG selftest RAM 277A Switch break 277B SG selftest ROM 277C SG selftest reset 277D Battery Voltage 277E Moment restrictor level 1 277F Crankshaft sensor 2780 Ref. marking generator 2781 Camshaft sensor inlet 2782 Camshaft sensor outlet 2783 Hot film air mass meter 2784 Thermostat diag. THM 2785 DK-Potentiometer 2786 Throttle-valve potentiometer 1 2787 Throttle-valve potentiometer 2 2788 Vehicle speed 2789 Bad way detection 278A Ambient temperature 278B Engine temperature 278C Intake air temperature 278D Temp. sensor coolant temperature 278E Diff. pressure sensor suction tube 278F LowRange signal not plausible 2790 transmission temp. 2791 Parts exchange without adaption 2792 Drosselklappe - Positionsüberwachung 2793 DK-Actuator regulator area 2794 DK-Actuator controlled 2795 Spring test DK-controller closing spring 2796 Throttle flap lower stop 2797 DK-Controller failure booster 2798 Throttle flap emergency air point 2799 Abort DV-adaption because of enviroment 279A Throttle flap adation - abort after reteaching 279B Thermostat jammed 279C Control heater cooler 279D Control engine fan 279E Output exhaust flap 279F Output fanA 27A0 Controll E-box fan 27A1 failure within secondary air system 2 27A2 Temp.sensor engine LR 27A3 CAN timeout HDEV2 SG 27A4 EWS3.3 Schnittstelle EWS-DME 27A6 Ansteuerung Einspritzventil 1 27A7 Ansteuerung Einspritzventil 3 27A8 Ansteuerung Einspritzventil 4 27A9 Ansteuerung Einspritzventil 2 27AA Ansteuerung Einspritzventil 27AB Ansteuerung Einspritzventil 27AC Ansteuerung Einspritzventil 27AD Ansteuerung Einspritzventil 27AE Ansteuerung Einspritzventil 27AF Ansteuerung Einspritzventil 27B0 Ansteuerung Einspritzventil 27B1 Ansteuerung Einspritzventil 27B3 Diagnose DK/HFM adjustment 27B4 Ambient-pressure sensor 27B5 Control inlet-VANOS 27B6 Control inlet-VANOS bank2 27B7 Controll gas pump relay 27B8 Plausibility diff. pressure sensor 27B9 BLS/BTS Plausibility 27BA Output AC-kompr. enable from AC-SG 27BB Camshaft control outlet-VANOS 27BC Camshaft control outlet-VANOS bank2 27BD Control outlet-VANOS 27BE Output outlet-VANOS bank2 27BF Camshaft sensor inlet bank2 27C0 Camshaft sensor outlet bank2 27C1 Master camshaft sensor 27C2 Controll AC-compressor relay 27C3 Signal oil level sensor (TOENS) 27C6 LDP Diagnose 0.5mm leak 27C7 LDP Diagnose 1.0mm leak 27C8 LDP system 27C9 Leak diag. module 27CA Ansteuerung DM-TL Pumpenmotor 27CB DM-TL 0.5mm leak MIL off 27CC DM-TL 1mm & 0.5mm leak 27CD DM-TL module 27CE Load sensor monitoring 27CF Ignition time Cyl.1 27D0 Ignition time Cyl.3 27D1 Ignition time Cyl.4 27D2 Ignition time Cyl.2 27D5 failure within the idle-speed control 27D6 Output idle-speed controller OFF 27D7 Output idle-speed controller ON 27D8 Failure depressure pump 27D9 Output DM-TL heater 27DA generator failure 27DC EWS3.3 Random-code storing 27E1 monitoring pedal-travel sensor 27E2 Knock sensor 1 27E3 knock sensor2 bank1 27E4 Knock sensor 3 27E5 Knock sensor 4 27E6 Knock sensor zero test 27E7 Knock sensor offset 27E8 Knock regulation Test impulse 27E9 Knock sensor zero test bank2 27EA CAN-Timeout HDEV 27EB CAN-Timeout TCU 27EC CAN-Timeout EGS 27ED CAN-Timeout ASC/DSC 27EE CAN-Timeout Instrumentenkombination 27EF CAN ACC-Signalfehler 27F0 Plausibility MSR-control 27F1 Plausibility ACC-control 27F2 Plausibility gas level 27F3 CAN-Timeout VVT-Control unit 27F4 CAN-Timeout VVT-Control-unit bank2 27F5 CAN-Timeout DME-Control unit 27F6 Pedal-travel 27F7 Pedal-travel Poti1 27F8 Pedal-travel Poti2 27F9 Start automatic control 27FA Input starter automatic 27FB Output controlled airflow 27FD Starter automatic 27FE Knock control offset bank2 27FF Knock control test signal bank2 280A Assign. camshaft to crankshaft 280D Control unit monitoring 280E Control unit monitoring 280F Camshaft control 2810 Engine speed monitoring 2811 Local CAN Bus Off 2812 oil temperature 2813 Control unit monitoring