Old 02-19-2010, 05:41 PM
busa1300 busa1300 is offline
Mein Auto: 2001 DINAN M5
2002 M5
mileage = 52k
all mine baby...
only needed a new clutch at 51k hahaha a norm for these beasts
Old 02-19-2010, 06:04 PM
Financeman Financeman is offline
Mein Auto: 2003 530IA
67,000 miles, putting 13,000 miles on the car since purchase in January 09. So far; front pad and brakes, battery, vapor barriers, FSU, and tires. Up next; CCV, Oil Filter Gasket, spark plugs, fuel filter, and cooling system overhaul. Probably needs vanos. I figure about $1,000 in parts and a full day sometime this summer.
Old 02-19-2010, 06:09 PM
e39BMW e39BMW is offline
Mein Auto: 1997 BMW 540i
What is your odometer at?
5k miles on ODO but actually has 225K miles (Had some fun with my cluster)
What year?
1997
Any major drive train repairs?
New clutch 2 month ago, complete cooling and gasket overhaul
Old 02-19-2010, 07:18 PM
chevelle01969 chevelle01969 is offline
Mein Auto: 2002 530i
2002 530i sport premium
128,000
Old 02-19-2010, 08:56 PM
davenotize's Avatar
davenotize davenotize is offline
03 530 S/P for sale!!
Mein Auto: 03 bmw 530s/p 02 bmw 525
Originally Posted by Josh P. View Post
What happened with your torque converter? That seems like low mileage for a new converter. I have a Step w/ 62k and am hoping that torque converter will last a while. Plan on changing diff/tranny fluids in the spring, for first time.
For OP: See the sig for my repairs (some other wear items like brakes were not included).
sorry for the late reply!! im careful with the car from the moment i turn the key and let the fuel pump do its job!! but one day cruising,"service engine soon" came up out of nowhere....my heart dropped, everything was just quiet the only sound was my heart beat at 110mph turned pale, hands sweaty kinda feeling....and the TC had given up on me, its weird that at 67k it would give me those kinda problems but yeah thats what it was, the indy did his job but did not replace the tranny fluid, i wonder if its a bad a idea to replace the fluid now that i did that, my car is like new with so many parts getting replaced avery 2 months i wish these cars were like nissans, my brother owns a 01 altima and at 160k it runs fine, nothing but oil changes.
Old 02-20-2010, 04:20 AM
helpmyfive helpmyfive is offline
Mein Auto: 528i
98 528 with 160K.
I put over 14K in 4 months on it.
So far I've had to JB weld the front wear sensor back in place to stop the sensor light, wrangle a bolt and nut in the ebrake pads to prevent a squeak, replace the idler pulley, sand the wiper relay, replace plugs that looked factory, clean the ICV and replace the traction control throttle cable.
Aside from the idler pulley (which flew off but the belt continued to run on the frozen bearing just fine) none of the repairs were dire. I plan to swap the vanos seal once the weather gets better as well as replace the front struts.
Love that car!
Old 02-20-2010, 04:35 AM
marcelbakker7 marcelbakker7 is offline
Mein Auto: E39 523i executive 1996
mine has got 167k (523i '96), but there are some e39's with over 250k miles for sale in germany, and yes those are petrol engines
example:
link!
Old 02-20-2010, 09:55 AM
ajustin67 ajustin67 is offline
Mein Auto: 1999 e39
coolant leakkkkkkkkk
Old 02-20-2010, 10:20 AM
Chris10980 Chris10980 is offline
Mein Auto: 98 528i
98 528i 172k still tight and going strong
Old 02-20-2010, 12:45 PM
EasyE EasyE is offline
Mein Auto: '02 M5, '84 R80 G/S PD
Originally Posted by Meinfarr View Post
03 530 42500....
No repairs yet...but I feel a Vanos coming soon. Poor mileage and hesitation.
Early for VANOS...maybe try new MAF sensor
Originally Posted by Bell528i View Post
158-159k
Few problems need to be sorted out, but the most important on right now is the fan clutch.
With that mileage....might as well do the fan blade....seen examples of them grenading and doing a bunch of damage....about $1,200 worth...not counting the hood.
'02 M5 97k
Went bad:
Ebox fan ~$160 for part
Clutch at 60k
Fuel Pump at 95k
Thermostat...doing soon (fails open)
rear sway brackets (weak aluminum...went to TC Designs product)
power steering hoses 70k
waiting to install
Royal Purple Synchromax diff fluid
Royal Purple 75w-140 tranny fluid
Coolant flush...soon....with thermostat
Shocks/struts/springs/ball joints, control arms, center link, tie rods, idler bushing, front wheel bearings, Monoballs
VANOS o-rings & solder board
Fan blade
Old 02-20-2010, 03:25 PM
bakdoc66 bakdoc66 is offline
Mein Auto: 2003 540i6
Good thread.
