Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 02-08-2010, 11:12 PM
Abboushi Abboushi is offline
ADNIMISTRATOR
Mein Auto: has a flux capicator
DIY: LCI Eyebrow/ LED retrofit to non LCI Models
Hey Fellas,
I wanted to update the front end a bit on the 6er, I bought some Headlights and the 08 LCI eyebrows, I tried to search for the how to and couldn't find any help? So after a few hours of trial and error I got them to light up!
its not the best DIY, i took these pictures for my reference but hopefully they help? also use a basic tester to check for power this helped me so much trhroughout the process. Check the power and grounds regularly to ensure all circuits are in tact, they may get loose during the taping and connecting.
What works is the signals, hazards, alarm alert.
what does not is the led corner lights as running corners.
Slot 1- Blue wire (power)
Slot 2- Brw wire (ground)
Slot 3- Brw/ylw wire (ground)
sSot 4- Blue/brw wire (power)
LEAVE HAZARDS ON TO TEST for blinking.
step 1. remove the bumper, remove the headlamps and theres 3 screws that hold the eyebrow in place. (2 screws in the hood and 1 behind the headlamp.
step 2. cut the 2 signal bulbs and harnesses, theres another harness used for the small corner light i left it un cut and stashed.
step 3. I wired the blue wire to slot 1 (power/signal) and other blue to slot 4 (power) and 1 brw (ground) wire to slot 2 and the other brw (ground) wire to slot 3 . TEST IT.
step 4. after all is workings then solder the tips, heat shrink the wires and black tape them to stay tight and protected.
step 5. put them back on and rejoice.
10 points of Dinan Stuff, V1, M package,euro lamps, LCI updates, City Vision lighting (AE,interior and LP led), KW3, M6 Brakes.. Next? Hmmm.. Any Used Headers for sale? SOLD! Good bye Sally
HELLLO Madeline, e39 M5 is now my DD
Old 02-09-2010, 12:39 AM
Kyaj Kyaj is offline
Mein Auto: '05 E64
Very nice. Looks very clean. How much did the pair cost you?
Old 02-09-2010, 04:31 PM
pablo645's Avatar
pablo645 pablo645 is offline
Mein Auto: 650i Convertible
They are running about $250 each for the front and around $350 each for the rear.
2008 650 Convertible- 6 Speed manual- Sport package- HUD- Lane Departure- Comfort Access- Merino Leather- HD Radio- SAT
Old 02-09-2010, 07:24 PM
JESMAL's Avatar
JESMAL JESMAL is offline
Makin Lotsa Noise
Mein Auto: ACS e64 650i SMG S.Black
Well done. Yes, the corner LEDs will not work, which sucks.
Old 02-12-2010, 01:17 AM
ADNIMISTRATOR
just updated some colors on wires and placements.
Old 02-12-2010, 04:34 AM
6er 6er is offline
Mein Auto: 6er
I'm confused in the picture I can see 1 brown with one white wire connected and 1 blue wire with 3 white wires connected but you say
so should it not be 2 wires to the ground and two wires to the power ?
Sorry for the stupid question. Could some one draw a diagram
Old 02-12-2010, 09:08 AM
ADNIMISTRATOR
yes, theres several ways of wiring it, theres an option to leave the led's on fulltime theres another to make the signal blink from the side led's, but this Blue and blue brown is power, brown and brown yellow is ground. when you see the harness the slots are numbered thats just for the full led to blink. in the picture above the ground placement lights up different pattern.
all in all there isnt a wrong way to wire it if the ground is placed at #2 or #3 and power going to #1 or #4.
heres how I finished my wiring.
Old 03-14-2010, 08:11 PM
JESMAL's Avatar
Makin Lotsa Noise
I notice your main headlights are from the LCI version as well. Did you upgrade that portion or was that original?
Rumour has it that if we pre-LCI 6ers upgrade the main headlight portion, the xenon tilting function will not work. Is that true?
Old 03-16-2010, 06:19 PM
ADNIMISTRATOR
thats correct you lose the auto level feature with the LCI or the Euro in which case I had and have. Its not a feature that I care for but the chrome insert thingy majiggs make my heart beat fast
Old 03-16-2010, 08:30 PM
JESMAL's Avatar
Makin Lotsa Noise
True...love these tiny details...dang...the headlight unit cost a bomb.
Old 03-19-2010, 11:25 AM
ADNIMISTRATOR
Hopefully my LCI tails came in today!! Will install and post up pics
Old 04-18-2010, 09:47 AM
645on22s 645on22s is offline
Mein Auto: 05 645
did you buy them at bmw?? ive searched online to find the front eyebraws and i cant. Let me know if you could be of any help. Thanks
Old 04-18-2010, 02:57 PM
Solution Six Solution Six is offline
Mein Auto: 645Ci
Usually some on ebay... when searching, look for "LCI front turn signal" and you'll find them floating around...
http://cgi.ebay.com/ebaymotors/ws/eB...d=190249067744
2010 S5
2004 645ci - SOLD
Old 04-18-2010, 03:02 PM
Mein Auto: 05 645
thanks man! now i can actually search around...i guess i was missin the LCI part...
Old 04-18-2010, 04:26 PM
bmwlover1985 bmwlover1985 is offline
Mein Auto: ...
hey
hey about 60 bucks less from tisher
Old 04-18-2010, 04:36 PM
Mein Auto: 05 645
hey pablo645 can you get some night time pictures?? just with the LCI on? i wonder if its as strong or close to the audi ones.
Old 04-20-2010, 12:34 PM
Mein Auto: 05 645
Old 04-20-2010, 02:30 PM
pablo645's Avatar
Here are some shots of it on
ID:	226934   Click image for larger version
ID:	226935   Click image for larger version
Old 04-20-2010, 02:33 PM
Mein Auto: 05 645
hey thanks man! quick question tho, are they yellow? i thought thet would be super white like the audi's.
Old 04-21-2010, 06:00 AM
pablo645's Avatar
They are yellow. This is due to DOT standard. The audi and mercedes have the white LED running lamps but noticed that they are not use for signaling. They all use an amber color for the signals. With BMWs, our running lamps are the angel eyes that you can switch out for whiter bulbs to give you that white light look. I am pretty sure that some company some where is making these LCI signaling lense whith white LED as an after market add on.
Old 05-12-2010, 08:29 PM
tigerroars tigerroars is offline
Mein Auto: 2007 650i Sapphire Black
after a year are you having any problems with your install?
Old 05-28-2010, 10:40 PM
teto teto is offline
Mein Auto: m6 2006
Hi im a tech in BMW of Costa Rica, (Bavarian Motor) I have one m6 2006 and am installing indicators led, and i do what the graphic above said, but it dosnt work to me, the intermitents are very fast and in the display it indicates me as it was burned, what can I do??? your help will be very helpful to me. thx
Old 05-30-2010, 04:48 PM
JESMAL's Avatar
Makin Lotsa Noise
Dude, how much did the main headlight cost you to replace? Does it come with autoleveling?
Old 05-31-2010, 11:33 AM
Mein Auto: m6 2006
Leds
Only buy the direccinales and the stop but they me do not work ignite and go out mul fas and he says to me in the display that the indicators estan burned