group A 2814 Control unit monitoring group B 2815 Control unit monitoring group C 2816 engine rpm monitor 2818 voltage-monitoring O2-sensor on air 281C BSD wire failure 281E Controll DISA 281F DISA-mount response 2820 Failure DISA 2821 DISA temp. warn level engine protection model 2822 Forced switched EGS 2823 Heating lambda sensor befor Cat 2824 Heating lambda sensor befor Cat bank2 2825 Lambdasensor aging after Cat 2826 Lambdasensor aging after Cat bank2 2827 heater link at signal-path 2828 CAN ARS-Signalfehler 2829 CAN CAS-Signalfehler 282A CAN IHKA-Signalfehler 282B CAN PWML-Signalfehler 282C CAN SZL-Signalfehler 282D heater link at signal-path bank2 282E PWG-movement 2830 aging of O2-sensor behind catalyst (Bank 2) 2832 Plausibility ASR-Torque 2833 Plausibility CAS 2834 Plausibility IHKA 2835 Plausibility PWML 2836 Plausibility SZL 2837 Plausibility EMF 2838 Output-stage AAV 2839 AAV-Functionality 283A Failure oil quality sensor 283B Camshaft control output bank2 283C Camshaft control output 283D PT - CAN bus off 283E VVT enable controll 283F Plausibilitaet Oeldruckschalter 2841 Air flushed injector valves control 2843 plausibility diagnostics LSU by LSH after catalyst 2844 internal diagnostics CJ125 SPI communication 2849 power break at pump-current 284A short circuit to minus or to plus at sensor-line 284C LSU dynamic too slow 284F failure at speed-display kombi 2850 VVT-guiding sensor 2851 VVT-guiding sensor (bank2) 2852 VVT-ref. sensor 2853 VVT-ref. sensor (bank2) 2854 VVT-Sensor plausibility 2855 VVT-Sensor plausibility (bank2) 2856 VVT-Supply volatge for the sensor 2857 VVT-Supply volatge for the sensor (bank2) 2858 VVT-Teaching function at stop 2859 VVT-Teaching function at stop (bank2) 285A VVT-Actuator monitoring 285B VVT-Actuator monitoring (Bank2) 285C VVT-CAN-communication 285D VVT-CAN-communication (bank2) 285E VVT-Control unit internal failure 285F VVT-Control unit internal failure (bank2) 2860 VVT-Controll 2861 VVT-Controll (bank2) 2862 VVT-Power supply 2863 VVT-Power supply (bank2) 2864 DM-TL-Pump control failure 2865 Power supply limit VVT-emergency 2866 VVT-stops leaning necessary 2867 VVT system overload 2868 VVT system overload (bank2) 286F AGR Valve output 2870 AGR Valve monitoring 2871 AGR Valve positioning sensor 2872 Diagnose AGR valve 2873 Output-stage HDEV-SG1 bank1 2874 Output-stage HDEV-SG1 bank2 2875 Output-stage HDEV-SG1 bank3 2876 Output-stage HDEV-SG2 bank1 2877 Output-stage HDEV-SG2 bank2 2878 Output-stage HDEV-SG2 bank3 2879 Signal exhaust temp. sensor 4 287A Output pressure control valve 287B Signal exhaust temp. sensor 3 287C Pressure sensor suction tube 287D Signal rail-pressure sensor 287E Pressure control valve 287F High pressure sensor test 2880 AGR system 2881 CDKBKE Output twist generator controller 2882 Output pressure control valve 2883 Rail-pressure regulation 2889 plausibility monitoring of the RAM backup 2893 DME- Temperature 2898 lambda sensor after cat bank1: signal 28A0 Output gas circuit switch 28C8 Lambdacontrol mismatch 28C9 Lambdacontrol mismatch bank2 28D2 Pressure sensor charge-air 28D3 Plausibility ambient- to charge pressure 28D4 Pressure control valve 28D5 Output charge pressure control valve 28D6 HO-Proc.failure, coding missing 28D7 Generator communication 28D8 RAM backup-failure 28D9 elec. heater 28DA CAN timeout elec. heater 28DB min. Lift adaption repeat. ran over 28DC generator 2 communication 2906 AGR valve monitoring 2907 AGR valve monitoring 2908 CAN timeout DSG SG 2909 CAN timeout EGS 290A active front steering torque 292B LSU adjustment line 292C LSU adjustment line bank2 292D LSU Nernst cell break 292E LSU Nernst cell break bank2 2930 LSU virtual mass break 2931 LSU virtual mass break bank2 2936 fuel pressure sensor 2937 funktion monitoring: Lambda Plausibility 296B inverted lambda sensors of front cat 2972 Control pump for breaks 