Old 04-08-2013, 11:58 AM
senser senser is offline
Mein Auto: 540i/6 E39
Crashed Today
With great sadness, I am bringing pics of the aftermath of my crash.
It's raining pretty hard right now in SLC. I did a lane change merging on to the freeway, and spun out after hitting a puddle and being unable to power out of the slide. My tail end was parallel with the wall and I ended up sliding back first into it.
DSC worked against me today.
The car's still very drivable, I drove it home after the accident, no highway patrol or other drivers were involved. Just a matter of me being an idiot.
Any tips on repairs?
Will a body shop be able to fix the dent here below the tail light?
I'm going to definitely need a new bumper plus whatever inner components got messed up. The rear bumper is pushed in about 3 inches from where it should be
Old 04-08-2013, 12:06 PM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Good you're OK. If the bumper is pushed in 3", there might be some frame damage. I would go to a specialized shop to asses the damage first. Also, if the frame is damaged, check if it's repairable.
GL
Looking for a DIY? Parts? Check this out, it might be your ticket
TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint
Stable: e39 M54, e53 N62 & Tribby
Old 04-08-2013, 01:55 PM
tcbDE tcbDE is offline
Mein Auto: (E39) 2001 530iA Sport
So, did you have DSC on or off? And when you say, "power out of the slide," do you mean you tried to correct with the throttle? Just curious how DSC is responded to your inputs.
Old 04-08-2013, 01:57 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
Good you're okay!!
How are the tires condition? DSC is only as good as the tires.
Check your mirrors as often as it takes for you to know where everyone is around you!
Old 04-08-2013, 05:41 PM
DSC was ON.
Yes, I tried to correct with the throttle.
Originally Posted by boramkiv View Post
Good you're okay!!
I have Hankook Ventus V12 EVO K110's with about 6/32nds left on the rear.
Old 04-08-2013, 05:45 PM
Mein Auto: 2007 335i
Glad your OK and the car looks repairable. I don't think you can correct over steer with more throttle.
94 318i, 97 528i, 07 335i
Old 04-08-2013, 07:19 PM
Dragan Dragan is offline
Mein Auto: 2002 BMW 530i Sport 5 Spd
+1. Letting off the throttle and going into opposite lock would've been your best chance. But even that has unpredictable results when DSC is involved. Glad you're okay. It could've been much worse.
2002 530i Sport Package 5-speed
Style 42s for summer
Style 29s for winter
CDV delete
Skibag retrofit
G.A.S. DISA Valve Repair Kit
G.A.S. 1.2 Bar Expansion Tank Cap
Old 04-08-2013, 07:45 PM
carlova78 carlova78 is offline
Mein Auto: e39 530i 5SP/e60 530i
Definitely repairable. That's similar to the damage compared to when I got rear ended. However, check for frame damage after removing the bumper.
Time for the m5 rear end.
I was about to get the Hankook Ventus v12. I've never had a problem with dead Michelin tires in the wet though.
Old 04-08-2013, 08:17 PM
I'm praying that there's no frame damage
When it's dry, they're AMAZING, but any sort of serious weather and it's scary to drive.
Another question for everyone. I have full coverage on insurance. Is it worth the $500 deductible to go through insurance? Or should I not even report it?
Old 04-09-2013, 03:58 AM
retiredat44 retiredat44 is offline
retiredat44
Mein Auto: BMW and Toyota
Thumbs up
I drove our BMW on some wet roads the day I bought it used,, and have since bought some new tires... NEXEN tires. I have not yet tried them in any serious rain yet. We don't get much rain... I am more worried about the really bad road-ragers around me.. and in my rear view mirror.... San Diego has some rotten drivers... not as bad as L.A. but still bad..
The 530i is aheavy car so that should help in the rain... but our roads build up with layers of oil, then comes some water and it's an oil slick...
I also had to put some new windsheild washer nozzles on, and hoses, the old ones were broken when I bought the car.. the pump is good,, I took out the washer motor and cleaned it up and checked it..
BMW 2001 530i (E39)
(Family cars):
1989 Toyota Corolla SR5 (400,000 miles, and junking soon).
1993 Toyota Camry LE (Daughter uses it for college).
Disabled Veteran:
Necrotizing Pancreatitis (pancreas is dying, not sure when, doctors can't giver me a more exact time of how long I have. There is no cure and with many complications.).
