#51
My '03 530I M54 automatic transmission, definitely does have an oil temperature sensor. I have read the values with INPA and DIS. I've never tried through the instrument cluster. I do not though have any oil temp gauge as suggested by Pelican's description. My oil filter housing does have 2 sensors as indicated in the RealOEM link. WDS agrees that I should have oil temp sensing. http://www.realoem.com/bmw/showparts...01&hg=11&fg=30 part #s 12 & 13 for pressure & temp Regards RDL |
#52
Today, in the Chiefweg & Aioros Evans NPG+ threads, the question of oil temperature before and after switching to 100% propanol waterless coolant came up. The first question is: - How do I know if I have an oil temperature sensor in my E39? The second question is: - How to measure oil temperature in an E39 if I do have the sensor? (Presumably the high cluster will show it as should INPA or DIS, right?) The third (big kahuna) question is: - If I don't have the oil temperature sensor (e.g., Chiefwej or Aioros who have switched to Evans NPG+), then can it be easily retrofitted?
#53
I wonder if anyone (specifically with the M62 engine) has added an oil temp gauge since BMW included an oil temp sensor in the filter housing.
I believe the OBC has a spot for this also but it does not read a temp. ANYONE? |
#54
I can't say with certainty, but it seems to me that if you have 2 sensors on the oil filter housing you have oil temp sensing. Locator images from WDS are attached. However some OEMs use separate sensors for pressure gauge and pressure warning light. BMW may do the same on some engine/DME combinations. Second Q I assume the cluster will display oil temp if available, but don't know that. INPA and DIS definitely will display it if the DME is sensing oil temp. Third Q I don't know. If I were they, I'd pull my OFH and look to see if the boss for the oil temp port is machined with a thread & plug or left as cast, i.e. solid. If already threaded, then hope the thread matches a sensor they wish to use. Keep in mind though, the BMW temp sensor is connected to the DME. If the DME doesn't support oil temp, the only option would be an aftermarket standalone gauge. Regards NPG+ & oil temp The oil temp will not be affected by the type of coolant. Recall that the two don't mix (we hope) & they can't telecommunicate. Each fluid picks up heat from different parts of the engine and disipate it through different paths. Coolant primarily: heat from block/cylinder walls & head => radiator Oil primarily: heat from pistons & crank/con-rod/cam bearings => sump (& oil cooler if fitted) There is a weak interaction in that oil flows through galleries in the block & head which are cooled by coolant. The discussion of NPG+ properties is relevant only with regards to its ability to cool the block & head(s) under various ambient conditions and engine load. We can't possibly do these calculations since we lack the design data. When I worked for an engine manufacturer (more years ago than I like to recall ) calculations were a starting point. Prolonged testing and extensive measurement was used to ensure everything worked, particularly that there were no unexpected hot spots.Bottom line for us: the coolant either maintains ~110C or it doesn't, given ambient conditions and driving style. And we hope that there isn't a new hot spot. For interest & not BMW specific, oil temp is typically higher than coolant temperatures once at operating temp, although Arctic conditions make a difference. This is particularly true at high load &/or RPM. Engine designers calculate if an auxillary oil cooler is needed given the operating condtions & duty cycle expected. Regards oil/water sensor Yes, apparently BMW uses this part for both depending on the engine, although we hope in different locations . The sensor doesn't care what it is sensing, only its temperature. It could just as easily measure air temperature.Regards RDL |
#55
An interesting Evans NPG+ temperature reading was posted today:
- E39 (1997 - 2003) > NPG+ temperature EDIT: This is the LOW cluster; so the 60° is for the ambient temperature! Last edited by bluebee; 04-04-2011 at 02:21 PM. |
#56
I just did this tonight! Ambient temperature = 3'C.
I was parked with engine running for about 10 minutes, having a conversation. Engine temperature reached 105'C ... about 1 deg per minute increase! I then drove for about 3 minutes and it dropped to 93'C. The engine liked the cold air, me thinks! |
#57
How consistent should the temperature be?
And what is a maximum temperature I can se before I should be concerned? |
#58
For the cross linked record, here is a similar thread that was resurrected today:
E39 (1997 - 2003) > Test 7 Coolant Temp on 540i |
#59
For the record, here is a similar question, asked today:
- E39 (1997 - 2003) > Stupid question on electric Thermostat |
#60
One observation, made in that prior referenced thread (and supported by the BMW documentation in this thread) is that, at the 12 o'clock temperature gauge position, the actual range of coolant temperatures is from 75°C to 113°C.
Is it just me and that OP, or does a 38°C range of coolant temperatures for the 12 o'clock gauge position seem awfully wide to you also? Last edited by bluebee; 10-05-2011 at 08:19 PM. |
#61
If you have the OEM blue coolant and have those temps, me thinks you fan clutch is toast (or pusher fan).
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby |
#62
For the record, regarding normal operation, someone asked today:
- E39 (1997 - 2003) > Coolant system Quote:
This thread today made me question my understanding of the V8 thermostat in the BMW.