297D CAN SSG signal failure 2981 Control controlled airflow 299B IBS communication 299C IBS general error 299D IBS plausibility 29A8 power management network failure 29A9 power management 29AE tank-ventilation-system major leak 29CC misfire detection summation error 29CD misfire detection cylinder 1 in 1. ignition sequence 29CE misfire detection cylinder 2 in 4. ignition sequence 29CF misfire detection cylinder 3 in 2. ignition sequence 29D0 misfire detection cylinder 4 in 3. ignition sequence 29D9 misfire at too low fuel filling level 29DD Bad way detection 29E5 LR-Adaption multiplicative area2 (Bank1) 29E6 LR-Adaption multiplicative area2 (Bank2) 29E7 LR-Adaption additive per time (Bank1) 29E8 LR-Adaption additive per time (bank2) 29E9 LR-Adaption add. per ignition 29EA LR-Adaption add. per ignition bank2 29EB LR-Deviation 29EC LR-Deviation bank2 29ED LR-Adaption multiplicative area1 (Bank1) 29EE LR-Adaption multiplicative area1 (Bank2) 29F4 Catalytic-converter conversion 29F5 Catalytic-converter conversion (bank2) 29F8 Cat-konversion LSU 29F9 Catalytic-converter conversion LSU bank2 29FE secondary air injection system 29FF secondary air system (Bank2) 2A01 secondary air injection control valve 2A02 Control air system valve 2A03 secondary air pump relay 2A05 Secondary air valve bank2 2A0E AGR valve 2A12 magnetic valve DMTL control 2A13 Control DMTL pump motor 2A14 DM-TL Fine leak 2A15 tank-ventilation-system major leak 2A16 DM-TL 0.5mm leak MIL off 2A17 DM-TL module 2A18 Control DMTL heater 2A19 Tank ventilation valve 2A1A Tank-ventilation functional check 2A1D Tank leakage monitoring 2A1E Leackage diagnostic pump 2A58 VVT-Enable control 2A59 VVT-leading sensor 2A5A VVT-leading sensor bank2 2A5B VVT-ref. sensor 2A5C VVT-ref. sensor (bank2) 2A5D VVT-Sensor plausibility 2A5E VVT-Sensor plausibility (bank2) 2A5F VVT-Supply volatge for the sensor 2A60 VVT-Supply volatge for the sensor (bank2) 2A61 VVT-Teaching function at stop 2A62 VVT-Teaching function at stop (bank2) 2A63 VVT-Actuator monitoring 2A64 VVT-Actuator monitoring (Bank2) 2A65 VVT-Control unit internal failure 2A66 VVT-Control unit internal failure (bank2) 2A67 VVT-activation 2A68 VVT-Output-stage (bank2 2A69 VVT-Power supply 2A6A VVT-Power supply (bank2) 2A6B Power supply limit VVT-emergency 2A6C VVT-stops leaning necessary 2A6D VVT-system overload 2A6E VVT-system overload bank2 2A6F multip. min lift adaption stop 2A70 error current plausibility 2A71 output stage diagnostics of discharge relay VVT 2A72 Actuator control VVT throw adjustment 2A80 injector-VANOS 2A81 Control inlet-VANOS bank2 2A83 camshaft control- Input 2A85 outlet-VANOS 2A86 Control outlet-VANOS bank2 2A88 camshaft control outlet 2A89 camshaft control outlet-VANOS bank2 2B5C Crankshaft sensor 2B5D Ref. marking generator 26 2B61 Assign. camshaft to crankshaft 2B62 camshaft sensor inlet 2B63 camshaft sensor outlet 2B64 camshaft sensor inlet bank2 2B65 camshaft sensor outlet bank2 2B66 Master camshaft sensor 2B70 DISA 2B71 Failure DISA 2B72 DISA temp. warn level engine protection model 2B7F Diagnose DK/HFM adjustment 2B80 idle running controling 2B8A Knock sensor zero test 2B8B Knock sensor offset 2B8C Knock regulation Test impulse 2B8D Knock sensor zero test bank2 2B8E Knock control offset bank2 2B8F Knock control test signal bank2 2B98 plausibility monitoring of the RAM backup 2B99 RAM Backup 2B9A ECU self-test RAM 2B9B ECU self-test ROM 2B9C ECU self-test Reset 2B9D overvoltage detection on VCC 2B9E Energy saving mode active 2BA7 torque restrictor level 1 2BB6 Control main relay 2C24 interchanged O2-sensors 2C37 heater link at signal-path 2C38 heater link at signal-path bank2 2C39 LSU dynamic too slow 2C3A LSU dynamic too slow bank2 2C3B voltage-monitoring O2-sensor on air 2C3C voltage-monitoring O2-sensor on air bank2 2C45 lambda sensor in front of cat 2C46 Lambda sensor