Old 02-09-2010, 05:22 PM
Bell528i's Avatar
Bell528i Bell528i is offline
Ich bin ein Berliner
Mein Auto: 2001 740iL
Question Fan Clutch
Has anyone ever replace their fan clutch? Also how hard is it to replace?
Der einzig wahre Fehler ist, wenn Sie versuchen zu stoppen!
Old 02-09-2010, 06:12 PM
kingbled kingbled is offline
Mein Auto: 1999 540i 6speed
I think it is fairly easy you just should get the tool to get the fan off...
Old 02-09-2010, 06:18 PM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
www.bimmerboard.com/forums/posts/199986
Old 02-09-2010, 06:21 PM
shalyndavis23 shalyndavis23 is offline
Mein Auto: 528
yes, just 3 screws that hold the fan clutch on to the plastic fan, taking out of the car is hard make sure you have the water pump pulley holder tool
Old 02-09-2010, 07:16 PM
Waveho Waveho is offline
Mein Auto: '07 335xi 6MT 4door
I think that by now just about every member with over 100 posts here has had to replace the fan clutch! Some have needed special tools, but I was able to get mine off with a VERY slender, wide-opening adjustable wrench and used a screwdriver as a holding tool for the water pulley (sorta).
'07 335xi 6-spd 4dr, Montego blue
'98 540i 6-spd Sport, Jet Black II(sold)
'92 325i 5-spd 4dr, burgundy(sold)
Old 02-09-2010, 08:27 PM
Neversaynever Neversaynever is offline
Mein Auto: 2002 525i
Save yourself the potential of a ton of aggrevation and get this either homemade or BMW tool which is designed to allow you to hold the fan from spinning in order to loosen the fan nut (reverse thread). It is tight quarters in there and this simple tool is worth it's weight in gold.
http://www.bimmerfest.com/forums/sho...623&highlight=
CL
2002 525i 164k
1988 911 Cabrio
1986 911 Coupe (track car)
Greater Boston, MA
Old 02-09-2010, 09:09 PM
lennyd lennyd is offline
Mein Auto: 540i/6 Speed
we don't need no stinking tools... slim adjustable wrench and a long screwdriver to wedge into the gap between the pully bolts to keep it from spinning. replace you fan too, its bound to not be nearly as flexible as it should be. Cheap insurance too.
2001 540i 6 Speed / Jade Green Metallic / Two Tone Interior / 16:9 Mk IV Nav / Sirius / Bluetooth / Sport Seats / Staggered 18" M Pars / Custom Exhaust
1999 528ia T / Black / Sport Pack / Premium Pack / Sand Beige / Nav / DSP / Sun Shades
Old 02-10-2010, 05:34 AM
1+++
Old 02-10-2010, 06:41 AM
Jase007 Jase007 is offline
Wrenchin' fool ...
Mein Auto: e39 528it
Sometimes ... the reverse theaded nut of the fan clutch is really stuck on there.
Your need leverage as I did ... aluminum jack handles on BMW specific wrenches ...
Jason
2000 528iT Sport 5M (mfg. 5/1999) ~ 1990 325iX 5M
BMW CCA member #130075
JScottRacing
Old 02-10-2010, 06:46 AM
Certainly works either way: screwdriver or tool. Just a preference, that's all.
CL
2002 525i 164k
1988 911 Cabrio
Greater Boston, MA
Old 02-10-2010, 06:48 AM
Jason, that is hilarious. How the h** did you get those big jack handles to reach the tools with the fan in there. Amazing.... You must have taken the fan off the clutch while in the car.
CL
2002 525i 164k
1988 911 Cabrio
Greater Boston, MA
Old 02-10-2010, 06:50 AM
Mein Auto: 528
jase007 your fan shroud looks like mine after trying to get the fan clutch bolt off, hardest job ever
Old 02-10-2010, 08:15 AM
mmm635's Avatar
mmm635 mmm635 is offline
Mein Auto: '02 525i Sp/5, 95 FJ80 LC
If you are not far from Jackson, then I will show you how to do it.
Michel
2002 Sterling Gray/
Black 525i Sport Pics
Old 02-10-2010, 08:34 AM
Probably should consider removing the fan shroud first....
Old 02-10-2010, 08:44 AM
Solidjake's Avatar
Solidjake Solidjake is offline
The one and only
Mein Auto: 2002 330i
I replaced mine because it made my fan seize and blow, lol.
Just buy from ebay the fan clutch tool kit, should be $40 shipped max, that takes a few min to take off and then screw on the new one. Done.
_______________Going to Bimmerfest East AND West
Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide
Old 02-10-2010, 09:00 AM
Wrenchin' fool ...
LOL
My fan shroud was heat dried / cracked already by previous owner ... I replaced with new from getbmwparts.com for ~$50. They are a safety item as well ...
At 7 years old ... 150,xxx miles .... you could grab the edge of the shroud nearest the engine and "crack" off pieces. (pic was back in '07-ish)
I got my wrenches a few years back from baum or zdmak online sales. They make the job easy and I lend them out often to fellow local BMW owners.
I love my BMWs but ... to much plastic in the engine bay.
Jason
JScottRacing
Old 09-09-2010, 10:39 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Found this thread searching for a link for a newbie and figured I'd cross reference to this toolmaking thread for one-stop shopping.
How to make your own BMW special cooling system & drive belt counterhold tools
Old 09-16-2010, 07:10 PM
Wrenchin' fool ...
Update:
I see my photo is making it's rounds in the Internetz ... lol
I've had the clutch/fan off a few times since this repair ... gentle nudge is all it takes to loosen it.
Highly recommend Lubro-moly LM-508. Use it in critical applications on street and track cars. Otherwise use the silver stuff ('65 f - 1600f).
http://www.liqui-moly.de/liquimoly/p.../usa_2012.html
... as a good coper based antiseize.
Anti-seize Info:
Copper antiseize (C5-a) copper and graphite in high quality grease. Protects metal from corrosion, galling and seizing at temps to 1800°F. Zinc antiseize: Protects aluminum and ferrous surfaces from seizure and corrosion up to 700°F. Silver antiseize: Heavy-duty, temperature-resistant, petroleum-based lubricant compound fortified with graphite and metallic flake. Inert, will not evaporate or harden in extreme cold or heat up to 1600°F. Nickel antiseize: Copper-free. Recommended for stainless steel and other metal fittings. For preventing corrosion, seizing and galling in harsh chemical environments and temperatures to 2400°F. Zinc works well, and it mentions its use for aluminum, but the copper free nickel is a good choice too. Used on lug nuts, brake caliper bolts, spark plugs various front of engine bolts (except for water pump, which will use low-strength anti-seize). Not all antisieze is compatible with O2 sensors. If it has Nickel, it can trash the O2. Call Bosch 800 # for advice. Optimoly HT - Copper Antisieze, Optimoly TA - Silver Antisieze, Molykote U - Dry Graphite Molybdenum.
Jason
JScottRacing
Old 09-16-2010, 07:43 PM
MatWiz's Avatar
MatWiz MatWiz is offline
Psychology Reversalist
Mein Auto: 528
Originally Posted by cn90 View Post
1+++
I never figured out where to wedge that screwdriver. And God knows I tried.
I need a close-up photo of this thing to understand. I don't see where it goes, even on my 50" plasma monitor.
Embarrassing. I know.
mw
MatWiz
"Seeing is not believing. Believing is seeing." -Judy the Elf