- E39 (1997 - 2003) > Engine core temp 66C- new thermostat? Quote:
The only thing not budging is the temperature gauge, which, at the straight-up position, is indicating temperatures swinging a whoppingly huge 38°C (75°C to 113°C). My question: Q: Does the V8 also have such a huge variation in temperature at the 'normal' temperature reading (straight up)? |
#64
BTW, the quote by SeanPhang has an error. A "standard" non-electric thermostat does not maintain an absolutely constant temperature. Such thermostats have a characteristic termed droop. Droop is a control theory term refering to the change in response due to a disturbance. For a thermostat in an engine, the response would be coolant temperature. The main sources of disturbances are: 1 change in engine load -> more or less heat to reject through the radiator 2 changes in radiator cooling effect -> ambient temp, air flow from fans &/or forward speed. 3 coolant flow rate -> engine RPM The extremes in swing would be ~10C from say -20F at idle to +100F at WOT (e.g. climbing a steep mountain.) The quote is correct that an engine without a thermostat will have much wider, i.e. extreme, temperature swings. And would almost never reach a normal temp. Also the statement "temperatures swinging a whoppingly huge 38°C (75°C to 113°C)." is not quite correct either. Rather the gauge is giving a constant indication across a range of 38 C °. It's like getting a bank balance without numbers rather saying either: you're broke / will honor your cheques / filthy rich. ![]() The WDS characteristic map diagram indicates that temperature will range between 85C and 110C - still a healthy 25C range. It seems that BMW has designed the gauge so that these changes are invisible to the driver, who would thus not complain and generate an unnecessary warranty service visit. But 38C° does seem more than a bit overboard, doesn't it? Regards RDL
Regards RDL |
#65
That probably contributes to the BMW oil specification....i.e. to handle the large temperature swings. That may also be why the high pressure cooling system.
Frank 540/6 Dirrezas (4) @ 275/35-18, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy |
#66
Thanks. Quote:
If I understand you correctly, you're explaining that the range 'could' be as great as 38C° at the center reading but the 'practical' range is more like 25C°. You've been 'very right' before ... so ... I'll go with that. |
#67
My car is a 05/97 540i w/ 114k and 10k on the thermostat and I average 104-105C, and dip to 103C at colder places on the highway like the Bay Bridge. Is it bad that my average temp isn't the 110 other 540i's are at? I know the thermostat and fans are different at some point in 1998, but I don't know if it has any actual difference or if my system is running 'cold' for some reason. Should I be happy since it is solid where it is?
#68
Just did a modified cooling system overhaul (kept the old radiator and thermostat). This is a 'new to me' car - '99 540iT, M62TU, 107,000.
Started it up after the overhaul, idling with a/c off and watched the KTMP (high cluster) as it warmed up. (ambient temp around 65F) KTMP 110C, idiot gauge centered KTMP 115C, idiot gauge ticks toward red KTMP 116C, idiot gauge ticks toward red KTMP 117C, idiot gauge ticks midway between centered and red At this point, the electric fan clicks on, and I watch the KTMP drop from 117C to 101C within a 20 second span, and the idiot gauge returns to center. Hope this information is useful to someone. |
#69
ever since I unlocked my hi OBC, I've been a KTMP wathcing junky...driving differently, varying ambient temperatures, engine speeds, (I have the 6 speed 540i) Firstly, the analog dash-gauge goes to the noon position from 80*C-115*, the auxillary fan kicks-in at 106*C and hits warp speed @ 110*C. It seems to me that the thermostat is always in "search" mode regardless of how I drive.
my normal commute, (if you want to call a 15minute drive along the lake a commute) allows me to drive from 35mph to 50 mph, (depending if there are any self-appointed speed enforcers puttering along at the posted limit) and I can loaf along in 5th/6th gear at engine speeds in the low teens and I can zip around in 3rd/4th with RPM's in the high 20's-mid 30's. Interestingly, the higher RPM/load maintained a more consistant 104*/105*C while the lower RPM's had the thermostat seemingly working harder to find that sweet spot. just an observation from watching that display for the past 6 months...appeals to my OCD nature
This post is so informative that I append it here for others to benefit from:
> E39 (1997 - 2003) > coolant pressure Quote:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
#71
Long time lurker, first time poster...
Digging up an old thread to build on this bit of info from TJJ re: the DTS:
Filled it and shut it off after running it for a while to bleed it. I noticed when I shut it off, the KTMP on the cluster changed from -128 to 88. Restarted the car, noticed that the temp gauge went to 12 o'clock for a brief moment, then immediately spiked into the red again. KTMP was -128 again. Seems that different sensors are in fact used depending on whether the car is running or not. I had manhandled the DTS a little on its plastic body with a pair of channel locks when trying to take the plug out so think I turned it into a single temperature sensor. ![]() Also noticed the SAP didn't run, guessing that's because the DME didn't know whether to run it or not, as it decides this from the KTMP. (cooler temp = longer run times) Now to put an ohm meter on some pins of that DTS... |
#72
New information on controlling the thermostat was posted over here, for reference:
> X5 E53 (1999 - 2006) > Controlling the thermostat myself on my M62 4.4i (DME 7.2) Quote:
#73
This related post by RDL contains some good information that we should keep together:
#74
For the record, this thread today has related information:
> E39 (1997 - 2003) > Problems with coolant temperature Quote:
#75
For the record, people are often wondering why their temperature gauge reads slightly left or right of center, as in this thread today:
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