of front cat bank2 2C47 short circuit to minus or to plus at sensor-line 2C48 short circuit to minus or to plus at sensor-line bank2 2C49 plausibility diagnostics LSU by LSH after catalyst 2C4A plausibility diagnostics LSU by LSH after catalyst bank2 2C4B internal diagnostics CJ125 SPI communication 2C4C internal diagnostics CJ125 SPI communication bank2 2C4D power break at pump-current 2C4E power break at pump-current bank2 2C4F LSU adjustment line 2C50 LSU adjustment line bank2 2C51 LSU Nernst cell break 2C52 LSU Nernst cell break bank2 2C53 LSU virtual mass break 2C54 LSU virtual mass break bank2 2C55 Lambda sensor periode duration ageing 2C56 Lambda sensor ageing TV 2C6A inverted lambda sensors of front cat 2C6D Lambda sensor aging of rear cat bank1 2C6E Lambda sensor aging of rear cat bank2 2C6F lambda sensor aging of rear cat (VL- test) 2C70 aging of O2-sensor behind catalyst (Bank 2) 2C71 lambda sensor in rear of cat 2C72 Lambda sensor of rear cat bank2 2C9C output heater O2-sensor before catalyst 2C9D output heater O2-sensor before catalyst bank2 2C9E Control heater sensor after cat 2C9F Control heater sensor after cat (bank2) 2CA0 lambda sensor heating in front of cat 2CA1 Oxygen sensor heater before cat. (bank2) 2CA2 heating lambda sensor of front cat (shearing stress) 2CA3 heating lambda sensor of front cat (shearing stress) Bank2 2CA8 Oxygen sensor heater after cat. 2CA9 Oxygen sensor heater after cat. (bank2) 2CEF DK-actuator 2CF0 DK-Actuator regulator area 2CF1 DK position monitoring 2CF8 DK-poti sensor 2CF9 Throttle-valve potentiometer 1 2CFA Throttle-valve potentiometer 2 2CFF DK-Controller failure booster 2D00 spring-check throttle-valve-actuator closing spring 2D01 spring-check throttle-valve-actuator opening spring 2D02 error emergency air setpoint 2D03 Abort DV-adaption because of enviroment 2D04 throttle valve adaption 2D05 Abort at UMA-repeat learning 2D08 parts exchange without adaption 2D0F Hot film air mass meter 2D10 Plausibility HFM 2D11 Plausibility, mass flow Lambda sensor 2D12 Plausibility, mass flow Lambda sensor BAnk2 2D19 PWG-movement 2D1A accelarator potentiometer 2D1B Pedal-travel Poti1 2D1C Pedal-travel Poti2 2D28 Diff. pressure sensor suction tube 2D29 Plausibility diff. pressure sensor 2D32 Plausibility pressure sensor intake tube 2D6E moment monitoring level 2 2D6F Load sensor monitoring 2D70 Control unit monitoring group A 2D71 Control unit monitoring group B 2D72 Control unit monitoring group C 2D73 fuel pressure sensor 2D74 funktion monitoring: Lambda Plausibility 2D75 engine speed monitoring 2D76 pedal encoder monitoring (level2) 2D78 Control air mass flow adjustment 2DB4 interface MFL 2DBF CAN ACC signal failure 2DC8 CAN- Timeout EGS 2DCA CAN timeout EGS 2DCB CAN SSG signal failure 2DCF CAN- Timeout instrument combination 2DD6 CAN- Timeout ASC/DSC 2DD7 CAN timeout DSG SG 2DD8 active front steering torque 2DD9 CAN ARS signal failure 2DDA CAN CAS signal failure 2DDB CAN IHKA signal failure 2DDC CAN SZL signal failure 2DDD CAN-Timeout VVT-Control unit 2DDE VVT-CAN-communication 2DDF VVT-CAN-communication (bank2) 2DE6 CAN-Timeout DME-Control unit 2DEB power management network failure 2DEC power management 2DED Powermanagement: quiescent current violation 2E24 spark coil cylinder 1 in 1. ignition sequence 2E25 spark coil cylinder 2 in 4. ignition sequence 2E26 spark coil cylinder 3 in 2. ignition sequence 2E27 spark coil cylinder 4 in 3. ignition sequence 2E30 injection valve cylinder 1 in 1. cylinder sequence 2E31 injection valve cylinder 2 in 4. cylinder sequence 2E32 injection valve cylinder 3 in 2. cylinder sequence 2E33 injection valve cylinder 4 in 3. cylinder sequence 2E68 Knock sensor 1 2E69 knock sensor2 (Bank1) 2E6A Knock sensor 3 2E6B Knock sensor 4 2E7C BSD wire failure 2E86 Electrical water pump 2E8B IBS communication 2E8C IBS general error 2E8D IBS