The X5 SAV Forum
Old 02-10-2010, 01:51 AM
bradgan bradgan is offline
Mein Auto: BMW x5 AND 335i
BMW X5 Transmission Problems
Hi,
I have a BMW X5 V8 2002 Model. Basically after driving for about an hour or when the car heats up and driving it hard the transmission will automatically go into a sports mode where it will hold in gear until basically it red lines. We have
1. Changed the oil,
2. Changed the Throtle Sensor,
3. Cleaned all the wires that lead to the throttle box (as they did have corrosion on them).
4. And many many other things which i cannot remember as the problem started about 18 months ago and now worstening.
The Mechanics computer does not identify that there is a problem so it is very hard to find
I ask for any assistance
Regards Brad
Brisbane Australia
Old 03-26-2010, 12:49 AM
KnightofDeeDee KnightofDeeDee is offline
Mein Auto: 1997 540i/6 2000 X5 4.4i
Hello,
I am having the same intermittent issue on my 2000 X5 4.4i. I can actually be on the highway and it be working fine when suddenly it will down shift and be at 4k rpms and then go back to normal 2k rpms. It can do that several times within 5 seconds of each other. Sometimes it shifts high the whole time I drive and other times it stabilizes and works OK with occasional high shifting. I noticed that when it high shifts, there is Nothing I can do to make it shift differently. In Sport mode it acts the same way and when in Manual mode it completely bypasses it. In Manual mode I will hit is to shift from 2nd to 3rd and it will go to '3' for a second and then back to '2'.
The high reving goes like this:
1st gear, shifts at 3k Rpm's
2nd-4th gear, shifts at 4k Rpm's
When it acts up it will always shift at those points regardless of how hard or soft I give it gas.
Then when down shifting it will drop gears at 3k rpm's which feels like the car is braking.
It seriously feels like a bad connection somewhere. I read on one of the forums that it can be the transmission harness which I am seriously considering replacing along with the fluids and filters.
The trany was already rebuilt by the previous owner for $7,000 so I think something might of happened to the harness during the rebuild.
This problem is getting worse as the weather is warming up here in California. During the winter it was only doing this every other week only when it was cold. Now it is doing it Every Day regardless of cold or hot.
Someone please advise if you know what this could be. If not I will update once I get it sorted out.
Regards,
Tomas
Southern California
Old 03-26-2010, 08:46 AM
ard ard is online now
Resident Curmudgeon
How many miles on the car and on the transmission... BOTH POSTERS.
Tomas, who did the "rebuild"? Any warranty on their work?
How often has the ATF been changed? Both posters.
Both sound like hydraulic issues within the transmissions which will NOT show codes....
A
Resident Curmudgeon
A
Old 03-26-2010, 09:07 AM
Hello,
My X5 has 137k miles. It has maybe 15k miles on the rebuilt transmission. I don't have the name of the shop on me but it was done by a reputably shop in Orange County. The job was done almost 2 years ago and it carried a 1 year warranty which is obviously expired. ATF was changed when it was rebuilt 15k miles ago. Also I do pull a code from the EGS with my P.A. Soft 1.4.0 diagnostic tool. I cant quote it but it's something like "Transmission Sump Temp Sensor". And I have cleared it but it keeps coming back. I know it has to relate somehow to my issues. Which brings me back to the possible solution that the Valve Body harness is faulty, since the harness has the built in temp sensor.
I can get the harness from the dealer for $150.00.
What do you think?
Tomas
Old 03-26-2010, 10:14 AM
Resident Curmudgeon
1. A BMW transmission is factory remanufactured, which means that it has not JUST the parts that come in a rebuild kit, but every single part including the valve body replaced or reworked.
2. BMW reman has a 2 year warranty.
3. Buy the harness. Worth $150.
4. What does the shop that did the rebuild say? Have them try a diagnosis.
Old 03-27-2010, 03:00 AM
HI Guys,
I posted the original thread and i have resolved my problem . There were many issues which caused the problem and i will explain.
basically my mechanic said it would go into this mode once the transmission hit 128 degrees. We found that the transmission oil cooler was not cooling to its capacity (it was intermittedly working). Along with that we found the the bottom of the radiator has a pipe going to cool the transimssion. This has an internal thermostat (something he has never seen) and this was seized. So it also got replaced as.
The car now runs constantly at 115 degrees and the A/C is also working so much better...
I have been running the car for about 1 month now and the problem hasn't returned (touch wood).
Hope this helps
Brad
Brisbane Australia.
Weather here 29 degrees hot and sunny but starting to cool down.
Old 03-27-2010, 08:56 AM
Resident Curmudgeon
Wow. That is interesting. So is there a transmission cooler that is integrated into the radiator (this is pretty common) but also with a thermal valve integrated into the cooler??
With some vehicles, a tranny replacement requires VERY specific flushing of the hydraulic cooler lines- under the theory that when the tranny fails the particulates will disperse into the cooler and. if not cleaned out, will cause the new tranny to fail.
Clean fluid, changed often, is essential for long tranny life. IMHO.
I guess simply hot fluid- perhaps so hot it no longer performed within the range of hydraulic performance required- was causing the tranny to not shift properly.