53K
2003 540i6
Bought with 44K. Since ownership April 2009: Cabin filters DIY, FSU (nervous, but VERY DIY, then angry what dealership wanted to charge for repair), oil change (dealership) and left rear door seal (didn't know it was a DIY). Planning to do clutch delete valve this spring.
Not sure what will go next. Don't know if cooling system was done prior to my ownership, any suggestions how to find out?? Maybe nothing will go wrong??
Old 02-21-2010, 12:30 AM
It's good for peace of mind to just swap the fluids on purchase....unless you have records.
Tranny (17mm socket), diff (14mm allen)....make sure you can crack open the fill hole before loosening the drain hole....for both diff & tranny, coolant every 2 years, brake fluid every 3....there will be a little leftover brake fluid in the system, unless you take it to the dealer & have them actuate the ABS to get it all out....or do some real heavy braking & then flush a little more.
Cheers,
E
Old 02-21-2010, 10:49 AM
papito papito is offline
spanky
Mein Auto: 1999 528I
99 528i I HAVE 72685 MILES
Old 02-21-2010, 03:00 PM
raiderddj raiderddj is offline
Mein Auto: 2000 528i, 2000 RC-51
133k
No problems...my first check engine just came on today...we'll see how she goes!!!
Only minor repairs to this point, cooling system overhaul...hoping for another 100K. Great car.
Old 02-21-2010, 03:01 PM
2000 528i 133k
Old 02-22-2010, 09:48 PM
POof540i's Avatar
POof540i POof540i is offline
^^^Worst Username Ever!
Mein Auto: '01 540iA
Originally Posted by davenotize View Post
... i wish these cars were like nissans, my brother owns a 01 altima and at 160k it runs fine, nothing but oil changes.
I wouldn't go so far as to say it runs "fine", only that it runs.
"The more you know, the more you don't know," Dave Chappelle
"Man is an emotional animal, occasionally rational; and through his feelings he can be deceived to his heart's content"-Durant
WTT: Black Comfort Seats for Black Sport Seats. PM for info.
Old 02-22-2010, 09:52 PM
POof540i's Avatar
Originally Posted by bakdoc66 View Post
...Don't know if cooling system was done prior to my ownership, any suggestions how to find out?? Maybe nothing will go wrong??
There's a sticker with the date on the passenger side of the radiator. Look there and you'll at least know if the radiator has been recently replaced.
Old 03-01-2010, 03:44 PM
Andreas540i's Avatar
Andreas540i Andreas540i is offline
1997 125K
Cat Converter, Oil Leaks
1997 BMW 540i
Old 03-01-2010, 07:41 PM
etc etc is offline
Mein Auto: 528i
119K
This bimmer has its cooling system done and tranny replaced.
Next: Suspension. This summer: VANOS and CCV.
I want to keep it until 200K miles.
Of course we all know that "Life is what happens when you have other plans".
1999 BMW 528iT. Station wagons are back.
Old 03-01-2010, 08:40 PM
Bethesda E39's Avatar
Bethesda E39 Bethesda E39 is offline
Mein Auto: BMW 1 Series
2003 525i
85,000 mi
Water Pump failure at 79K [WP + thermostat replaced], all other cooling system components are original.
Nothing else major (LR vapor barrier, driver's seat transmission [ext. warranty], RR tail light assy [corrosion]).
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Just rolled over 96,000 today!
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 03-02-2010, 05:13 AM
RBS007 RBS007 is offline
Mein Auto: 540i M package
2001 just went over the 200 KM ! stored every winter ( Dec - April ) Last summer was not a good one for repairs put about $2,500.00 into the car. Thinking of selling it but I do love to drive it !!!!!!
Old 03-02-2010, 06:04 AM
dacey1974 dacey1974 is offline
Account closed at users request
Mein Auto: 2002 BMW 540iA Sport
2002 540iA Sport 80236 miles
Old 03-02-2010, 01:40 PM
NFS NFS is offline
Mein Auto: E39 540I
00 135K. Too many repairs to list.
Old 03-02-2010, 03:08 PM
jun jun is offline
Mein Auto: 2003 540a
2003 540A
30,519 miles
no problem of any kind at all:-)