plausibility 2E95 generator communication 2E97 CDKDGEN/CDKGEN - BSD generator 2E9F Failure oil quality sensor 2EA0 Oil status sensor 2EB8 BSD-message from IBS not existent 2EBC BSD message from oil sensor missing 2EBD BSD message from generator missing 2EBE BSD message from generator missing 2EE0 Temperature sensor engine cooling liquid 2EEA Temp. sensor coolant temperature 2EF4 Thermostat characteristic diagram cooling, mechanical 2EF5 Thermostat characteristic diagram cooling, activation 2EF6 characteristic diagram thermostat 2EFE engine blower 2F08 Intake air temperature 2F0D Control controlled airflow 2F12 Air conditioner compressor control 2F17 Forced switched EGS 2F1C oil temperature sensor 2F21 engine controller, power reduction 2F44 EWS3.3 manipulation protection 2F45 EWS3.3 Interface DME-EWS 2F46 EWS3.3 Random-code storing 2F4E Vehicle speed 2F50 failure at speed-display kombi 2F58 Control starter automatic 2F59 Input starter automatic 2F5A Start automatic control 2F62 Switch brakes 2F67 Switch clutch 2F6C Control exhaust flap 2F71 E-Box blower 2F76 Ambient-pressure sensor 2F7B oil pressure switch 2F80 error CAN / relative timer 2F85 DME- Temperature 2F8A Battery Voltage 2F94 fuelpump relay 2F99 Ambient temperature 2F9E Thermical oillevel sensor 2FA3 HO-proc.failure, coding missing 2FB2 suction jet pump for brake force amplifier 2FB7 electr. under pressure pump for brake booster CD87 PT - CAN bus off CD8B Local CAN Bus Off CD9B status vehicle-mode CDA1 angle of steering wheel CDA2 powermanagement battery voltage CDA3 powermanagement charge voltage CDA7 status gear reverse CDAA control crash-switch-off EKP CDAC status water valve Generic OBDII Codes P1083 Fuel Control Mixture Lean (Bank 1 Sensor 1) P1084 Fuel Control Mixture Rich (Bank 1 Sensor 1) P1085 Fuel Control Mixture Lean (Bank 2 Sensor 1) P1086 Fuel Control Mixture Rich (Bank 2 Sensor 1) P1087 O2 Sensor Circuit Slow Response in Lean Control Range (Bank 1 Sensor 1) P1088 O2 Sensor Circuit Slow Response in Rich Control Range (Bank 1 Sensor 1) P1089 O2 Sensor Circuit Slow Response in Lean Control Range (Bank 1 Sensor 2) P1090 Pre-Catalyst Fuel Trim Too Lean Bank 1 P1091 Pre-Catalyst Fuel Trim Too Rich Bank 1 P1092 Pre-Catalyst Fuel Trim Too Lean Bank 2 P1093 Pre-Catalyst Fuel Trim Too Rich Bank 2 P1094 O2 Sensor Circuit Slow Response in Rich Control Range (Bank 2 Sensor 1) P1095 O2 Sensor Circuit Slow Switching From Lean to Rich (Bank 1 Sensor 1) P1096 O2 Sensor Circuit Slow Switching From Lean to Rich (Bank 2 Sensor 1) P1097 O2 Sensor Circuit Slow Response after Coast Down Fuel Cutoff (Bank 1 Sensor 1) P1098 O2 Sensor Circuit Slow Response after Coast Down Fuel Cutoff (Bank 2 Sensor 2) P1111 Engine Coolant Temperature Radiator Outlet Sensor Low Input P1112 Engine Coolant Temperature Radiator Outlet Sensor High Input P1115 Coolant Temperature Sensor Plausibility P1116 Mass Or Volume Air Flow Circuit Range/Performance Problem (Bank 2) P1117 Mass Or Volume Air Flow Circuit Low Input (Bank 2) P1118 Mass Or Volume Air Flow Circuit High Input (Bank 2) P1120 Pedal Position Sensor Circuit P1121 Pedal Position 1 Range/Performance Problem P1122 Pedal Position 1 Low Input P1123 Pedal Position 1 High Input P1132 O2 Sensor Heater Control Circuit (Bank 1 Sensor 1) P1133 O2 Sensor Heater Control Circuit (Bank 2 Sensor 1) P1134 O2 Sensor Heater Circuit Signal Intermittent (Bank 1 Sensor 2) P1135 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1) P1136 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1) P1137 O2 Sensor Heater Circuit Signal Intermittant (Bank 1 Sensor 2) P1138 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2) P1139 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 2) P1140 Mass or Volume Air Flow Circuit Range/Performance Problem P1145 Solenoid Valve Running Losses Control Circuit Electrical P1151 O2 Sensor Heater Circuit