Thanks for posting the fix- very helpful
A
Old 04-18-2010, 01:19 AM
I FOUND THE SOLUTION!!!! It is a faulty Valve Body Wiring Harness. Part number: 24.34-1 423 719 $198.11
The transmission always registered 'Transmission Sump Temp Sensor' and the harness has the integrated temp sensor.
Took me 4 hours to fix it but got it all squared away. You also need 7 Quarts of ATF OIL which ran me $80.00 (Bought the Red Line Synthetic on eBay), and new Filter with O-Ring.
So if your beloved X5 is Up Shifting at 4k RPM's and is Down Shifting at 3k RPM's, with all of the symptoms I described in my previous posts. Then this is Most Likely your problem since it was mine.
Prosedure:
-You need to drain the ATF Oil
-Drop the Transmission Oil Pan (T27 Torx)
-Clean the magnets and everything
-Remove the Oil Filter
-Unplug the valve body harness and remove (the large round connector plug must be maneuvered out since it is in a very tight place)
-Plug in the new harness
-Install new filter and O-ring
-Install the Pan and gasket if necessary
-Top off the transmission with a Hand Held Oil Pump. about 5 quarts
-Turn the car on with the car level and go through all the gears
-Go back under the car with the car running and top off the transmission oil again. about 2 quarts, watch out for the Hot Exhaust!
This is a rough step through but should give you an idea of what to expect if you decide to do it yourself. All of this is MUCH easier if you have a lift. Pretty much everything is easier with a lift.
Hope this helps lots of you out there. This harness has also cured my hard shifting which felt like I was getting rear ended through each gear, vice versa when downshifting also.
Tomas
Old 04-18-2010, 08:55 AM
Resident Curmudgeon
Thanks for posting.
Old 01-17-2011, 11:58 PM
ydanikas ydanikas is offline
Mein Auto: x5 4.4i '01, z4 3.0si '07
Hi Tomas,
I have exactly the same problem with my 2001 X5 4.4i. I am planning to change the Valve body Wiring Harness that you mentioned. But before I do, I wanted to make sure that this was the problem. I mean, it has been almost a year since you changed it, has the problem gone away completely?
Thanking you in advance for your reply.
Yannos
Old 03-16-2011, 10:17 AM
Hi guys,
I finally placed the order for the part that Thomas mentioned in his post and I asked BMW service to replace it. The problem is now completely gone!!! I am very glad.... This definitely saved me a lot of money.... If I took BMW's mechanics advise I would have to change the entire transmission...!!
Yannos
Old 05-19-2011, 01:49 PM
Follow Up on this issue
Thought I would give a follow up on the Hard shifting issue that the harness was causing. I am now at 155k miles and no hard shifting! The harness was for sure the problem to the hard shifting and high rev shifts. Sad thing is that I now have a bad pulse generator to the output speed sensor so I will going under the X again either today or tomorrow. Its causing the Trans Failsafe and SES light. Reverse works just fine.
IKE Error:
8D EGS Signal Line Disturbed (Not Active/Intermittent)
EGS Error:
(059) 3B Stall Speed Monitoring (Always Active)
Not looking for a solution. Just thought I would post up my findings. If you do change the harnes though, its better to replace the two pulse generators that are held on by a torx screw, since they are only $50.00 each. Its better to do it the first time so you dont have to go under the truck twice like I am.
Regards,
Tomas
951-522-4032
www.BMRPRTS.com
Old 08-22-2011, 02:30 PM
Another A-Drum Failure
IKE Error:
EGS Error:
Update to my latest post:
Though the above Errors could very well be a pulse generator issue, after hours of diagnosis on the GT1 and checking the electrical system nothing could get my 1-4 gears back. So I took it to a mechanic to remove the tranny and sure enough it was a bad A-Drum that bursted at the retainer ring causing the pressure to escape. The A-Drum controls gears 1-4. I had a couple bad bearings in there also. Total job was $2,750 with the enhanced A-Drum sold on eBay for $250.00. 3 months and no issues.
Tomas
www.BMRPRTS.com
951-522-4032
Old 01-17-2013, 08:40 PM
Davodags Davodags is offline
Mein Auto: X5
Hello Brad. Are you able to advise is your problem is still rectified. Cheers Davodags
Old 01-26-2013, 04:21 PM
ktpolanco7 ktpolanco7 is offline
Mein Auto: 2004 X-5 4.4L
My 2004 X-5 4.4L will not shift into high gears. It revs past 4000 rpms and wont shift into higher gears. It's most noticable past 40mph since this is when it normally shifts into higher gears.
Please help
Old 04-02-2013, 06:54 PM
408sanjosebmw 408sanjosebmw is offline
Mein Auto: bmw x5
hi, i have the same problem with 2002 BMW x5 . trasmission failsafe program comes on once the car heats upp.. i have code p1747.. what it could be? any help would be apresiated dealership diagnostic $215..
Old 05-21-2013, 04:49 PM
oguh45 oguh45 is offline
Mein Auto: 2000 bmw x5
Question
Prosedure:
Tomas
Hi waht type of test you did to detect the problem?
Old 05-22-2013, 07:09 AM
NJPILOT NJPILOT is offline
Mein Auto: x5 E53
Transmission rebuild cost ????
I have an X5 with 147,000 and the original transmission.
Can I reasonably expect get 200,000 out of my transmission?
What does a transmission rebuild cost?