Old 04-09-2013, 06:12 AM
540iman's Avatar
540iman 540iman is offline
resident, old fart
Mein Auto: 2002 540i sport
Doing a survey on accidents of this type so please don't be offended, but just answer truthfully if you will. Your age? Thank you for your time and expected honesty.
Bill (old man river)
Old 04-09-2013, 06:20 AM
boramkiv's Avatar
Propellers Up Front
Here's a good question. Did you happen to notice the DSC light flashing at all?
Probably hard to see as you were paying attention to what was happening. The reason I ask is that (no offense to you in any way shape or form)
I had to correct someone before who thought that the DSC system was activated or "on" and standing by ready for issues when the light on the dash was on.
Quite the contrary.
Old 04-09-2013, 10:34 AM
540iman's Avatar
resident, old fart
I see from OPs Bio that he is likely at least 40, but something really does not add up. Just driving within the speed limit and make a simple lane change an hit a puddle which happens to us all a zillion times, yet most don't try to "power out of it" and just let the car continue to go in the direction it wants to continue to go- which is straight. You don't brake or accelerate at attempt a Power drift-type move. Trust me that you did not encounter anything that people drive through every day-difference is we let the car do what it was designed to do and not "power anything".
Sorry for your accident, but think you need to really move from tires and physical faults with the car and examine your driving technique which I am sure you will defend. Puddles reach out and grab these cars all the time and smash them up as they are inherently unsafe at any speed, even in the hands of a master driver. I hate when it does that.
Old 04-09-2013, 10:39 AM
boramkiv's Avatar
Propellers Up Front
DSC won't let you power out of it. You can throttle all you want, but if its working during that time the car remains at idle.
It is difficult to understand what happened. I'm trying to figure it out myself just to learn more and try to commit it to memory
driving in bad weather.
Old 04-09-2013, 10:58 AM
540iman's Avatar
resident, old fart
I got ya, so DSC "caused" him to be whipped up on by that (how deep) puddle and probably caused him to end up sideways and in the middle barrier in the back. Makes perfect sense. Sounds like he has a legitimate law suit. Thanks Clear as mud to me now that you pointed that out.
I can't remember the last time I ever saw anyone take credit for a maneuver that caused them to wreck. Always crap tires, car that would not power drift out of danger, cars that the driver saw a piece of wood in the road and the next thing you know they were upside down and against a tree. Audi needs to pick up on this defect and exploit it to sell more Audis-whatcha think?
Old 04-09-2013, 11:50 AM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is offline
Mein Auto: 01' 540 M-Sport cdn, F355
+1, there is likely some minor frame damage...regardless, it should be put on a frame bench and checked, that was a pretty good hit. Find a reputable shop...there is a ton of fraud in the industry these days, due to insurance companies being so cheap on what they will pay on labor, so stuff you may not see, they will skip...seriously! check on the internet, it is getting really bad out there.
Factory M-Sport with factory installed M-tech bumpers, factory Bluetooth, factory M-Audio 10" dual voice coil subs, homelink, M5 rear stabilizer bar, Bilstein B14 PSS coil overs, stop tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, strong strut front upper stress bar.
Old 04-09-2013, 11:51 AM
NoWayJose's Avatar
NoWayJose NoWayJose is offline
Mein Auto: 00 528ia Sport
glad your alright but if everything is fine sounds like a perfect time to get a m5 rear bumper
00 BMW 528ia Sport
M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza VXX 10w LED Halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks adjustable, 19" M6 Reps, Full LEDs.
Old 04-09-2013, 12:31 PM
Macht030 Macht030 is offline
Mein Auto: '00 540i/6
Glad you're alright and the damage probably could've been much worse. Sorry to hear about it. Looks like a gorgeous 540i
2000 540i Sport 6-speed | Bilsteins | Eurosport CAI | Clears
Old 04-09-2013, 09:53 PM
540iman: I'm indeed a young'n. I wonder what made ya think that I'm in my 40's by reading my bio. I'm 21 years old. I'm by no means an "experienced" driver, perhaps it's my Asian genes that made me a bad driver... just kidding lol I'm slightly confused by the wording in your post and cannot tell if you're being sarcastic or not.