Signal Intermittant (Bank 2 Sensor 1) P1152 O2 Sensor Heater Circuit Low Voltage (Bank 2 Sensor 1) P1153 O2 Sensor Heater Circuit High Voltage (Bank 2 Sensor 1) P1155 O2 Sensor Heater Circuit Intermittant (Bank 2 Sensor 2) P1156 O2 Sensor Heater Circuit Low Voltage (Bank 2 Sensor 2) P1157 O2 Sensor Heater Circuit High Voltage (Bank 2 Sensor 2) P1158 Fuel Trim Additve Bank 1 Low P1159 Fuel Trim Additve Bank 1 High P1160 Fuel Trim Additve Bank 2 Low P1161 Fuel Trim Additve Bank 2 High P1162 Fuel Trim Additve Per Ignition Bank 1 Low P1163 Fuel Trim Additve Per Ignition Bank 1 High P1164 Fuel Trim Additve Per Ignition Bank 2 Low P1165 Fuel Trim Additve Per Ignition Bank 2 High P1174 Fuel Trim Adaptation Additve Bank 1 Malfunction P1175 Fuel Trim Adaptation Additve Bank 2 Malfunction P1176 O2 Sensor Slow Response Bank 1 P1177 O2 Sensor Slow Response Bank 2 P1178 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 1 Sensor 1) P1179 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 2 Sensor 1) P1180 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 1 Sensor 2) P1181 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 2 Sensor 2) P1182 O2 Sensor (Bank 1 Sensor 2) Open Circuit During Coast Down Fuel Cut-off P1183 O2 Sensor (Bank 2 Sensor 2) Open Circuit During Coast Down Fuel Cut-off P1186 O2 Sensor Heater Control Circuit (Bank 1 Sensor 2) P1187 O2 Sensor Heater Control Circuit (Bank 2 Sensor 2) P1188 Fuel Control (Bank 1 Sensor 1) P1189 Fuel Control (Bank 2 Sensor 1) P1190 Pre-catalyst Fuel Trim System Bank 1 P1191 Pre-catalyst Fuel Trim System Bank 2 P1192 Post-catalyst Fuel Trim System Bank 1 P1193 Post-catalyst Fuel Trim System Bank 2 P1221 Pedal Position Sensor 2 Range/Performance Problem P1222 Pedal Position Sensor 2 Low Input P1223 Pedal Position Sensor 2 High Input P1270 Control Module Self-Test, Torque Monitoring P1271 Ambient Air Pressure Sensor Electrical P1283 Switching Solenoid for Air Assisted Injection Valves Bank 1 Control Circuit Electrical P1284 Switching Solenoid for Air Assisted Injection Valves Bank 1 Control Circuit Signal Low P1285 Switching Solenoid for Air Assisted Injection Valves Bank 1 Control Circuit Signal High P1287 Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Electrical P1288 Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Signal Low P1289 Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Signal High P1313 "A" Camshaft Position Plausibility P1317 "B" Camshaft Position Plausibility P1327 Knock Sensor 2 (Bank 1) Low Input P1328 Knock Sensor 2 (Bank 1) High Input P1332 Knock Sensor 4 Low Input P1333 Knock Sensor 4 High Input P1340 Multiple Cylinder Misfire During Start P1341 Multiple Cylinder Misfire With Fuel Cut-off P1342 Misfire During Start Cylinder 1 P1343 Misfire Cylinder 1 With Fuel Cut-off P1344 Misfire During Start Cylinder 2 P1345 Misfire Cylinder 2 With Fuel Cut-off P1346 Misfire During Start Cylinder 3 P1347 Misfire Cylinder 3 With Fuel Cut-off P1348 Misfire During Start Cylinder 4 P1349 Misfire Cylinder 4 With Fuel Cut-off P1350 Misfire During Start Cylinder 5 P1351 Misfire Cylinder 5 With Fuel Cut-off P1352 Misfire During Start Cylinder 6 P1353 Misfire Cylinder 6 With Fuel Cut-off P1354 Misfire During Start Cylinder 7 P1355 Misfire Cylinder 7 With Fuel Cut-off P1356 Misfire During Start Cylinder 8 P1357 Misfire Cylinder 8 With Fuel Cut-off P1358 Misfire During Start Cylinder 9 P1359 Misfire Cylinder 9 With Fuel Cut-off P1360 Misfire During Start Cylinder 10 P1361 Misfire Cylinder 10 With Fuel Cut-off P1362 Misfire During Start Cylinder 11 P1363 Misfire Cylinder 11 With Fuel Cut-off P1364 Misfire During Start Cylinder 12 P1365 Misfire Cylinder 12 With Fuel Cut-off P1384 Knock Sensor 3 Circuit P1385 Knock Sensor 4 Circuit P1386 Control Module Self-test, Knock Control Baseline Test Bank 1 P1396 Crankshaft Position Sensor Segment Timing Plausibility