Old 05-20-2014, 04:06 AM
spankey spankey is offline
Mein Auto: 335xi
Stuck gas gauge 07' 335xi
I noticed since this past Friday that my gas gauge seems to be stuck about a 1/8-1/4 tank fuller than what my miles left till empty are reading? I put more gas in it today and the gauge rose to a smidgen past half tank however my miles till empty read 169 which is usually between a 1/4 tank and half tank?
Any ideas on what could be causing this? Again this just happened a few days ago.
Could the fuel pump be related to this? I would think not but it concerns me since it's an 07 which had the dreaded fuel pump issues. I'm at 103,000 miles currently.
Thanks!
Old 05-20-2014, 04:53 AM
Mein Auto: 335xi
I just read that there is a bulletin on the recall website that states a possible failure on the fuel sensors? Hmmm???
Old 05-20-2014, 07:36 AM
sunny5280 sunny5280 is online now
Mein Auto: 2011 X5-M
That seems the logical point of failure. As for the fuel pump it's warrantied until 120K miles so that would be the preferred, if unlikely, part to fail.
Old 05-20-2014, 08:57 AM
marius07031 marius07031 is offline
Mein Auto: 2011 BMW 335XI
Thanks!
If you've programmed your car before and you're familiar with NCSExpert try to load up your KOMBI module and do a "SG_Reset" something like that. It will reset your guage to default and also do a FA_Write to re-code it and make sure everything is good. It happened to me not too long ago I was messing around with NCSExpert and somehow i bricked the KOMBI. I went to put gas and it overflowed and it wasnt sensing anything - MPG or how many miles are left. I did the reset and recode and it worked good right after that. Hope this helps.
Old 05-20-2014, 08:58 AM
Mein Auto: 335xi
Is it safe to use the computer reading miles until empty vs the gauge? Weird they would give two different readings? I would think one fuel sensor would send info for both readings? Both are reading different!
Anyone have any links or how to's on replacing the sensor?
Old 05-20-2014, 08:59 AM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
Why would you FA_Write? FA-Write is used to code the VO string to CAS and NFRM.
You should not use FA_Write for this job
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 05-20-2014, 09:06 AM
Yeah you're right. All he needs to do is a reset then.
Old 05-20-2014, 09:08 AM
Mein Auto: 335xi
I don't have any way or tools to do anything computer code wise the car so that won't work. The car is stock! I'm gonna stop at my local bmw dealer today and talk to them about the fuel sensor bulletin and the fuel pump warranty. I also have the nasty waste gate rattle too. No warranty but just curious about if my car ever had the fuel pump recall performed at all.
Mein Auto: 335xi
Sorry meant to say the car is stock! Nothing software wise has ever been done before
Old 05-20-2014, 09:11 AM
Mein Auto: 335xi
I also tried to pull the fuel gauge fuse and that didn't work. Is there a way to hard reset the car such as pull a fuse or main power from the battery for a period of time?
Old 05-20-2014, 09:13 AM
The float in your gas tank might be bad.
The miles remaining is mainly a calculated value and is barely based off sensor readings.
Old 05-20-2014, 09:16 AM
Mein Auto: 335xi
That's so strange because it just happened instantaneous . No warning such as slowly going or such
Old 05-20-2014, 09:38 AM
Mein Auto: 335xi
I pulled the negative on the battery and my miles till empty now increased to where the gauge is reading. I'll keep an eye on it to see if it moves and post back
Thanks guys
Old 05-20-2014, 10:50 AM
Mein Auto: 335xi
Just drove 35 miles. Working again! Whew! Thanks guys