A slight walk-through of what happened:
I know for a fact that my lane change was far too aggressive for the conditions. The accelerator was down a little bit to pass on a curving overpass that merges with the freeway. The DSC kicked in trying to correct the spinning tires as I hit the puddle which I wasn't expecting either to happen. Normally this would just send my tail end sliding out, which could be correctable with opposite lock, BUT I was taken by surprise and fought the DSC, by fluttering the throttle, where then I was going backwards on the freeway, threw it into reverse and kept spinning until I was perpendicular to the wall. The car stalled out and I rolled back into it at about 20 ish MPH.
Ugh re-living it just stresses me out. I also don't see any reason at all to have a lawsuit, seeing as I was the only party involved, and did not stop to phone highway patrol.
boramkiv: I saw that thread as well, and I typically keep my traction control ON(not pressing the button and having the light be on/DSC unactivated).
In this situation it was in fact "ON," not the light being on indicating your DSC is OFF.
IF I did NOT apply the throttle mid spin, two things would have happened:
1. Front end collision at +50 MPH into a concrete barrier.
2. T-Boned on the drivers side.
Although many accidents are avoidable, sometimes things just don't go as planned, due to any reason ie inexperience, faulty equipment, driver error, etc.
Thanks to everyone else for your support.
Old 04-10-2013, 05:21 AM
boramkiv's Avatar
Propellers Up Front
Thank you for this response. I'm trying to learn so that I can commit to memory. I learn from peoples' mistakes, and that's part of the reason I've been accident free all my life.
I have no issues with how you handle it, just trying to learn.
There may be other people on this forum whos coffee was soiled with contaminants unbeknownst to them.
You're obviously good because you're here talking about it, so reliving it shouldn't stress you out.
Hydroplaning is obviously scary, and the wife tells me about it all the time. (when it rains)
I've never experienced it, but I've taken courses and drifted to simulate those events.
Not the same as the real thing with your eyes and mouth wide open, but hopefully it prepares me for such.
Thank you for the detailed response.
Old 04-10-2013, 10:37 AM
540iman's Avatar
resident, old fart
Nevermind. You made my point to a "T". I would not report it as this will not be your last accident and you might need it worse later.
Old 04-10-2013, 10:49 AM
rrtec's Avatar
rrtec rrtec is offline
Bored Worker
Mein Auto: 1997 740i
That'll buff out...
I kid... Sorry to hear about that.. Looks like my car's twin brother..
1997 740i- Daily Driver- 18" M-Pars, Depo Lighting, HIDs
1991 Mazda Miata CSP Autocross Beast. too much to list..
1999 540i M-Sport 6 SPEED- Waiting for upgrades.
2010 Mini Cooper S- Bone stock TURBO Wife's Daily..
Old 04-10-2013, 07:40 PM
Hm, I'm asian and about your age too. If you're Chinese I got something for you.
So would you not recommend the Hankook Ventus v12s? I'm about to pull the trigger.
How much tread was left on your tires? Just had a friend recommend Nexon N3000s
Sorry if this has been covered, didn't bother reading the entire thread.
I had similar damage when I got rear ended. About 5-10mph. And had very slight frame damage.
Old 04-10-2013, 08:54 PM
L0F L0F is offline
Mein Auto: 3/98 528i
I almost got side swiped twice going to work yesterday. Taxi and lady putting on make up on a cellphone in a convertible beetle with a bouquet of flowers in the patented beetle flower holder.
Old 04-10-2013, 09:50 PM
Texan Engineer Texan Engineer is offline
Mein Auto: something with 4 wheels
Oh gosh, glad everyone's ok! As other's noted, there's definitely a chance of frame damage...if it were my car, it'd get a trusted indy shop to give it a quick look and quote, in order to feel out whether filing on insurance (and taking that black mark on file) is worth it. Tentatively, I'd estimate 1-2g depending how much of the crush structure (ok, whatever that beam under the bumper is called) is damaged. You have some side pictures to show how deep the damage is.
On a side note, the bumper might be salvageable? If there isn't extensive damage to the bumper itself, a bumper man could probably iron it out for a couple hundred, and let a good repairman fix the internal structure. Could end up being cheap enough to do on your own instead of dealing with insurance...
Hope you get things sorted out, that really stinks man!