P1397 Camshaft Position Sensor "B" Circuit (Bank 1) P1400 Heated Catalyst Battery Voltage or Current too Low During Heating (Bank 1) P1401 Heated Catalyst Current too High During Heating (Bank 1) P1402 Heated Catalyst Power Switch Overtemperature Condition (Bank 1) P1403 Carbon Canister Shut Off valve Control Circuit Electrical P1404 Heated Catalyst Current too High During Heating (Bank 2) P1405 Heated Catalyst Power Switch Overtemperature Condition (Bank 2) P1406 Heated Catalyst Internal Control Module Checksum/ROM Error P1413 Secondary Air Injection Pump Relay Control Circuit Signal Low P1414 Secondary Air Injection System Monitor Circuit High P1420 Secondary Air Valve Control Circuit Electrical P1421 Secondary Air System Bank 1 P1422 Secondary Air System Bank 2 P1432 Secondary Air Injection System Incorrect Flow Detected P1438 Purge Control Valve Control Open Circuit P1439 Purge Control Valve Control Circuit Signal Low P1440 Purge Control Valve Control Circuit Signal High P1441 Leakage Diagnostic Pump Control Open Circuit P1442 Leakage Diagnostic Pump Control Circuit Signal Low P1443 Leakage Diagnostic Pump Control Circuit Signal High P1444 Diagnostic Module Tank Leakage (DM-TL) Pump Control Open Circuit P1445 Diagnostic Module Tank Leakage (DM-TL) Pump Control Circuit Signal Low P1446 Diagnostic Module Tank Leakage (DM-TL) Pump Control Circuit Signal High P1447 Diagnostic Module Tank Leakage (DM-TL) Pump Too High During Switching P1448 Diagnostic Module Tank Leakage (DM-TL) Pump Too Low During Switching P1449 Diagnostic Module Tank Leakage (DM-TL) Pump Too High P1450 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Open Circuit P1451 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Control Circuit Signal Low P1452 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Control Circuit Signal High P1453 Secondary Air Injection Pump Relay Control Circuit Electrical P1454 Secondary Air Injection Pump With Series Resistor Control Circuit Electrical P1456 Heated Catalyst Heater Power Supply Open Circuit (Bank 1) P1457 Heated Catalyst Heater Power Switch Temperature Sensor Electrical (Bank 1) P1459 Heated Catalyst Heater Power Supply Open Circuit (Bank 2) P1460 Heated Catalyst Heater Power Switch Temperature Sensor Electrical (Bank 2) P1461 Heated Catalyst Gate Voltage Signal Low P1462 Heated Catalyst Internal Control Module Checksum/ROM Error P1463 Heated Catalyst Battery Temperature Sensor 1 Electrical P1464 Heated Catalyst Battery Temperature Sensor 2 Electrical P1465 Heated Catalyst Battery Temperature Sensor 1 or 2 Plausibility P1466 Heated Catalyst Power Switch Temperature Sensor Plausibility P1467 Heated Catalyst Comparison Battery Voltages of Power Switches Plausibility P1468 Heated Catalyst Battery Disconnecting Switch Plausibility P1470 Leakage Diagnostic Pump Control Circuit Electrical P1472 Diagnostic Module Tank leakage (DM-TL) Switching Solenoid Control Circuit Electrical P1473 Diagnostic Module Tank leakage (DM-TL) Pump Current Plausibility P1475 Leakage Diagnostic Pump Reed Switch Did Not Close P1476 Leakage Diagnostic Pump Clamped Tube P1477 Leakage Diagnostic Pump Reed Switch Did Not Open P1500 Idle Speed Control Valve Stuck Open P1501 Idle Speed Control Valve Stuck Closed P1502 Idle Speed Control Valve Closing Solenoid Control Circuit Signal High or Low P1503 Idle Speed Control Valve Closing Solenoid Control Circuit Signal Low P1504 Idle Speed Control Valve Closing Solenoid Control Open Circuit P1505 Idle Speed Control Valve Closing Solenoid Control Circuit Electrial P1506 Idle Speed Control Valve Open Solenoid Control Circuit Signal High P1507 Idle Speed Control Valve Open Solenoid Control Circuit Signal Low P1508 Idle Speed Control Valve Opening Solenoid Control Open Circuit P1509 Idle Speed Control Valve Opening Solenoid Control Circuit Electrial P1510 Idle Speed Control Valve Stuck P1511 DISA Control Circuit Electrical P1512 DISA Control Circuit Signal Low P1513 DISA Control Circuit Signal High P1519 "A" Camshaft Position Actuator Bank 1 P1520 "B" Camshaft Position Actuator Bank 1 P1522 "A" Camshaft Position Actuator Bank 2 P1523 "A" Camshaft Position Actuator Signal Low Bank 1 P1524 "A" Camshaft Position Actuator Signal High Bank 1 P1525 "A" Camshaft Position Actuator Control Open Circuit Bank 1 P1526 "A" Camshaft Position Actuator Control Open Circuit Bank 2 P1527 "A" Camshaft Position Actuator Control Circuit Signal Low Bank 1 P1528 "A" Camshaft Position Actuator Control Circuit Signal High Bank 1 P1529 "B" Camshaft Position Actuator Control Circuit Signal Low Bank 1 P1530 "B" Camshaft Position Actuator Control Circuit Signal High Bank 1 P1531 "B" Camshaft Position Actuator Control Open Circuit Bank 1 P1532 "B" Camshaft Position Actuator Control Open Circuit Bank 2 P1533 "B" Camshaft Position Actuator Control Circuit Signal Low Bank 2 P1534 "B" Camshaft Position Actuator Control Circuit Signal High Bank 2 P1540 Pedal Position Sensor P1541 Pedal Position Sensor Double Error P1542 Pedal Position Sensor Electrical P1543 Pedal Position Sensor P1544 Pedal Position Sensor P1545 Pedal Position Sensor P1546 Pedal Position Sensor P1550 Idle Speed Control valve Closing Solenoid Control Circuit Electrical P1551 "A" Camshaft Position Actuator Control Open Circuit Bank 1 P1552 "A" Camshaft Position Actuator Control Open Circuit Bank 1 P1556 "A" Camshaft Position Actuator Control Open Circuit Bank 1 P1560 "B" Camshaft Position Actuator Control Open Circuit Bank 1 P1564 Control Module Selection P1565 "B" Camshaft Position Actuator Control Open Circuit Bank 1 P1569 "A" Camshaft Position Actuator Control Open Circuit Bank 2 P1580 Throttle Valve Mechanically Stuck P1581 "B" Camshaft Position Actuator Control Open Circuit Bank 2 P1589 Control Module Self Test, Knock Control Test Pulse Bank 1 P1593 DISA Control Circuit Electrical P1594 "B" Camshaft Position Actuator Control Open Circuit Bank 2 P1602 Control Module Self Test, Control Module Defective P1603 Control Module Self Test, Torque Monitoring P1604 Control Module Self Test, Speed Monitoring P1607 CAN Version P1608 Serial Communicating Link Control Module P1609 Serial Communicating Link EML P1611 Serial Communicating Link Transmission Control Module P1619 MAP Cooling Control Circuit Signal Low P1620 MAP Cooling Control Circuit Signal High P1622 MAP Cooling Control Circuit Electrical P1623 Pedal Position Sensor Potentiometer Supply P1624 Pedal Position Sensor Potentiometer Supply Channel 1 Electrical P1625 Pedal Position Sensor Potentiometer Supply Channel 2 Electrical P1632 Throttle Valve Adaptation; Adaptation Condition Not Met P1633 Throttle Valve Adaptation; Limp Home Position P1634 Throttle Valve Adaptation; Spring Test Failed P1635 Throttle Valve Adaptation; Lower Mechanical Stop Not Adapted P1636 Throttle Valve Control Circuit P1637 Throttle Valve Position Control; Control Deviation P1638 Throttle Valve Position Control; Throttle Stuck Temporarily P1639 Throttle Valve Position Control; Throttle Stuck Permanently P1640 Internal Control Module (ROM/RAM) Error P1690 Malfunction Indicator Lamp (MIL) Electrical P1734 Pressure Control Solenoid "B" Electrical P1738 Pressure Control Solenoid "C" Electrical P1743 Pressure Control Solenoid "E" Electrical P1744 Pressure Control Solenoid "A" Electrical P1746 Transmission Control Module Output Stage P1747 CAN Bus Monitoring P1748 Transmission Control Module Self Test P1749 Secondary Pressure Solenoid Communication Error P1750 Secondary Pressure Solenoid Circuit Range/Performance P1751 Secondary Pressure Solenoid Open Circuit P1761 Shift Solenoid Malfunction P1765 CAN Throttle Valve P1770 CAN Torque Interface P1780 CAN Torque Reduction |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
